Question about KitchenAid KESC307 Electric Kitchen Range
Bake button broken on KESC307HBS4
The bake button seems to be broken on our KESC307HBS4. Everything else on the oven works relatively well. Sometimes we can get the bake button to work if we repetitively press it 100 times or more in different places on the touch pad, but most times we give up and use convection.
Is there a quick fix for this?
    President:
  • KitchenAid Master
  • 2,651 Answers
Other then cleaning the glass, and making sure your finger is alas oclean and dry, no reall easy fix other then replacement od the console,i gues if you wante dto try you could llift teh console( 2 screws on either side, nad 4 screes acroos bottom) this will allow you to tilt the console back, and from there i would disconnect the ribbon connector, connecting the glass to the circuit board and try cleaning the end of cable with an eraser form a pencil..( sometimes,works, limited success but worth a try! diconnect power first LIVE WIRES!!!!!!!!!!!!!!!
Posted on Jun 15, 2009
WHEN YOU TURN OVEN ON AND PUSH BAKE BUTTON AT 400 AND PUSH THE BAKE BUTTON AGAIN THE PANEL WILL SHOW 400 AND BEEP AS IF READY BUT OVEN NEVER HEATS UP. SOMETIMES THE DISPLAY WILL RANDOMLY FLASH DATE. ...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Maytag MERH865RAB Electric Range
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
ALL BUTTONS ARE WORKING, BUT SUDDENLY MY "BAKE" BUTTON QUIT. EVERYTHING ELSE WORKING.
I would Have it Checked. It Sounds like a Transistor or the Circuit Board Needs to be Replaced.
May 12, 2009 | Ovens
GE JTP70 convection oven - defaults to self-cleaning mode
I believe your control board is going bad. This isn't that expensive. However, get one from a GE parts store. They tend to be better priced.
Jan 29, 2009 | GE JTP70 Electric Single Oven
TAPPAN gas range model 30-3991-00/03 oven won't work.
the button your holding is the switch that tells the board that the consumer whats to bake.so if holding the switch causes that message to work[or oven to heat] and letting go of that button ,then no work .its that button ,but its all part of the board .just that part of its funktion is broken.,if it was lets say your oven ignitor or oven gas safty valve ,the board/oven control[the one with the button]would continue to try after you have selected bake [pushed button]or would give error code.hope that helps you. God bless you , tom
Jan 05, 2009 | Tappan Kitchen Ranges
Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Sep 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
161 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
