Question about Stanley Tools & Hardware - Others
Bostich Framing Nailer
My Bostitch N88RH will fire a nail properly, but will not re-load. I have to disconnect and reconnect the air supply to allow it to fire again. I've purchased an O-ring rebuild kit. Does anyone have any suggestions on where to look for the obvious problem?
Matt
  • 285 Answers
Try getting a can of air gun lubricant from a good hardware or specialist store that sells nail guns. Often the feed mechanism just gets stuck and needs a bit of spray lube to get move again.
Posted on Jun 20, 2009
My bostitch N88RH is not firing nails
May occur when headvalve or driver is stuck (will usually make a pop or click when tigger is depressed), or tigger valve has failed or safety not actually touching trigger firing pin. Easy test, remove nails, remove trigger by pushing out 3mm roll pin or bolt to expose the firing pin. Pull back nail feeder and place the nose against piece of wood ~ depress trigger with very quick motion with finger. If it fires, reinstall trigger and adjust safety foot so that the firing pin is pushed all the way in. If does not fire, replace trigger valve (usually tva6) or remove trigger valve and replace the 3 orings on the inner plunger. If you hear a pop or click when you do test above, remove head and lube the headvalve orings with white grease or silicone paste.
Nov 17, 2011 | Stanley Bostitch N88rh Framing Nailer...
I have a bostitch model #N88RH. It won't drive nails all the way down. How do I adjust it?
Using the web address below for reference, item number 46 is a small slider button on the nose of your gun. Push in on the slider and adjust the safety nose up into the gun for setting the nail deeper into the work. Good luck on your projects
http://www.ereplacementparts.com/bostitch-n88rh-pneumatic-stick-nailer-parts-c-29443_29458_29650.html
Jun 03, 2011 | Stanley Bostitch N88rh Framing Nailer...
My N88rh shoots two nails at a time
N88rh uses a full round head plastic collated nails which are spaced apart enough that the driver cannot hit two nails at once. If your are using other nails that fit into your magazine that are closer together you may in fact drive two nails at once. If, however you are using the correct nail and the nailer shoots twice, then you probable have a very sensitive firing valve. You could change the TVA6 valve or change the actual trigger. To overcome this problem of double firing and you do not want to try changing the firing valve, you need to change the trigger to sequential type instead of bump fire type. This trigger is usually white and will only permit one nail to be fired. Check www.toolpartsdirect.com or bostitch.com for parts. Good holiday
Nov 28, 2010 | Stanley Bostitch N88rh Framing Nailer...
Fires 2 nails
Nail feeder pawl is miss alinged or wrong degree of nails being used!
Jul 23, 2010 | Stanley Bostitch N88rh Framing Nailer...
Nail is jammed ln a bostich n88rh how do you clear the barrel
I have solved my problem, I am going to dump this bostich even though it is a brand new product that has not been used in over a year, has only fired approxamately a dozen nails and go with another product that has an honest customer relation rep that does not charge you for information on their products.
I will also remember my experiance with this company and there products
Yours truly
Charles Marleau
Jul 09, 2009 | Stanley Bostitch N88rh Framing Nailer...
Tools & Hardware - Others Logo
106 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
JOHN LAPIER
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
