Question about Bruder forklift by
Fuel regulator leaking on front hwhere the two arrows point to two screws what is that from and is the regulator bad?
Forklift runs but when I shut off the engine is when the regulator leaks
    New Friend:
That is test port just tighten plug
Posted on Jul 21, 2014
Why does my Saturn smell like gas after being started and shut off?
please go to this site, it sounds like you have a bad fuel pressure regulator.--- http://www.doityourself.com/stry/7-symptoms-of-a-bad-fuel-pressure-regulator Good-Day! But make sure there is no fuel leaks anywhere under car, this is dangerous to have a fuel leak. Good-Day!
Jul 27, 2014 | Saturn SL Cars & Trucks
My car burns gas very fast. where is the 02 sensor located? do i need a calib cabreter?
02 sensors are located in the exhaust the upstream ones are close to the engine in the rear exhaust manifold (for 6 cylinders) and at the front exhaust (for 4 cylinder). The downstream ones are behind the catalytic converter. Check to make sure the fuel pressure regulator on the to of the engine isn't leaking. Replace the air and fuel filter could be plugged. Check the coolant level in both the rad and the reservoir they are notorious for intake manifold and head gasket leaks for 6 cylinders. There aren't many calibration updates for this vehicle relating to fuel consumption.
Jan 30, 2011 | 2000 Oldsmobile Alero
I have changed the fuel pump and the fuel filter and car started for a couple days now it isnt starting and it smells like it is flooding itself. could I have the fuel filter on wrong
check the fuel filter some where on fuel filter there should be a arrow or a in or out labled on it
if has arrow arrow should point to front of car
if has in or out IN should be tank side of filter
if that checks out ok check for a fuel leak
possible places for fuel leak would be fuel filter connections connections to tank or if lines are rusty they could be leaking
my best guess is you got a fuel leak somewhere
Jan 12, 2011 | 2000 Ford Contour
If i put a little gas in the carberator and fight with my blazer it will start and stay started, but if i leave it for awhile, it will turn over but not start. i cant figure out if it is electric or...
Get a fuel pressure gauge and connect it to the rail for the fuel injectors to read pressure.
If the pressure is too low, it might be a bad fuel pressure regulator or pump:
Fuel Pressure Regulator Removal & Installation 2.2L Engine To Remove:
  1. Relieve the pressure in the fuel system.
  2. Disconnect the negative battery cable.
  3. Disconnect the vacuum hose from the fuel pressure regulator.
  4. Remove the pressure regulator mounting screw.
  5. Remove the fuel pressure regulator assembly with O-ring. Inspect filter screen for contamination. If contaminated, remove and discard.
Fuel pressure regulator removal/installation (2.2L SFI engine) gm-05-22-619.gif
To Install:
  1. Apply clean engine oil to the new pressure regulator O-ring and install the O-ring on the regulator.
  2. Install the regulator on the fuel rail. Apply thread-locker to the mounting screw.
    • Tighten the screw to 106 lb in (12Nm).
  3. Connect the negative battery cable.
  4. Use the following procedure to pressurize the fuel system and check for leaks;
  5. Turn the ignition ON for 2 seconds.
  6. Turn the ignition OFF for 10 seconds.
  7. Turn the ignition switch back ON to run the fuel pump again and pressurize the fuel system.
  8. Check the fuel rail assembly for fuel leaks.
4.3L Engine RPO L35 To Remove:
4.3L (RPO L35) Fuel meter body assembly gm_trk_sil15_02-04_43_fuel_metr_body_assy.gif
  1. Before servicing the vehicle, refer to the Cautions and Warnings in the beginning of this section
  2. Remove or disconnect the following:
    • Upper intake manifold (See: Upper Intake Manifold)
    • Fuel pressure regulator retainer clip (M) and discard the clip
    • Regulator (N) from the housing by twisting and pulling the fuel pressure regulator (N) and using a shop towel to catch any spilled fuel
    • Regulator seal O-ring (R) and discard the O-ring seal
    • Regulator filter (Q) and discard the filter
    • Regulator seal O-ring (P) and discard the O-ring seal
    • Backup ring (O) and discard the ring
  3. Cover the fuel pressure regulator housing to prevent contamination from entering the fuel system
To Install:
  1. Lubricate the NEW O-ring seals with clean engine oil
  2. Assemble the following new parts to the fuel pressure regulator:
    • Backup ring (O)
  3. Install or connect the following:
    • Fuel pressure regulator with the vacuum tube pointing down
    • Upper manifold
  4. Test drive the vehicle to confirm the repairs
RPO LU3 To Remove:
4.3L (RPO LU3) Fuel meter body assembly gm_trk_sil15_02-04_43_rpolu3_fuel_metr_body_assy.gif
    • Fuel pressure regulator retainer clip (E)
    • Regulator (F) from the housing by twisting and pulling the fuel pressure regulator (F) while using a shop towel to catch any spilled fuel
    • Regulator seal O-ring (J) and discard the O-ring seal
    • Regulator filter (I) and discard the filter
    • Regulator seal O-ring (H) and discard the seal
    • Backup ring (G) and discard the backup ring
To Install:
