Question about Polar F4 Heart Rate Monitor Watch
Reset frozen watch
Watch stopped at 4:59 4days ago the last time it was used. It does not respond to pushing all buttons at once for 2 sec
2 Suggested Answers
  • 7 Answers
SOURCE: Frozen Display
The reset will always solve the issue. It may have been due to Electromagnetic Interference or Static Electricity.
You can press and hold ALL buttons at the same time for 10-15 seconds. After that, simply reset the time/date. All saved information will be stored.
If you are still having a problem feel free to contact Polar Customer Support @ www.polarusa.com.
Hope this helps.
Chris @ Polar USA
Posted on Aug 22, 2008
How do I set the time on adrenaline digital watch?
two standard digi watch setting processes
1 press and hold mode button until time start to flash
then use the start button to move between hour , minute sec etc and the reset to adjust the time, when correct time set press hold once more to return to normal time.
2 press hold button one push at a time on the third push the time should start flashing , follow the above processes.
Mar 04, 2015 | Freestyle Adrenaline watch
I have a pulsar chronograph 100m the time keeping seems to be ok but, the buttons for stop watch, when stopping the sec,1/20 etc hand are not returning to zero. can u help. richard
Thanks for using Fixya.
Try this: pull out crown to the first click, then push and hold button at 2 o'clock. When the hand is adjusted to the desired time, push the crown back in.
If this do not work, do the same using the button at 4 o'clock.
Good Luck and have a nice day.
Apr 27, 2010 | Pulsar Watches
During a workout my watch stopped working it appears to be frozen and will not do anything
NO, don't open the back cover you will break the water seal.
Reset the wrist unit. Resetting clears the date and time settings.
Press all buttons except the Light button at the same time until the display is filled with digits. Press OK.
If this does not work, have the batteries checked.
Oct 19, 2009 | Polar F6 Wrist Watch
DECADE WATCH HAS NO SETTINGS MANUAL
If your Decade watch is like mine it has 4 push buttons (10, 2, 4 and 8 "o'clock" positions respectively; and one pull and turn stem (at 3 o'clock position) -
For the purpose of setting the watch and functions mentally label the push buttons as follows:
10 o'clock position "A"
8 o'clock position "B"
2 o'clock position "C"
4 o'clock position "D"
NORMAL TIME SETTING
1) In normal time readout press B (3x) to get to normal time setting mode: "SEC" will start flashing, press C for synchronization
2) Press D once: "MIN" will be flashing, press C to advance
3) Press D once: "HOUR" will be flashing, press C to advance ("A" is for am, "P" is for pm, "H" is for 24 Hour format)
4) Press D once: "DATE" should be flashing, press C to advance
5) Press D once: "MONTH" should be flashing, press C to advance
6) Press D once: "DAY OF WEEK" should be flashing, press C to advance
7) Press B once: Setting is completed, return to normal time readout
ALARM TIMES SETTING
1) In normal time readout press B (2x): Alarm time "HOUR" should be flashing, press C to advance
2) Press D once: Alarm time "MIN" should be flashing, press C to advance
3) Press B once: Setting is completed, return to normal time readout
ALARM FUNCTION
1) In normal time readout press C and D simultaneously: Alarm signal should appear
2) In normal time readout disarm alarm by pressing C and D simultaneously: alarm signal should disappear
Note: Alarm (when activated) will stop itself after 1 minute; or can be silenced by pressing D or press C to snooze for 5 minutes (operates for 1 hour)
CHIME
1) In normal time readout press D and B simultaneously: Chime signal should appear
2) In normal time readout disarm chime by pressing C and D simultaneously: alarm signal should disappear
CHRONOGRAPH (STOP WATCH FUNCTION)
1) In normal time readout press B once to get into "CHRONO" mode: press C for to start counting event -
While in Chrono mode there are two options
a) During a counting event: press C to stop counting, press D to clear and reset stopwatch to 0:00
b) During a counting event: press D to see a "split" time (IE first leg of a relay time is shown while the counting event continues, press D again to return to running counting event; press C at end of event, press D to reset stopwatch to 0:00
2) press B to return to normal time mode
Mar 27, 2009 | JCPenney Watches
My michele watch chronograph is stuck
Have a watchmaker fix it...there isn't anything you can do.
Mar 24, 2009 | Michele CSX Diamond watch
Nike triax watch
sounds like the contact inside for the ligt button is stuck on. Remove the back again and take a look at the contact under the light button to see if it is stuck, if so, GENTLY pry it out a bit so it's not touching all the time...
GOOD LUCK
Jan 27, 2008 | Nike Triax CV10 Wrist Watch
Frozen Display
Hope this helps.
Chris @ Polar USA
Nov 08, 2007 | Polar F6 Wrist Watch
SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Sep 19, 2007 | Watches
Kenneth Cole KC3081
if you pull the crown out to the #2 position,then push the start/stop pusheryou will move the sweep sec. hand up to the 12 o'clock position. push in crown. Don
May 22, 2007 | Kenneth Cole KC3271 Wrist Watch
Polar F4 Heart Rate Monitor Watch Logo
54 people viewed this question
Top Polar Watches Experts
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
