Where does the fuse go in my fender Hot Rod Deville 212 amp?
    Champion:
  • 211 Answers
You can find the fuse right of the powercord inlet.
Regards,
Gerard
Posted on Jun 16, 2009
Fender Hot Rod Deville 212 sounds ok then LOUD HUM
On mine, the guitar input jacks get tarnished and causes all kind of interference and noise. Take a Q-Tip soaked with WD-40, run in down into the jack and brush up and down. Don't overlook the filter caps as they are a common cause of noise. You need a capacitor checker (the older tube type) to thourghly check those out.
Sep 05, 2014 | Fender Musical Instruments Corporation...
Is there a way to make the sound of the reverb on my deville 2-12 sound better ?
modding the reverb takes some electronics experience...if you know where the reverb circuit is. all you can really do is change the input caps that make the tone bright or dull... larger uf for dull... lower cap values for bright... it's in the signal circuits... dont mess with power caps. The schematic shows op amp into the tank and out of the tank to another op amp...Output of the tank to opamp.. Id double that input cap ( 330 pf ) to see if you get more response into the opamp... then look at the circuit C17-C18/R33-R34 894cf4a0-46f7-4f21-9667-be620f05b31d.png
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Jun 06, 2012 | Fender R) Hot Rod DeVille III 212 Guitar...
Fender hot rod deville 212 111. On the 2nd and 3rd distortion chanels the noise coming out of the speaker is very loud. Is this normal? Hard to play through the noise.
Hi. If the volume and drive levels are considerably low but you still hear a noise, you may want to consider trying a different guitar cable. The noise may be coming from a ground loop which is being amplified and overdriven by the amp itseld. I hope this helps. :-)
May 29, 2011 | Fender Musical Instruments Corporation...
How do I replace a fender 2 x 2 deville pilot light? CL
You unscrew the plastic dome over the bulb. The bukb is a bayonet base. Push in and turn... probably counterclockwise and extract the bulb. Replace by reversing the process.
Use T47 or #47 (6 volt) lamp... available at Radio SHack and other places.
Jan 23, 2011 | Fender R) Hot Rod DeVille III 212 Guitar...
My Fender Blues Deville (2-12)amp after heating up will cut out totally and then pop back in..thanks Mike
IF you can get the thing to fail while out of the case, the quickest way to find a thermal failure is with circuit cooler spray. Unless you are adept at electronics, this is probably NOT a DIY project.
The nature of your symptoms SUGGEST probably a bad solder joint or a cracked circuit board.
OFTEN the bad solder is around HEAVY components or POTENTIOMETER leads, especially where they support the board by those leads (dumb!)
A trained eye can spot bad soldering around a lead... you look for a tiny gray line around the lead part way up the meniscus of the solder fillet... see one, reheat the joint with a soldering iron.
Nov 12, 2010 | Fender Hot Rod Deville 212 Cab Cover
Hot Rod Deville, reverb squeal...
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
Aug 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
No volume.
Are the tubes bad? Do they light up? Check the tubes and install replacements if necessary. If it's a preamp tube that went bad, just replace that one tube. If a power tube went bad then replace the set of power tubes. Be sure to get a matched set when replacing power tubes, and to bias them.
Aug 08, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deville 212 - popped and died
This may sound stupid, but did you check the fuse?
Apr 22, 2009 | Fender Hot Rod Deluxe Guitar Combo...
333 people viewed this question
 Grubhead
Grubhead
