Question about Humidifiers
Does not collect water
No water in bucket
Humidifier blows cool air only not collecting water
a humidifier doesnt collect water only disperses it. a dehumidifier collects water
Jul 05, 2017 | Humidifiers
Humidifier is full of water but the light shows it's empty. Since the humidifier thinks there isn't any water it won't run.
More than likely, the float valve in the top of the water collection bucket is broken or stuck in the DOWN position. Turn the unit OFF & unplug it. Remove the bucket for it's holder and empty any water that's in it. Inspect the float valve to see if it moves freely. Jiggle the arm of the float valve to see if it moves up and down freely. If it doesn't then it's stuck or broken. Hopefully, it's only stuck, because in most cases, purchasing a replacement bucket with the float valve installed is your only option.
Hope this helps you solve the problem. Thanks for choosing FixYa.
Sep 17, 2011 | Essick Air Humidifiers
Dehumidifer runs, but does not collect water. Just started this recently. We use it in the basement. Not too old. It's a Whirlpool Accudry.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 07, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
The water doesn't come down when it's turned on.
heatman101
Jul 31, 2011 | Humidifiers
The unit is leaking water, but not from the collection bucket. The unit is in the basement, has worked well for many years, but has never been serviced or cleaned.
More than likely, the drain tube or hole that delivers the water into the collection bucket is clogged. To clear the clog: First turn the unit OFF and unplug it from the wall outlet. Use an 18 -20" long plastic Zip Tie, that will fit into the drain tube or hole. DO NOT use a wire coat hanger for this. Carefully insert the Zip Tie into the hole or tube and gingerly work it in until you reach the bend of the tube. This is where it gets a little tricky, because you must get past that bend, to be effective. Once the Zip Tie has reached it's limited reach or it has bottomed out. Slowly pull it back out, while rotating it. This will remove any clogs, so be prepared for water to follow.
Hope this helps you solve that leaky situation. Please let me know.
May 06, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
Whirlpool accudry dehumidifier doesnt work, the fan runs, but i think theres something wrong with the compressor, it clicks (on and off it seems) every bout 5 seconds. what could the problem be?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Sep 14, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
Dehumidifier not collecting water
do the lines from the compressor to the evaporator freeze up or ice up anywhere,if so it could be low on refrigerant,also check the start capacitor in the compressor power circuit,if its bad the compressor won't run
Apr 04, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
Motor runs, but does not collect any water in yank
Make sure any air filters are clean. Check to be sure the evaporator and condenser coils are very clean. Also could the humidity level in your home just be very low right now and just no moisture to remove? If all of this fails it could be a compressor problem or a refrigerant level issue. If this is the case determine if it is worth the expense to repair.
Good luck
Mar 28, 2009 | Whirlpool AD25BBR 25 Pint Per Day...
Humidifiers Logo
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
