Question about Samsung SGH-D900 Cellular Phone
No power i used my battery on other phone but its usable! pls help me pls! no screen
    President:
  • 1,952 Answers
Charging pin at the bottom of the phone problem
Posted on Jun 15, 2009
I'm having problems with my android discovery v8 mobile phone. At some times the phone won't stop vibrating and the touch screen won't work and is opening and closing apps.
-Try backing up your phone and restoring it.
-If that does not work, use it until your phone battery life is completely drained. Next charge it to a usable percentage and attempt to use your phone again.
-Sometimes simply turning off and powering on your phone can help resolve glitches in the software.
You can try the second method or third method first if you like.
Aug 07, 2015 | Android Cell Phones
I HAVE A IBM THINKPAD A22M LAPTOP WHEN IT BOOTS IT HAS A ERROR CODE OF 0271 CHECK DATE AND TIME SETTINGS AND BLANK SCREEN APPEARS AND A LOCK ICON APPEARS.... IT PROMPTS FOR A PASSWORD I DONT KNOW THE...
You will most likely have to remove the backup battery temporarily to allow the CMOS to clear the password lock.
The instructions for removing the CMOS battery are located here.
Be sure to disconnect the power cord and remove the standard battery when performing this work.
Be very careful to follow the directions exactly as shown.
You may have to leave the CMOS battery removed for a number of hours in order to clear the CMOS password.
Dec 29, 2010 | IBM ThinkPad A22m 2628 Notebook
My screen shows a picture of a battery with an x through it heyjudejude@msn.com
Hi this symbol is showed because of two reasons
1)The phone battery is dead.(It is not usable more,you have to replace it for soon,)
2)Your using a battery that is for different model....
Take the battery out and clean the gold terminals on the battery and phone with a pencil eraser.By doing this it cleaned the collected junk off these terminals so the battery and phone could make a better connection!
Still the problem persist the phone battery is dead mainly.plz go for replacement soon.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Jul 28, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
I have nokia 3230 when i switch on, only gray screen appears then after that it turns to black and white horizontal line..i tried to reformat my phone using *,3 and green button then switch on but it...
The code for formatting the nokia phones is *#7370#. Have you tried it. And before you do that press the power switch enough to give you a list of profiles. Select General profile. and then format your phone.
Aug 02, 2009 | Nokia 3230 Cellular Phone
K800i cannot open when im trying to open!!some people help me!!
hi thanks for using fixya!!
Is the problem is you cannot turn on your phone? try to remove the battery and install the battery back again, they try to turn on the power, if doesn't open, try to recharge it, if the recharging is not responding, perhaps the problem is with your battery or charger.
I suggest that you bring your phone to the service center.
If you need further assistance, let me know.
pls rate me positively! thanks!
Apr 03, 2009 | Sony Ericsson K800i Cellular Phone
Is my lg kc550 usable in Florida usa?
yes u can after you have unlocked its networkto other countries
pls rate me
thankyou
Feb 14, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Kyocera oyster screen blank
I hope that when you say blank it means partially lit, with a kind of background, but no image.
This solution is not for an abused phone, as it does not seem to be mechanical, or due to a loose connection. It rather seems like a firmware failure. It will not make your phone usable, instead, it will enable you to retrieve your saved numbers. Once these cheap things start failing they become disposable.
Tried removing battery: No cigar. Tried opening it carefully (under 90 degrees) still no solution.
Here's what worked for me. Phone off, either by powering it down of by having removed the battery.
Get a toothpick, and with the phone CLOSED in the off position, pinch the power-on button and let the phone come on closed. It may not work the very first time, but you should be patient. Once it comes on, you can do just about anything with it until you power it down.
**Make sure you have charged your battery prior to this, since will be spending some time retrieving your numbers**
Good Luck!
Aug 28, 2008 | Kyocera Oystr KX9 Cellular Phone
Help
my phone LG KG 800 is charging is not stored i am charging full but only two hours back up getting battery is new pls how to rectify this problem pls help any one
Azeem
cell : +91-9985980830
Aug 28, 2008 | LG KG800 Cellular Phone
UPS
Depending on your location, phone line voltages are not suitable to charge the battery nor supply the current requirement of a UPS.
A car battery would work as long as the voltage is identical to the UPS' original battery. It is just the ampere/hour rating that only increased and therefore the usable time likewise increased.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 16, 2008 | Belkin (F6C800-UNV-PL) UPS System
PLEASE HELP;; phone was fine and i was just typing on it, but then it suddenly turned off...
There are two possible causes for this problem. Either your operating system is corrupted, or your battery is bad.
You can get the operating system reinstalled by taking the phone to a Verizon store -- this will probably delete all the saved data on the phone, but it will become usable again.
The other possibility is that the battery is worn out and doesn't have the juice to power up the phone any more; either way you will probably have to take it to a Verizon store to get it fixed.
Feb 29, 2008 | LG enV VX9900 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
