Question about GE Microwave Ovens
GE Spectra oven heating element gets hot on its own, without turning oven on.
Just replaced a heating element on a GE Spectra Oven. Now, when the breaker is turned back on, the heating element gets hot on its own, without turning the oven on. Top of the stove works fine.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 119 Answers
Sounds like you have your wires crossed
Posted on Mar 31, 2014
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Range RF315PXDW
It sounds like you are missing part of your input voltage.
I would take a voltage reading at the receptacle and confirm you are reading 220-240VAC. Some homes have the 220 service receptacles wired up with two 120 volt breakers to make up your 220 service. If your home is configured this way, you may have one of the breakers tripped. Or, the receptacle itself may be bad. If you confirm you have the correct voltage at the receptacle, your power cord may be bad.
The reason the clock and display will still appear to work is because the clock only uses 110-120VAC and is tapped off the source voltage. The surface burners and the oven heating elements, however, require the full 220 service.
If you are confused by this explanation, please post back and let me know. Hopefully, this is a problem that will not require any parts or a service call. If the power cord is bad, you can purchase a replacement at any hardware store. I hope this information is helpful.
Posted on Dec 19, 2009
Testimonial: "I will definitely check both the 120v wires in receptacle feeding power to the stove. The breaker in the house breaker box is a single 60amp breaker. "
  • 2841 Answers
SOURCE: the oven stopped working...doesn't heat
Remove the heating element and inspect them for a bulge or break. If you seen any bulge or burnt spot the element is defective. Normally they are held in place with one or two screws you remove end then pull the element out. If they look good then check for continuity with an ohm meter. Set the ohm meter to 1000 ohms and place red probe one one end and black probe on other end. If the meter does not move then the element is defective and must be replaced.
Posted on Jan 04, 2011
heatman101
  • 43501 Answers
SOURCE: My GE gas oven won't
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Jul 03, 2011
My lower oven is not heating properly, the bottom heating element is not getting hot.
You will have to test the element to be sure it is the problem. Turn power off to oven and then remove element. You will have to check with ohm meter. Remove wires before checking. If you don't have one, most appliance parts stores will check it for you. If element is burnt in two or has any rough, bubbled up places on it, then it needs to be replaced.
Jan 18, 2011 | Microwave Ovens
Nothing is hot - everything is on
Check the door safefy interlock switches before you plunk your $ down.
If you open your oven to check the contents without turning the oven off first ... the tiny switches arc and start to burn ... once they cannot make contact ... the oven doesn't know if the door is open or closed so it will not turn on the heat.
It is worth checking ...
Jun 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating
In all likelihood the Magnetron, or Power Diode has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 26, 2010 | GE Microwave Ovens
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Microwave safe cups are heating up without the liquids getting very hot.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
s334
Oct 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge convection micro combination has a problem with convection fan . fan runs for about 5 seconds, rattles, then stops. heat element gets red hot but little heat inide oven. replace fan motor or maybe more?...
I would say the convection fan blade is loose on the shaft.
If this is the case, it would try to run, but no cooling would take place, so the heat from the heating element would get very high but it would not be distributed through the oven.
The thermistor would then detect the extra high heat and stop it, I assume.
You may be able to use super glue or JB Weld to fix the blade on the shaft, as long as they are clean and dry and it is allowed to set overnight.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Accessing these components for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jul 11, 2009 | GE Monogram ZE2160SF Convection /...
Microwave Ovens Logo
49 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
