FixYa.com
Tags:
Toshiba Satellite Pro 6000 and 6100 14.1 LCD Display LQ141X1LH53  CD-ROM Drive
Hdd password (by 8 users)
posted by mitsubishi on Oct 30, 2007
toshiba model ps610c-029zdp
when i boot the main screen ask's me for a HDD password,  I never make it to Windows
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Comment by burdenk, posted on Jul 15, 2008
having problems with the built in HDD1 user password
Comment by johncena2k4, posted on Jul 08, 2008
toshiba satellite Model a135-s45407 hdd1 user password problem
Comment by Guest, posted on May 27, 2008
When I turn on my Toshiba Satellite I get a prompt to enter my HDD1 user password which I have forgotten. Please help
Comment by ibrmoh, posted on May 15, 2008
when i turn on my computer (laptop), a message displays: please enter the built in hdd1 password.
please help for solving this problem
Comment by THADDEUS POR, posted on May 15, 2008
MY TOSHIBA NOTEBOOK CONTINUES TO SAY ENTER PRI.HDD PASSWORD
Best Solution
posted on Nov 09, 2007
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Use your tooth brush to rub inside the Machine Heads.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 02, 2007
Thanks for Trying (70)
diazphi
Rank:Wiz Wiz
Rating: 79%, 206 votes
What is HDD Password? All hard disk drives have the possibility to set a hardware password, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. When you set a password on your notebook, the drive becomes locked as well. XBox gaming consoles and some desktop computers can also lock hard disk drives. This is usually called "HDD password" or "ATA password".
If you forget the original HDD password, there is no way of restoring it by generic system tools. HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow to remove an unknown HDD password and make hard drive usable again.
I have a software enable to reset the password security on your harddriver but you need to pay my professional charge. If sound interested please email diazphi@gmail.com.
Please rate me solved if you like my solution.
Best regards,
Philip
Solution #3
posted on Jun 13, 2008
Not Rated (0)
GiGa-ByTe
Rating: 0%, 0 votes
I believe The removal and replacement of the HDD is the only way
Solution #4
posted on Apr 29, 2008
Not Rated (0)
razabhai
Rating: 0%, 0 votes
There is no solution at all to decrypt password of your beloved hard drive.
Solution #5
posted on Feb 26, 2008
Not Rated (0)
Commonsensia
Rating: 83%, 7 votes
If you change to a new Hard drive then you will be fine. But make sure you aren't confusing hard drive password and Bios password.
I have not seen but one Hard Drive passworded in 15 years of fooling with PCs.
Lastly, since it would still be stored most likely on the drive you could try one of the stronger drive managers and redo the Master Boot Record. Loosing all data on it at the time, but possibly regaining the drive. Nothing to loose at this point.
Solution #6
posted on Feb 25, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
So What Happens if a change the hard disk
Can you Help with these CD ROM Drives problems?
CD ROM Drives
HP Pavilion Slimline s7400n PC
I purchased this PC from... Answer This...
Toshiba Satellite Pro 6000 and 6100 14.1 LCD...
Blue Vertical Line on my laptop...
Since downloading pictures from... Answer This...
hard drive password solution
I have 40 g.b hard drive of my... Answer This...
Toshiba satelite
Hi am not able to download... Answer This...
my dvd and video card
it is saying that it has a... Answer This...
7 Other Users Have The Same Problem - Continued
Comment by Roy dsouza, posted on Apr 19, 2008
hi! m Roy and m using a toshiba tecra A8/satellite pro A120, i could easily lock the hdd but cannot unlock it nor i can rename. plz sugesst some solution.
Comment by dargio, posted on Mar 02, 2008
i have tecra m1 and when i want to starrt the os it shows a mesage HDD pasword
Repair Service
Find CD ROM Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
