I need to know how to load and Print envelopes for invitations. Please help!
PRINTING ENVELOPES ON CANON MP620: It's simple, and you simply do two things:
1. In your word processing software, select 'letter size envelope' as your document size.
2. In the Canon MP 620 there is an auxiliary paper feeder at the rear of the printer -- open it. WHEN you have paper in it, it functions as the default paper feeder (instead of the internal paper trays). So place the envelope right-side-up in the feeder & adjust the gray holders to the envelope's size. Then click Print.
Hi. since many printers are different in their functions from one another, without being in front of the machine it is somewhat hard to discribe the process on your particular machine. I have found a couple of links for you, and it may help solve your problem. This is all assuming you do not have the original documentation for your printer. First is the getting started manual in pdf format (you need the free adobe acrobat reader for this, which can be obtained by doing a search on "acrobat reader" on your favorite search engine) for your particular machine here: javascript:wssPopupWindow('http://gdlp01.c-wss.com/gds/8/0300001548/02/MP620_GS_EN-US_V1.pdf',%20'MP620_GS_EN-US_V1.pdf') The next is an onscreen manual for your computer, which you would install as a program on your computer for very detailed help for your particular machine. It is here: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=17406#DownloadDetailAct Give these a try, and it should tell you everything you need to know in order to print your envelopes. Hope this helps.
GO on printing option. there u can adjust paper size and quality set it. and outer side of printer's paper fedder adjust according to your envelopes size. thanks
