Question about Estate TEDS740JQ Electric Dryer
Dryer will not shut off or heat up
I am not sure why my dryer will continue to run while on the timer & the dryer is not heating up to dry my clothes. Is there something I can do to correct this problem?
    Sergeant:
  • 222 Answers
The problems are related. The timer advances when the thermostats sense that heat is being applied to the air in the dryer. With no heat, the sensors do not allow the time to advance.
You did not mention... Is your dryer gas or electric? If Electric, the most likely culprit is a burned out heating element or a faulty internal heat-sensing thermostat. Burned wires or a defective motor switch are less common factors.
If it's a gas dryer, suspect the glow sensor (could be something as simple as lint covering it), temperature control thermostats, or the heater switch on the motor.
Posted on Jun 15, 2009
Whirlpool dryer, when set for auto dry low heat, or timed heat, then dryer runs fine, when set on auto dry high heat timer doesn't move, what could be the problem? does it have to be the timer?
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Feb 10, 2015 | Whirlpool Dryers
What is wrong with my gas dryer ? no heat and wn't shut off.
FIRST OFF IN THE AUTO DRY MODE THE DRYER USES THE MOISTER SENSOR AND AS LONG AS THE MOISTER SENSOR DOES NOT DETECT HEAT OR DRIED CLOTHES IT WILL CONTINUE TO RUN FOREVER.
NEXT AS FOR UR NO HEAT:
Aug 09, 2014 | Kenmore Dryers
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 | Dryers
I have a Kenmore 70 series dryer. The dryer runs but will not heat. I have had all fuses, heating element, and thermostats tested but it still will not heat. Any thoughts?
Notes: Check all components on dryer with at least one wire removed and all have continuity or 0 ohms.
Have checked circuit breaker and know for sure 240 volts is going in machine (motor runs on 120v heater needs 240v).
Ok the next thing to do is find the heavy red wire going into the timer. Remove the red wire from the timer. Set the timer on heat dry cycle (power if off) Chck from that leg of the timer to any other leg on the timer for continuity. or 0 ohms. if you get nada then the contacts inside the timer is bad. My video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 10, 2013 | Whirlpool GEQ9800L Electric Dryer
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
WED5321SQ0 dryer doesn't heat or shut off once it's running
well if ran all night you maybe be running a even heat or auto dry cycle. i would first try on a timed dry see if heat then. if does heat (which probably wont) you will be need to replace either the sensor or board that controls the auto dry. or a very small chance that the timers bad. most likely you have a bad heating element. if the machine doesnt heat on the timed dry, then you need to check continuity on the heat fuse(located on heat element housing). if good then check continuity on heat element. i would say you have a bad element or heat fuse.
Aug 01, 2010 | Whirlpool Dryers
My dryer is not shutting off/no heat
The cycle timer motor is bad. Easily replaced and you can do it yourself. Does the dryer normally heat when drying?
Sep 14, 2009 | Zanussi TD4212W Electric Dryer
Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Sep 15, 2008 | Dryers
Dryer heats &revolves but clothes do not dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
if this helps please vote me a fix ya
Jul 15, 2008 | Maytag Dryers
Estate TEDS740JQ Electric Dryer Logo
158 people viewed this question
Top Estate Dryers Experts
Tim Whalen
Mike
John Tripp
John Tripp
Are you an Estate Dryer Expert? Answer questions, earn points and help others
