Question about HTC Touch HD Smartphone
Screen lite dims in 5 sec.s
I've tried several things, nothing works. I start reading a page an screen goes dim, i have to keep touching it. Help
  • lquig Jun 19, 2009
    Thanks fo trying. I've set that. Lite goes dim, not off in 5 sec.s I set it for 3 min.s to go off.
  • 14 Answers
It is because of the factory settings for the backlight. But you can change this yourself.
The simplest way to do this is:
1. Go to "All settings".
2. Choose "system".
3. Tap on "Power". The icon for this is a battery symbol.
4. Choose "Advanced".
5. Here you can define your choices, as to how long you want the backlight on (from 10 sec to 5 min).
Hope this helps.
Regards
Posted on Jun 19, 2009
HP Envy display stays dimmed after waking from sleep mode
well dim is complex on laptops
first off take the battery out of the LT.
dim now.?
is DIM IN BIOS screens?
or only under windows...????
some HP like mine have CAMERA ambient light dimmer
so if that is on, it dims when its indoors and is bright out doors
to prove this, turn that off in the device manager.
see that here
power saver modes are complex
tell me what BIOS F1 info page does, dim or not dim. first
does it DIM MAIN BATTERY OUT>>> ?????? means on AC power/
http://www.pcdied.com/sleep-or-dim.html
Jul 20, 2017 | HP Computers & Internet
Touch screen not working? any other option is there?
You can order the screen as a replacment if you like your machine. If it is lit up and or you push and nothing happens it's time for a new screen. In most cases the screen goes dim and you can't read it. I have replace a few of these.
Jun 09, 2010 | Canon imageRUNNER 400S Copier
The speedmeter lites up very dim
there are several small light bulbs inside the instrument cluster. as they burn out. it will look dim in places. remove the cluster to access the bulbs.
Apr 02, 2009 | 1991 Lincoln Continental
The screen is dim and goes black everytime i touch the wheel
Here is the link to the user manual - in the Settings Menu, there is a way to change the frequency with which it dims:
http://www.sandisk.com/Assets/File/pdf/guides/e200/e200_userguide_en.pdf
Mar 24, 2009 | SanDisk Sansa e200 MP3 Player
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
LCD goes dim within 1-2 minutes
You could have a bad "inverter" or flourescent backlight tube, or a problem in your power supply.The only way to isolate the problem is to check each component in sequence.If your hard disk and DVD / CD drive are still working when your screen goes dark, then I'd say it's the "inverter". You'll have to take it to a repair shop.
flipbooks
Jan 20, 2008 | HP Pavilion dv6000z Notebook
Dim bottom screen on DS Lite
There should be either a button or a setting to adjust the lighting, try doing that.
Dec 01, 2007 | Nintendo DS Lite Console
Lights on bottom screen don't light
i dont think it is a problem i think it just does it to save energy
Oct 03, 2007 | Nintendo DS Lite Console
Red CRT is dim....
Yes I did. You will need to get a service manual for this TV set to trace the voltage coming from the sweep power supply. If this is a problem that is new after you replaced the convergenbce4 board, you for sure have a broken wire or connection somewhere in the set. Have seen this happen may many times after a novice repairs a TV set. Good Luck
Sep 06, 2007 | Samsung HCL4715W 47" Rear Projection...
HTC Touch HD Smartphone Logo
74 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
