Question about Solis Master 5000 Espresso Machine
Smoke! When I pushed the brew button, smoke and a burnt rubber smell started happening. Shut it off immediately. Then, opened bean container and cleaned out grinder. Found some broken plastic pieces in there that don't appear to have come from the machine, but maybe my coffee bean bag...not sure. Put it back together and now when I push brew button it flashes and nothing happens. Do I need a technician?
SOURCE: wate coffee container removed for cleaning, the machine was accidently switched back on. Now the container will not slide back into the machine, it looks like the coffee maker portion needs to be re
You can remove the brew unit and cycle it manually back to the neutral position. There is an arrow and letter "N" that will align when the unit is properly positioned.
Posted on Mar 14, 2008
  • 1036 Answers
SOURCE: Solis Palazzo - Coffee grinder seems blocked
Hi there!
This is most likely due to a build up of ground coffee at the edges, and the whole lot has become a solid lump.
Disconnect the machine and clean with a small stiff paintbrush.
This is caused by damp beans, or using dark roast beans, or keeping beans refrigerated. Often it is the coffee oil that causes it.
If there are beans in there and the unit is not rotating, please contact here again.
Thanks......Oh, and rate as Fixya! if it helps you.
Posted on Jun 19, 2008
  • 11 Answers
SOURCE: brewing cycle and upper filter?
Be sure your metal strainer in the coffee puck funnel isn't clogged. Check you grind level adjustments also.
Best Wishes,
Posted on Jan 04, 2009
SOURCE: solis 5000 diagram of brewing unit
See for technical documentation of the digital unit (brew group looks the same as the non-digital one). Descriptions in German, French and English.
Posted on May 17, 2009
  • 1618 Answers
SOURCE: jammed brewing unit
Remove the brew unit and check the screen under the red o-ring, find the 2 screws above the top piston and make sure the chamber that leads out to the tube is clear.
Posted on Mar 29, 2010
Why won't it brew?
Think the grinding mechanism is jammed with something. Disassemble unit and look for same.
Sep 03, 2017 | Saeco Vienna Plus Black Super-Automatic
My car is hard to turn, it makes an awful noise and is smoking, it smells like burnt rubber, if i continue to drive it what will happen
Hi Debbie,
Not sure with out looking at it, But from what you posted if hard to turn
sounds like your power steering punp aint working , ant if smoking and smells like burnt rubber sounds like pumps locked up, (pully not turning) and if so continuing to drive it could leave you on side of road if it runs a cerpintine belt , that kind of belt runs every thing and if breaks water pump stops flowing water motor will over heat, you should realy have someone look at that for you.
Feb 05, 2014 | Dodge Cars & Trucks
I put beans in where the grinds should go. help!?
Open the door and remove the drip tray. Then remove the brew unit and empty the beans. Make sure that you get all the beans. Check the brew unit thoroughly. Then put everything back. Try the pre ground button but don't put anything in the brew unit then push the medium coffee button. That will run the machine through a brew cycle and if it works OK then you set to go.
Dec 30, 2009 | Saeco Incanto Classic Espresso Machine
Our Saeco Delux Magic coffee maker will not grind the coffee when we push the button. A light comes on that indicates that the grinder could be jammed.
The grinders run on a timer. If the grinders does not fill the doser in time you will get a light saying no beans. If this happens and there are beans in the hopper push the lever to the largest # and push the brew button again. This will clear the light and it should brew. If it is at the largest # already your beans are probably shiny and there is to much oil in the beans and this is what is clogging the grinder.
Apr 10, 2009 | Saeco Magic De Luxe Espresso Machine
Not turning on and has strange smell
Powershot A640 Could Not Be Powered On, Burnt Smell
My Powershot A640 died during a picture shot, lens remaining open. I thought it may be due to the dead batteries. But after putting new batteries and pushing the on/off button, the on/off indicator blinked once then shut off by itself. After a while, a strange smell came from camera batteries area, and I could feel warm there too. Immediately I took out all the batteries from camera.
When checking the posts here the other day, I tried one solution and got the lens back to close: first took out the memory card from camera, then put the new batteries in; push the on/off button with no memory card. I found the lens retracted a little before camera shut off by itself. I pushed on/off button three times to get the lens fully close. However, the burnt smell came out again. I immediately took out the batteries.
Did I get a short circuit inside? Is there any ways to fix it?
Oct 31, 2008 | Cameras
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Solis Master 5000 Espresso Machine Logo
29 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
