Question about Cobra Radio Communications
Clear call model # FRS-85 not work properly
I have an issue with one of the 2 way radios. I can talk out of the radio but can't hear anyone talk back. When I turn on it first says 18 and then it would usually change to the current channel but is doesn't it displays the 1 ehre part of the 8 in 18 is but still displays 18. Also I put new batteries in and it keeps flashing battery low, I put the same batteries in another of the same make and it works without any problems
  • 33 Answers
Is there any overheating???...can you disasemble it???..please tell me these infos and I will come back to you...!!!
Posted on Jun 09, 2014
Benimur
  • 6966 Answers
SOURCE: Model LXT 300 FRS/GMRS RADIO
There could be three (3) reasons why the display shows the battery icon at the top left side of the LCD display:
1. weak/undercharge/discharge batteries;
2. dirty/corroded/loose battery contacts/terminals; and/or
3. internal fault with the electronic sensing for battery level/state.
Corrective measures would require:
a. replace/recharge batteries. The rechargeable batteries need at least 12 hours of charging time;
b. clean, scrape, tighten (need to bend a little more towards the battery terminals) the spring/contacts of the battery holder;
c. (on the internal fault) your best bet might be to seek the services of a professional electronic technician since this would need familiarity with electronic components, their circuitry and diagnosis, perhaps a bit of soldering and the use of a DVM.
On the other hand, if the "low" is the "L" icon at the bottom right side of the display, this would indicate that the radio's transmit power setting (H/L - high/low). Transmit power level can only be changed in Channels 1-7 & 15-22. The radio will also auto change to lo power when batteries are weak.To switch to high power, press on the Menu button thrice or till "Pr" icon shows, press on the up/down to select H or L. To save & exit, momentary press the PTT.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 01, 2008
eradiostore
  • 1654 Answers
SOURCE: I get static after someone else talks
One of the main causes of static can be a bad battery. If you are using rechargeable batteries you need to replace them every 14-18 months. If you are using alkaline batteries, they have been known not to fully power the radio once your cross the 10 hour mark. Your radio would then be operating in somewhat of a brown out. This would lead to static.
Another cause of static is simply being nearly out of range of the other radio(s).
The burst of white noise at the end of Rx on some radios can be rather annoying. On the basic talkabout radios there is nothing which can be done to solve the problem, other than replacing the radio.
Posted on Jul 30, 2008
  • 19 Answers
SOURCE: One radio not working
Hi it sounds to me that you have a fault in the microphone or the cable to the unit.check all the connections wiggle the mic cable and note any changes.
You say the mike button is frozen? try adrop of CRC in the press to talk switch-- only a drop or two, dont want it getting into the microphone it self.
Oh and have you got the batteries in the right way?
Cherrio John
Posted on Apr 07, 2009
eradiostore
  • 1654 Answers
SOURCE: I cant talk to the other radio. the channels are both the same.
Here is a link to the EM1000 series user guide: http://www.giantintl.com/ContentManage/manuals/Moto/EM1000%20User%20Guide%2001-11-08.pdf
Check your frequency, code and Qt filter (if any) settings. For basic operations set the code and Qt filters to zero (off). Turn off any special features, and try the radios in just a basic mode.
Best regards.
Posted on Apr 10, 2010
Ironfist109
  • 3018 Answers
SOURCE: Radio Shack Catalog # 21-1926
In short channels 1-7 and channels 15-22 are GMRS channels are not supposed to be operated by anyone that does not have a GMRS (General Mobile Radio Service) license issued by the FCC. They automatically run on high power. Channels 8-14 are FRS (Family radio Service) and can be used by anyone and are set to run on Low Power. The power is not adjustable with this radio. So now for the manual. Uniden made this radio for Radio Shack. So this manual is for the same radio only with the actual Uniden name. Same exact physical radio same exact manual. http://www.uniden.com/pdf/GMR1038-2om.pdf
Regards, Tony
Posted on Apr 22, 2011
Looking for owners manual
Cobra says the FRS 105 and 110 are much the same as the 85.
https://www.cobra.com/sites/default/files/manuals/FRS105_EngSpa.pdf
Feb 01, 2016 | Cobra Radio Communications
1 works clear & the other just recieves a scrambling sound
See the both Radio should have same QTC and DQTC if not same then write same value and program the both Radio and check, it will work fine.
