Question about Avanquest Software Check Designer Home & Business
Check designer 2014 will not install
Attempting to install downloaded software from Avanquest, I get this message: "The version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32 bit) or x64 (64 bit) version of the program, and then contact the software publisher." I have Windows 7 64 bit. The guy in sales said it should work with either. I have been on hold with Avanquest tech support for over 2 and one half hours.
    Top Expert:
  • Avanquest So... Master
  • 26,124 Answers
I hope it is a free call!
Posted on Jun 02, 2017
My logo naker will not load/ Says "not responding"
Could be a corrupted installation, try re-installing
Is the software compatible with you OS?
Jun 23, 2014 | Avanquest USA MyLogoMaker, Download...
Jit debugging unhandled
Did you check that version is compatible with Windows 8? If it is, you will need to get in touch with Avanquest. I have found them very helpful.
Jan 11, 2014 | Avanquest My Invoices And Estimates Deluxe...
Problem installing MyMailList
IMPORTANT-it could be the"Aluminum -( HEADS!)"!IF they-R-LEAKING at ALL/Warped from Over-heating/Not-Proper temp. read-outs from your T-Stat-OR'Info-Center'-But IF there is ANY-ANY Carbon Monoxide Mixed IN W/Your Coolant-then you have"LEAKING HEAD or HEADS"!U-Can"Check VERY easy Actually with"Chemical that's Bluish&Merely-2- Radiator-( FUMES-from still fairly warm Engine)&CAN Check from Your"Coolant Resivoir"-Easily"!!It turns"Yellow or Brownish-Then-U-Have a HEAD-PROBLEM" -IF Stays BLUE-then ZERO Heads Leakage from Coolant-OK&NO' Blown heads/leak Head gaskets/Warped/NOTHING"!!Costs a HUGE"$32.00-4-SPECIAL-Made Kit for the 4.0L-Baby N-Stars"!!Can easy do-Yourself,OR have mechanic do it!:)This-IS#1Problem w/4.0L-N-Star Engine"Overheating Problems-Over90%++'!!:)Worth-2-Check!
Dec 29, 2013 | Mysoftware MyMailList & AddressBook...
Proventure logo
Where are you attempting to download this software from? Proventure changed it's name to Avanquest back in 2005.
Jul 15, 2012 | Encore Proventure Logo Maker Full Version...
Lost WebEasy 8 Professional packaging and disc
EasyWebSave v1.8.1
JGCF-EJAR-JIPQ-UYEM
Web Easy 7 Express
712D-0311-PBUU-0G64-CUGC-7HH9
or Download WebEasyPro_8_ENU_Trial.exe
Avanquest.com/../8/WebEasyPro_8_ENU_Trial.exe
Use following license key code / serial number:
12C-0411-6WBR-XP5X-VYE5-6RR9
hope it helps
May 15, 2012 | Avanquest WebEasy 8 Professional Full...
How to fix and repair a not valid win32 application?
Often this error message will be similar to the below error message.
C:\Program Files\myprogram\program.exe is not a valid Win32 application.
Cause
This issue can be caused by any of the below possibilities.
File is corrupt, bad, or missing.
File is not designed for your version of Windows.
File is a virus, worm, or other malware file.
Hardware incompatibility.
Answer
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install or after the program has been installed because it was not copied properly onto the computer.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
If the program is an older MS-DOS program or early Windows program you may get this error.
If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Getting old MS-DOS games to run in Windows.
This error can be generated by a file that is a virus, worm, Trojan, or other malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus or infected.
If the file has been checked and is clean, it is still possible that the virus protection program or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Source : ( http://www.computerhope.com/issues/ch000726.htm)
May 30, 2011 | Microsoft Computers & Internet
Not a valid Win32 application
Answer:File is corrupt, bad, or missing
Download files
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Bad file
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
If you're attempting to run an older computer game in a new version of Windows, see document CH000587 for additional suggestions about getting older games to work in Windows.
This error can be generated by a file that is a virus, worm, trojan, or other type of malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus and/or infected.
If the file has been checked and is clean, it is still possible that the virus protection program and/or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue. Additional information about Safe Mode can be found on document CHSAFE.
May 30, 2010 | Rosetta Stone Spanish (Latin American) -...
Cannot run application (*.exe)
what is the application?
It sounds like you are trying to run a Win 16 (Windows 3.x) program
Jul 26, 2009 | Dell Inspiron 1420 Notebook
Error message: "The file wmploc.dll has a version number of 11.0.6000.6344 where 11.6001.7004 was expected. Windows media player was not installed properly and must be reinstalled. Do you want to inst
This is not a very common problem, but in all likelihood your Avanquest software has altered your Windows files in such a way that you cannot install your media player.
Most fix-it utilities make back-ups of your system files as they were BEFORE running the utility.
Check in your Avanquest application to see if you can restore your system to the way it was before running the application, then try reinstalling Windows media player.
Let me know if you need any further assistance regarding the above.
Best wishes,
Graemevm
May 21, 2009 | Microsoft Windows Media Player
Error Message 'F:\ setup.exe is not a valid win32 application'
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
Download files
Bad file
Mar 18, 2009 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
Top Avanquest Software Computers & Internet Experts
David Payne
David Payne
Are you an Avanquest Software Computer and Internet Expert? Answer questions, earn points and help others
