Question about Frigidaire Dishwashers
Half way through a wash there is a pop and the circuit breaker has to be flipped only to repeat the same thing
What could this problem be?
    New Friend:
  • 12 Answers
If the dishwasher still runs except for the breaker popping part way through the wash, I would first suspect the heat element in the bottom of the tub. First, visually inspect the element to see if there are any obvious signs of it being burned out. If there are no outward signs, then the element needs to be checked at its terminals with a multimeter to see if it's shorted internally. If it is still not shorted, it should be showing in the vicinity of 14 to 20 ohms of resistance across the terminals for it to heat properly.
Posted on May 09, 2014
3 Suggested Answers
SOURCE: no power, tripping circuit breaker, loud pop
Sounds like the main wash pump has burnt out are there any leaks under unit.It could also be the heater.but the loud pop sounds more like the wash pump.
Hope this helped.
Posted on May 11, 2010
Testimonial: "Thank you for your reply, I took the DW apart and sure enough the motor is burned up. I have tryed looking for a replacement but they are very pricey."
heatman101
  • 43501 Answers
SOURCE: Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Posted on Oct 03, 2010
Dryer stopped working. Not spinning or anything
You will be needing someone with an electric meter, (an ohm meter or a multi-meter) to begin testing to find out if it is the dryer or the power source.
The one thing you could do is check the fuse panel or the circuit breaker box to see if a circuit breaker popped or a fuse blew.
The circuit breaker can be reset by flipping the handle a few times, a fuse would need replacement.
Other than that, an electric meter will tell if the plug socket is live or dead, and then the machine needs be taken apart to see which part has failed. Usually a fuse or a thermo-switch has popped inside the machine.
God bless your efforts.
Sep 08, 2015 | Avanti D110 Electric Portable Dryer
Wash cycle repeating
Hello Dave Powers - Try reprogramming the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. Run a normal cycle, if issue continues then it sounds like it is experiencing a wiring failure or a communication error with the control/keypad. Consult a professional to move forward accurately.
Feb 06, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Whirlpool washer machine WTW5790SQO washer trips circuit breaker half way through cycle
you are pulling to many amps see if breaker is faulty first.....see if washer is in the spin and jumping around when this happens run washer with out wash in it and see if it does it something is pulling to many amps to blow breaker or could be just a bad breaker,,,, pulg something else in the wall plug that the machine is plugged in to (like a toster) and see if it trips then if so probably the breaker
Nov 11, 2011 | Whirlpool Washing Machines
How to cancel delay start
Press the Delay Start button several times until the displayed delay start time is cleared or reads "00". Unplug the machine or flip the circuit breaker to the OFF position for at least half an hour or so to forcibly reset the control if pressing the Delay Start button does not alter or clear the displayed delay start time.
Nov 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Message ER DH continues to pop up on the door. If
ER =ambient temp sensor failure
DH= defrost heater
Defrost heater, temperature fuse short
circuit, unplugged connector(indicated
4 hour later after trouble)
You is gonna have defrost problemas!
Feb 24, 2010 | LG LRSC-26922 Side by Side Refrigerator
Loud pop, now circut breaker flips off when I turn on the machine
HI
A loud pop can be a couple of things. Usually it is a ruptured hose, or a hose the has separated from its keeper.. This can explain why it is you are popping the circuit breaker. Water is spraying on an electrical circuit, and causing the short. The other thing that pops is when you blow the circuit board but then you would have a burnt smell.
Oct 14, 2009 | Starbucks Saeco Italia Digital Barista...
Dishwasher is "tripping" the breaker & not draining.
I had the same problem with a Hobart AM8 passthru dishwasher. The electrician determined that some of the wires had become exposed and were wet, thus shorting things out and tripping the breaker.
Jan 08, 2009 | Bosch Dishwashers
LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
Jan 02, 2009 | LG WM2016C
I self cleaned my Amana oven model acf7225aw. During the cleaning there was a huge pop and then all power was shut off to the oven (no power to clock or anything). We flipped the breaker- another pop. ...
Yes you probably have a burned out bake or broil element in the oven. They usually short out to the frame when they go and can have some interesting results. A direct short probably burned out half of the circuit breaker and you are now only getting 120 volts to the stove and its feeding back through the shorted element and giving some heat. Unplug the stove reset the circuit breaker and test the outlet for proper power. Outer holes will read 220 volts to each other and 110 volts to the middle hole. Replace the circuit breaker if needed. Usually when an element burns out it is visible. If not remove both bake and broil elements and take them to the parts store and ask them to see which one is bad. It is very unlikely they both burned out.
Jun 28, 2008 | Amana Kitchen Ranges
Dishwashers Logo
26 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