Jul 22, 2015 | Cobra FRS 85 (14 Channels) 2-Way Radio
Whats the radious on Conair 2 way radio
Most handheld radios will talk line-of-sight up to two miles. Obstacles will reduce the range. Talking from inside to outside of a building you might expect 1/4 to 1/2 mile.
Best regards.
Jul 15, 2014 | Conair Frs 2 Way Radio 14 Channel...
Can a Motorola talk about 250 talk to a cobra CXT 195. They can hear me from the Motorola I just cant hear them
Your code (PL code, interference eliminator, quiet call) is not programmed the same on both radios. The Cobra appears to be set to open squelch (no code). Set your Motorola code setting to zero (off). This should solve the problem.
Feb 18, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
This is a confusing website. But my problem is with a pair of Uniden FRS 420 two way radios. Have replaced batteries, gone through manual, have every option set properly but still have no reasonable...
Are you stating the volume is not loud enough when someone talks or just idling. If if has a squelch knob turn it til it makes a hissing noise or rushing noise. then back to where the noise just quits. This is the proper setting. Then when someone talks increase volume to listening level you choose. If this does not work take them back and get your money back.
Dec 22, 2013 | Uniden 2 Way Radios Frs 420 Family,14...
Can you use 2 different talkabouts fr50 and t5420 with each other? I have just one of each unfortunately.
  • Yes they will both talk together on the same channels just fine. Most of the more recent Talk About Radios are FRS/GMRS with 22 channels. These radios are FRS only with out the GMRS. The FRS are the first 14 channels in most talk about's as are your radios.
Regards, Tony
May 01, 2011 | Motorola Talkabout FR50 (14 Channels)...
Will the MU21CV radio's work with the talk about radios?
Short answer, maybe. It depends on whether you have a 14 channel or a 30 channel Talk-About. The Motorola Talk-Abouts operate on the FRS frequencies (14 channel) or FRS & GMRS frequencies (30 channel). The MU21CV does cover a few of the GMRS frequencies. (see bold numbers)
GMRS Frequencies
462.500, 462.575, 462.600, 462.625, 462.650, 462.675, 462.700, 462.725, 467.550, 467.575, 467.600, 467.625, 467.650, 467.675, 467.700 & 467.725
FRS Frequencies
462.5625, 462.5875, 462.6125, 462.6375, 462.6625, 462.6875, 462.7125, 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, 467.7125
MU21CV Frequencies
464.500, 464.550, 467.7625, 467.8125, 467.850, 467.875, 467.900, 467.925, 462.575, 462.625, 462.675, 464.325, 464.825, 469.2625, 469.500, 469.550, 462.7625, 462.7875, 462.8125, 462.8375, 462.8625, 462.8875, 462.9125, 464.4875
Nov 01, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola talkabout 250 beeps when the talk button is pushed
The radio has possibly been damp or wet. Take the battery pack out of the radio and allow the radio to dry, or to speed the process try using a blow dryer on a low setting.
Check your programming and be certain your large and small numbers match one another when you get ready to try the radio again.
Here is a manual which most closely matches your radio type: http://www.usersmanualguide.com/motorola/2-way_radio/t280
Nov 17, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
00 jeep grand ---tail-gate wont unlock
use the key, to open. then check the solenoid on the window lock, to see if it working or greased properly. you will have to remove all the panelling of course
Jul 03, 2008 | Cobra FRS 85 (14 Channels) 2-Way Radio
Radio Communications Logo
77 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