  1. Lubricate the NEW O-ring seals with clean engine oil.
    • Backup ring (G)
    • Fuel pressure regulator (F) with the vacuum tube pointing down
Nov 04, 2010 | 2002 Chevrolet Blazer
2001 sebring conv 2.7 low fuel pressure where is the fuel pressure regulator location
hi, normally the FUEL PUMP, FUEL FILTER , FUEL REGULATOR at the back under the car near the front of the FUEL TANK. the FUEL FILTER HAS A ARROW and must go FROM THE TANK TO THE ENGINE. if you put it the WRONG WAY AROUND the car will NOT RUN PROPERLY. THE FUEL REGULATOR HAS A SPRING LOADED VALVE AND RETURN PIPE to the tank. THE FUEL PUMP HAS A ARROW TOO. from the tank to the engine. gerry
Sep 11, 2010 | 2001 Chrysler Sebring
I just replaced the fuel filter. now i can't get fuel to the carb. is there something i need to do to get the fuel in the lines.
If you noted the direction arrow on the fuel filter when you installed it and the arrow points toward the front of the vehicle, then the fuel pump will automatically bleed the air and deliver fuel to the motor. Just hold the pedal to the floor and try starting the car five or six times with the pedal all the way down. If it was just a bad or dirty fuel filter that was starving the engine that should work. If the engine was not starting before the fuel filter was replaced, you could have a defective fuel regulator leaking fuel or you may have a bad idle air control valve motor. When these fail you can smack it hard with a handle from a screwdriver or remove it and clean it and put it back in to "temporarily" get it working again. That will usually work for a few months anyway. The other possiblity is you have an air leak between the air filter box and the motor. Any leaks in the hoses between those locations can make a modern vehicle very hard to stop and will run a battery down pretty quick.
Jul 24, 2010 | 1993 Chevrolet Suburban
Where is fuel pressure regulatore located
For 2000 Chevrolet Truck Blazer 4WD 4.3L SFI 6cyl
If your engine is a 4.3L V-6 with CPI (central point injection) it is inside the upper intake manifold. The upper intake manifold is bolted on top of the normal intake manifold.
The throttle body is mounted on it and your fuel lines terminate into the center of this.
  1. Relieve the fuel system pressure.
  2. Remove the air cleaner outlet resonator.
  3. Disconnect the engine wiring harness from the retaining clips at the front of the engine.
  4. Disconnect the fuel pressure regulator vacuum line.
  5. Clean any dirt from the fuel pressure regulator and the surrounding area.
  6. Disconnect the fuel return pipe.
  7. Remove the fuel return pipe retainer.
  8. Remove the fuel pressure regulator retainer.
  9. Remove the fuel pressure regulator.
  10. Inspect the regulator filter screen for contamination. If contaminated, replace the fuel pressure regulator.
To install:
Fig. Fuel pressure regulator-4.2L engine
  1. Install the regulator filter.
  2. Install the new O-ring on the fuel pressure regulator.
  3. Lubricate the fuel pressure regulator O-ring with clean engine oil.
  4. Push the fuel pressure regulator into the regulator housing on the fuel rail.
  5. Install the fuel pressure regulator retainer. Tighten the regulator retainer screw to 71 inch lbs. (8 Nm).
  6. Install the fuel return pipe retainer. Tighten the return pipe retainer screw to 71 inch lbs. (8 Nm).
  7. Connect the fuel return pipe.
  8. Connect the fuel pressure regulator vacuum line.
  9. Connect the negative battery cable.
  10. Inspect for leaks:
    1. Turn ON the ignition for 2 seconds.
    2. Turn OFF the ignition for 10 seconds.
    3. Turn ON the ignition.
    4. Inspect for fuel leaks.
  11. Install the engine wiring harness into the retaining clips at the front of the engine.
  12. Install the air intake resonator.
Hope help with this (remember rated this post).
Feb 26, 2010 | 2000 Chevrolet Blazer
How to change fuel filter on 2000 dodge durango
Here ya go! Please don't forget to rate!
NOTE: A combination fuel filter and fuel pressure regulator is used on all engines. It is located on the top of the fuel pump module.
To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain and remove fuel tank.
  3. Clean area around filter/regulator to prevent contaminants from entering pump module.
  4. Remove or disconnect the following:
    • Fuel filter/regulator by twisting and pulling up CAUTION
      Do not pull filter/regulator more than three inches from fuel pump module.
    • Old fuel tube clamp by gently cutting clamp, taking care not to damage fuel tube
    • Plastic fuel tube from filter/regulator by gently pulling downward
    • Filter/regulator from fuel pump module
To Install:
  1. Install or connect the following:
    • New clamp over plastic fuel tube
    • Filter/regulator to fuel tube by rotating filter/regulator in fuel tube until it is pointed towards front of tank
    • Line clamp to fuel line using special hose clamp pliers (number c-4124 or equivalent)
    • Filter/regulator (pressing by hand) into rubber grommet
  2. Rotate filter/regulator until pointed towards front of vehicle
  3. Install fuel tank.
  4. Check for fuel leaks.
Jul 11, 2009 | Dodge Durango Cars & Trucks
Bruder forklift by Logo
61 people viewed this question
Top Bruder Toys Experts
Colin Stickland
Colin Stickland
ptpumpman
Are you a Bruder Toy Expert? Answer questions, earn points and help others
