No OSD CRT TV with no on screen display but led light.
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Check and replace the damaged component/s at its horizontal scan output section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 27, 2014
Hi, my screen has gone blank, every thing works but I have a blank screen, I cannot see viera either, I have tried unplugging and rep lugging the tv and hdmi cables. I do have sound though. What ca I
Hi Pascal,
Blank screen and you can not see even the on screen display ( osd ) means the back lights ( cfl or led ) are not working. Please consult someone qualified to handle your set.Unfortunately there is nothing you can do yourself. Good luck.
Sep 10, 2014 | Televison & Video
Tip
Diagnosing video problems on TVs and monitors
The first thing to always check is the MENU (osd - on screen display)
Push menu or display on your tv or monitor
- if the menu is clear, the problem is in the early stages of video or outside your device (could be the source (dvd, cablebox) or input connections
- if the menu is distorted, the problem is definitely a malfunction with your device the osd is generated from (tv menu distorted = 100% tv is problem)
* you can also use other OSD signals to troubleshoot - if the volume bar or display info (input label, info bar) is clear, problems are earlier in the circuitry or outside the device. don't be fooled by translucent menus or cablebox menus.
** osd is inserted in the picture in the later stages of video processing. if your osd is distored, suspect the circuitry after the video switch. this could be a bad LVDS cable, TCON or Logic board, or even a bad lcd panel, plasma panel, crt.
on May 21, 2010 | Televison & Video
Hello, I have a Sony Bravia 42 inch LCD colour TV Model number KDL S40A 12 U. When I turned my TV on the other day the amber light on the lower display panel was flashing against a TV screen icon with a...
Relay clicking (chatter) is a sign that the Capacitors on your PSB are failing. Since you still haveOSD-On Screen display you can wait till the TV shows NO OSD and a blinking fault LED before recaping. Now the Cross sounds like convergence. Hope this helps. If and when it gets both legs through the door
Jun 29, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How to remove the menu display off the screen memorex tv
you can use your remote control to remove the menu display,there is a button there,labeled OSD or DISPLAY just press the button to remove the display..
tnx please vote for my help..
Jun 04, 2010 | Memorex MT1134 13" TV
700e Lg crt monitor problam power on eht on but not display
The normal crt monitor have a demo display when you unplug the vga cable to PC like this image below.. fd6b6b9.jpg
Note:
If the crt monitor green LED light steady and heater beam have light, the horinzontal and High Voltage supplied to tube is completely good. If you encountered this problem just focus on video section of crt monitor. But before you start... find the flyback transformer behind this they have two controls screen & focus. After you found it plugin the monitor use plastic precision or small screw philip driver for safety to high voltage at horizontal area choose screen control rotate it to clockwise direction follow this....
5b5166c.jpg If the display responses or from dim to lighter 100% you have a problem to ABL find this at the bottom of horinzontal section near at flyback transformer pins trace the line of ABL for dried solder, open resistor if nothing happen find the Video IC at chroma section and replace it. follow this...
3c6e89c.jpg For LG & Redfox you found LM1269NA Visit this site for seaching semiconductor matches www.alldatasheet.com Good luck.
Check this site for searching semiconductor
Aug 12, 2009 | LG Studioworks 700S 17" CRT Monitor
50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Dec 19, 2008 | Philips BDS 4611 46 in. Plasma Television
Help now!!
Press Display button once on Remote Control, OSD (on screen display) will disappear.
Aug 12, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
ViewSonic E70f 17" CRT pincushion changed itsself continously
Press the [1] key & hold it for 10 seconds / till OSD Unlock appears on the screen. When OSD unlock appears on the screen , release [1 ] & press [1] or [2] key. This will unlock the OSD.
May 22, 2008 | ViewSonic E70f 17" CRT Monitor
Blue screen
Try pressing the "Input" button a click at a time and see if the OSD (On Screen Display) cycles through Ant A, ANT B, AV1 and so on...
Bill
Nov 11, 2007 | Mitsubishi WS-73615 73" TV
Dark screen on all inputs, OSD clear
luminance is missing or the brightness. try to inspect the board at the back of the CRT see if there is an open resistor
Jan 14, 2007 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
