Question about GE Deluxe AGM12AB Air Conditioner
I have a 2005 Dodge ram, the air conditioner light started blinking and the air coming out of the vents became warm. After playing with the knobs several times the air became cold again but the light is still blinking? Any suggestions?
2 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: freezer is cold, but the fridge is warm. where
The fan in the freezer is probably not running. It's in the freezer on the back wall. You should be able to hear it running when the compressor is running. It will stop with the door open so you'll have to hold the door switch down.
OR
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
This diagram shows your evaporator and fan but the location is not clear. The evaporator is near the bottom behind the rear cover inside the freezer and the fan is usually at the top where the vent is.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=210321&diagram_id=22357829#d22357829
Posted on Nov 04, 2010
2003 dodge ram 4.7 heat/air trouble
if you have a tilt wheel,you may have a broken wire,replace the whole colunmb also,,,,,,,,,,,,,(pics)look for 2 and 7 ,,blend door actuators,,
May 07, 2015 | 2003 Dodge Ram Pickup 1500
07 dodge charger air conditioner will not work properly
SOUNDS LIKE THE SWITCH HAS GONE BAD. YOU CAN GO ON LINE TO EBAY AND MOST LIKELY FIND A REPLACEMENT. I HAD TO REPLACE MINE ON MY 2008 SEBRING.
May 06, 2014 | Cars & Trucks
Is there anyway to tell if recirc door is blocking vent b4 purchasing one?
sounds like either the air condition pump or the belt on the pump is going out
Mar 20, 2013 | 2005 Dodge Ram 1500
Air Conditioner fan not blowing
You may need to replace the reostat in the heater box. Do you have the hi speed only? Only have off and I, then it is definitely that switch in your box. You can easily replace it.
Nov 14, 2017 | 2006 Dodge Ram 2500
I am trying to figure out which fuse operates the back lights for the Air Conditioner control knobs on a 2005 Dodge Ram 1500. (4.7 engine)
If the dash lights are working and the other controls light up then your problem is the bulbs need replacing, remove the controls and in the rear you will see where the bulbs go,remove the small socket and install new bulb. hope this helps.
Oct 27, 2010 | Dodge Ram 1500 Cars & Trucks
01 dodge 2500 v8. Air conditioner started out strong, blowing cold air..temporarily would start blowing warm and then back to ice cold...Noticed when stopping and turning corners a hissing noise coming...
Hi. Have your car aircon evaporator cleaned. Check also the drain hose. All water should go out of the car through the drain hose. There might be something clogging up the hose that is why water will run out the floor and that causes also the aircon to work intermittently.
Have a good one!
Aug 13, 2010 | 2001 Dodge Ram 2500 Truck
Started out with cold air coming out the vents
I'm no 'expert' but it sounds like possibly 2 different problems. Your heat comes from warm/hot coolant circulating through the heater core, and the fan blowing air through/over it. If your thermostat is not opening the coolant won't circulate. Thermostat is a not too difficult or costly starting place. No air flow leads me to think you have a blower motor issue, perhaps start with the fuse. Hope this helps.
Dec 04, 2009 | 2001 Dodge Ram 1500 Truck 2WD
2005 dodge grand caravan heat not working. one vent blows warm air and the others just blow reg. air. also ac isnt blowing cold air. freon put in worked for a month now not working.
There is a recall that has something to do with the air/heat system in 2005 Dodge Grand caravans. Recall F01. Here is a link. I had mine done two weeks ago, cost me nothing. My air conditioner was overheating.
Aug 07, 2009 | 2005 Dodge Caravan
With ac running cold, blows warm when truck is stopped
I have a dodge 2007 ram 1500...most likely its an RPM issue. The compressor requires a certain RPM to maintain the required pressurized vapor.
Apr 29, 2009 | Heating & Cooling
GE Deluxe AGM12AB Air Conditioner Logo
279 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
