Question about Epson Dc-10s Document Camera
Epson DC-10s keeps turning off
I've tried plugging it in different sockets, but still happens. Then I can't get it to turn on at all
    New Friend:
Were you ever able to figure this out...? Because now it's happening to me too...
Posted on Sep 11, 2015
Netbook turns off instantly when power cord plugged in - even when not plugged into power outlet!
Have you tried a different adaptor or power outlet other than that the dc jack on the notepad may need replaced
May 08, 2013 | Gigabyte Atom Series Netbook: Q2005 -...
It doesn't turn on
First try connecting the printer to a different outlet. If possible, get a replacement power cord and test if the printer will turn on.
If these steps don't help, the power supply or another internal component has failed. If the printer is under warranty, contact Epson. Otherwise, decide if it is worth attempting to locate and fix the problem. (If you take it to an Epson service center, you'll have at least a $50 fee just to diagnose the problem.)
I wish that I had better news for you.
Aug 20, 2012 | Epson Office Equipment & Supplies
Yahama PSRE413 Keyboard DC Adapter Issues
Yahama PSRE413 Keyboard DC Adapter Issues (1): First try battery power to ensure Synth works.
If it does, problem is most likely near DC socket, or socket contacts dirty / worn.
(2): Get a contact-cleaner spray (Servisol, McKenic, Kontakt, etc) and squirt into socket, then plug / unplug / twist DC plug to 'scrub' the contacts.
(3): Get a qualified tech to manually apply DC to the PCB solder-points which will verify if socket is faulty.
Aug 10, 2017 | Yamaha PSRE413 Keyboard
Dell Vostro Battery charging problems
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jul 12, 2012 | Dell Vostro V13 Laptop Computer (Intel...
Acer 7520 charging problem
Try another battery in the laptop to make sure the battery isn't bad. If you do that and the battery still doesn't charge then go ahead and try a different ac adapter.
If neither of these two steps solve it then it could be that the solder points underneath the DC Jack have hairline cracks in them. If this is the case then you'll have to get the motherboard out of the laptop and then with a soldering machine and some solder, you'll have to resolder all the solder points of the DC Jack to solve the problem.
That should take care of the problem but if it still doesn't charge then the motherboard is bad and would need to be replaced.
Aug 11, 2009 | Acer (ACERMOTHERBOARD)
Printer wont turn on
First things to check are that the power cord is properly plugged in and the socket it turned on (yes, sounds obvious but has caught me out in the past).
Beyond that, if your cable has a fuse in the plug, check that... try a different power cord and obviously check that the socket does indeed work.
Locating a working power socket and new cable that you know works and then seeing if that gives you any juice is the only other option... If that doesn't work your printer would appear to be in printer heaven.
Mar 10, 2009 | Epson Stylus Photo R300 InkJet Printer
Fried something?
A half volt will not make any difference. Sounds like the power supply is malfunctioning. Start by trying a different one. Keep in mind that you may have fried the new motherboard by using a faulty power supply. Popping sounds indicate a short or loose/exposed wires, and are never good with any electrical device, especially a laptop since they are sensitive to power fluctuations to begin with.
May 14, 2008 | HP Compaq Evo Notebook N600c
Epson DX 4000 printer
Thats interesting, check for obstruction inside the printer and try to do a selftest in which it will print a nozzle check pattern, chances are there is a faulty wiring that is why its not accepting commands when copying something. try to turn off printer and unnplug it from power supply then plug it back on a different socket or power outlet,
try copying again.
Apr 12, 2008 | Epson Stylus DX4200 All-In-One InkJet...
Problem
You have a failed circuit board there somewhere, maybe the power supply.
Mar 28, 2017 | Protron V33239 Television
Epson Dc-10s Document Camera Logo
112 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
