Question about Canon L220 Plain Paper Laser Fax
One Fax machine insatllaed in General Manager Office SEC railway. Problem of this FAX is we receive FAX either 30% or 40% not in complete form. Please provide me solution.
  • 385 Answers
Under rx setting in user mode try setting ecm rx off!!
Posted on Mar 31, 2010
  • 1,219 Answers
Does your fax display error message such: CHECK THE PAPER SIZE or PAPER JAM?
IN CASE OF CHECK THE PAPER SIZE YOU SHOULD CHANGE THE REGISTRATION SENSOR FLAPER.
Posted on Feb 20, 2010
Phone line and fax machine
ou may have inadvertently changed it from "Auto Fax" to "Manul". From the Xerox knowledge base website at:
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=12,E=0000000000022752235,K=612,Sxi=13,Case=obj(18044)
Print the fax received in manual mode by:
When a fax is received, your machine sounds the ringer. Then you will hear a fax tone. Press On Hook Dial and then Start Copy/Fax. The machine prints the fax and returns to Standby Mode when the reception is completed.
To change back to "Auto Mode", follow the instructions at:
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=53,E=0000000000022752268,K=612,Sxi=14,Case=obj(18040)
Jan 07, 2014 | Xerox Office Equipment & Supplies
We have two fax machines hook up to one dedicated fax line. When we send a fax from wither machine it is not faxing to the phone we fax it only sends the fax for the second fax machine that is in our...
Yes, you must set up your fax machines like this: The receiving fax must be set to auto receive and the telephone line must be inserted in the "line" input. A line must then be connected from the "Tel" to the "Line" of the Transmitting machine, which must be set to "manual receive." This is not really a satisfactory way of doing things as you can't send and receive 2 machines on the same line together. A much better way is to have 2 lines. with a machine attached to each. Get the tel company to put "No answer transfer" on the line as an accesory. Give them the number of the fax machine that transmits. Make it "manual receive" Now you have a versatile system that you can also use the office telephone with.
Oct 05, 2010 | Brother Office Equipment & Supplies
Can i re-print the document form the memory of the fax machine?
no, you can only print out a journal to show what fax number it came from.
Aug 03, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
THE FAX MACHINE CAN RECEIVE THE FAX IN THE MEMORY BUT FAIL TO PICK UP
My office fax machine can receive the fax in the memory, but it does not print it.
May 19, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Unable to complete fax transmissions
This turned out to be a Vonage issue. I was able to fax from my landline. I googled vonage and mx700 and found a number of similar issues. I also ended up setting my speed to 9600 and turning off TX error reporting. A quick call to vonage and an updated profile (not sure what they did) resolved the issue.
Jan 16, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Setting jx200 to manual and have ansewring machine connected.
I normaly set all my fax machines on fax only,but I change my incomming ring count to more than 7 rings,but less than 11 rings,this allow you to have time to answer you call before it goes to fax.But you can set it for manual.
Press the "receive mode/resolution button untill it show on the display-manual,fax only or ansering.
Yes you can use the fax and answering machine when you are out of the office.
Set you answering machine to pick up after one ring,the message must not be longer than 15 sec.
If you leave set your receive mode to answering mode
Hope this will help you
Jan 08, 2009 | Canon FAX-JX200
Fax won't receive
check is your fax properly set,is on automatic or manual.I you receiving fax manualy you must pick up the phone then press start buton.that is the problem in most.
Feb 18, 2008 | Canon CFX-L4000 Plain Paper Laser Fax
Received fax's are not printing. Unit prints confermations and is working as a printer but recieved fax's just park in memory and will not print.
TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING. IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING, IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY. HAPPY FAXING OMNIPRESENT
Jul 28, 2006 | Samsung SF-560 Plain Paper Laser Fax
Canon L220 Plain Paper Laser Fax Logo
229 people viewed this question
old marine
old marine
