Hi our Transonic DVD player works perfectly but no sound comes out its not muted or anything tried all different av cords what could be the problem and how do I fix it?
SOURCE: No picture but has sound
To fix this eject the disc and hit the stop button for 5 seconds to reset the unit.
Posted on Dec 31, 2006
SOURCE: acoustic solutions dvd-222 portable player
same problem here no idea
Posted on Apr 29, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Need a replacement AV Cord
Radio Shack carries those types of cables.
Posted on Jul 13, 2008
  • 68 Answers
SOURCE: colby dvd -215 i switched vidio options and cannot see it can it be reset?
try this
*********RESET THE DVD PLAYER BACK TO THE DEFAULT SETTING*********
Make sure you do not have a disk in the tray. Using the DVD player remote control:
1) Press the "Setup" button.
2) On the "Right" arrow, press it three times and then press the "Play" button.
3) On the "Down" arrow, press it two times.
4) On the "Right" arrow, press it once, and then press the "Play" button.
5) Press the Setup button.
*The default setting will take affect as soon as you press the setup button (step 5).
Posted on Oct 02, 2008
ve3wtj
  • 147 Answers
SOURCE: Have picture, no sound
I've had this trouble too. Not sure how to fix it, but I've found a work-around:
Remove DVD.
Insert Audio CD.
Wait for audio to play.
Remove audio CD.
Reinsert DVD.
Sound should work again.
If you power off the unit, you may have to try this procedure again.
Posted on Oct 07, 2008
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
Dvd screen comes up on TV but dvd player says "disc error".
unplug the pwr cord from dvd for 5-10 min..plug back into outlet..make sure the av cable is connected white-white yellow-yellow red-red...now press play on the dvd
feel free to rate help
Jul 04, 2010 | Toshiba SD-2800 DVD Player
Hi I have this DVD port.player ProlineDVDP620
check the AV cord properly maybe it is right way you insert them , they have different co lours check the one that need to go for red in the tv and at the back of the dvd and the red for red at back of the tv and the dvd .
May 31, 2010 | Televison & Video
No sound on dvd disc playback via av
check if muted set. try also new rca cord
Jan 01, 2010 | Televison & Video
Hi- my 74cm TV- when i connect the dvd player and switch to AV- there is no picture only sound. But the dvd player works perfect on my other TV- what could be the problem??
If your DVD with same AV cord working fine on another TV then its a problem of cold soldering of video pin that needs touch up soldering. And tv work fine again.
Thanks for using fixya.
Nov 06, 2009 | Sansui DTV2760 27" TV
Insignia pd-1020
Go to Radio Shack.  You're going to need an IPod dock that has video playback capability, an av cable with the three av outputs.  Then you will need a mini jack cable that plugs into the video and another mini jack stereo cable for the sound.  You made need a coupler as well.
They only make home cables for Ipod systems.  The other wires will convert the home cables for portable DVD use.
Sep 17, 2008 | Insignia I-PD1020
Dvd player in van no longer has sound
hi i have a toyota van and i have dvd play in it...the dvd player sound works with the radio station but i for got the channel...so cnu help what channel is it spousd to be....write back plzzz
thnks
Jul 18, 2008 | Eiger Vision AV-1301 Car Monitor
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
