Heater not heating
My Hyundai oil-filled radiator heater stopped working suddenly. It get turned on (both lights on) for the first time but after few seconds it turned off and doesn't heat at all even if i put it to the max level for heating. Thanks for ur suggestion in advance!
  • 4 Answers
SOURCE: Heat turns off
Sounds like the high limit switch on the heater is kicking off. The flash is the switch shutting off the heating element. The only way to reset it is to turn unit off for about 5 minutes. Possible problems are: 1.) Bad thermostat 2.) blower motor not turning fast enough which means motor is bad.
Posted on Oct 13, 2007
SOURCE: pilot light on but heater won't come on when I turn up the thermostat
Williams heaters have a manual reset for the spill safety switch. If the heater is not venting properly it will trip this switch and shut off main burner function. The switch is on the left side of the cover inside the small vent. You can use a screwdriver to push the button back in. If the heater then works you will need to get the vent inspected to make sure it is connected properly and there is no blockage.
Posted on Jan 03, 2008
SOURCE: Honeywell HZ-709 Oil Filled Radiator
Problem: firs let's identify the problem, there is a sensor on the inside panel, made originally for safety if you tipped the heater off, it kill the power causing it to turn off...after a year of so that sensor get a little rusty/dirty causing it not to work correctly...
let's find out how to fix that annoying turn off..
tool needed, a phillip screw driver.. electrical tape or soldering unit..
fixing it: take out the top and bottom screws, to open the panel. after you open the panel you'll see a metal bar screwed to the front controller...take all 6 screws out...the front panel comes off....then there is about 4 screws holding an inner box, open that up..
inside there, you;ll see lots of wires...look for 2 small blue wire running together to a black sensor that make noise everytime you move it....
disabling the sensor
2 ways you can do this..
-you can cut the wire off using a scissor, and connect the blue wires together, use the tape to tape them.
or
- you can solder them together on the back of sensor panel...
there you go problem solved...
Posted on Mar 25, 2008
SOURCE: The Lakewood 5500 oil-filled heater has stopped
Similar problem here. But in my case, it was a blown fuse. There's an in-line fuse on the internal wiring of the heater. Take the control-side off (remove the bottom grey plastic bracket, then remove a sheet metal screw, then slide the whole assembly down off of the radiator). Where the elements go into the reservoir at the bottom of the radiator, the white wire should have an inline fuse connected to it. It will probably be covered with what looks like heat-shrink tubing. Snip, snip, and replace.
Posted on Jan 11, 2010
  • 408 Answers
SOURCE: how do you set heater to work?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the manual you need. Hope it helps. If you need anything else, let me know.
Posted on Feb 20, 2010
Just stop working.. one year old
It should still be in warranty, even if it is slightly past the 12 month period a phone call to the supplier might bring a pleasant surprise. It really should have lasted longer
May 27, 2015 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
My Comfort Zone Oil filled CZ7007J Radiator is not heating, it was working just fine when I turned it off, but when I turned it back on, no lights, no heat, like it's getting no power. Bought it
doubt there is any warranty being made in 2010 but they do have a heating element very similar to an electric water heater .I know of no repair shops that work on them.nor where you might find an element . SORRY Personally I found these oil filed heaters cost more to operate than the ceramic. types
Dec 30, 2017 | Comfort Zone CZ7007 Oil Filled Electric...
My Lakewood oil-filled electric radiator makes some crackling noises when first heating - is this normal?
Yes, it is normal. the sound is from the oil heating up and moving through the fins. It will stop after a few minute. After the heater is used for a few months the noise will stop altogether. j
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
Capt. Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Feb 22, 2011 | Lakewood Oil-Filled Electric Radiator...
Lakewood radiator heater model number 5101. The heater just stopped working all of a sudden. The buttons still light up when switched on but there is no heating. please help as I dont have any other...
Sounds as if the element is burnt out or the tstat is broken. the tstat is the more common as they use very cheap ones. Unfortunately you can't get these. My suggestion is to buy a new one.
Jan 27, 2011 | Lakewood Oil-Filled Electric Radiator...
All of a sudden the heater is not heating up. The
make sure the thermostat dial is not turned all the way down. The red rotary dial, set it to 6.
Dec 15, 2009 | Honeywell HZ-680 Oil Filled Radiator...
Welbilt heater doesn't heat contactor switch doesn't light
my welbilt radiator just suddenly stopped working. what can i do to try to make it work again?
Oct 30, 2008 | Kitchen Appliances - Others
Oil filled Heater will not turn on and heat.
First thing make sure: · Ensure that your circuit breaker or fuse is working properly. · Be sure the heater is plugged in and that the electrical outlet is working properly. · Check for any obstruction. If you find any obstruction, turn the heater ?OFF?. Unplug the heater and wait a few minutes for it to cool down. Carefully remove the obstruction. Plug the heater in and turn it on again by referring to the OPERATING INSTRUCTIONS. Second, If you're NOT still under warranty you should at least open the heater and look for anything strange like a blown fuse. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace.
Dec 03, 2005 | WeatherWorks CH3001 Oil Filled Radiator...
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
