Question about Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum
How do I replace power connector plug on extension pipe?
I need to replace power connection plug (cover) in extension pipe. How do I disassemble the cover?
    Problem Solver:
  • 6 Answers
Google and order part 8175251 from major department store parts direct site. Must be handy to install. They have exploded view so you may be able to see how unit is assembled therefor you can use logic to disassemble.
Posted on May 28, 2014
I have a philips marathon fc 9202 vacuum cleaner. it has worked fine for a number of years but suddenly has no power. what can i check to diagnose the problem?
I finally found the root cause - Applies for FC9225, but may also solve other types of the same family.
The problem is the switch for the dustbox (not sure if the hinge is worn or the sensor (contactless switch) has another issue). Removing this safety switch (allowing you to switch on the vacuum cleaner without dustbox and filter cartridge properly installed, which I judge not a major 'risk'), permanently solved the issue, 1. Remove the lid 2. Remove the big sealing ring on the bottom of the lid 3. Pull the cantilever switch out (and dispose ;-) ) 4. Re-assemble 5. Fixed the problem in my case
(check 4 last images I added)
For your entertainment: I also filled the connector at lid side with glue gun glue, de-soldered all capacitors and measured them, completely dismantled the motor, pulled the brushes and cleaned the commutator... to find it was just the ****** switch...
DISREGARD BELOW BUT USEFUL FOR DISMAANTLING
We had similar issues (all power level lights start flashing when connecting). We could extend lifetime by electric contact spray. But also this stopped working at some point. Today I finally dismantled. Tip 1: to remove the lid, just push the 2 plastic covers outward at the hinge (no need to dismantle the lid) and push out the shaft.Tip 2: when dismantling main body, unscrew the small wheel below the 'dirt box' (OPPOSITE DIRECTION = CLOCKWISE TO LOOSEN). Tip 3: only dismantle the main plastic cover by loosening all screws.
Then dismantle the main body connector, remove the rubber block at the backside of the connector, make sure the 4 wires are as deep as possible in the connector, fill the connector with glue gun and put a tie rap to keep 4 wires together.
If you want to dismantle the connector, you need to push inside the 4 small latches near each wire, BE CAREFUL NOT TO ROTATE THE INNER OF THE CONNECTOR 180DEG WHEN RE-ASSEMBLING (there is no poko-yoko to avoid this).
I added some pictures to hopefully make things a bit more clear.
philips-marathon-h220o22wl0102llkt345joym-3-9.jpgphilips-marathon-pjs14luzmyx5n4x0j4da0pqs-5-5.jpgphilips-marathon-pjs14luzmyx5n4x0j4da0pqs-5-6.jpgphilips-marathon-pjs14luzmyx5n4x0j4da0pqs-5-7.jpgphilips-marathon-pjs14luzmyx5n4x0j4da0pqs-5-8.jpg
Oct 08, 2010 | Philips Vacuums
Carpet attachment with beater brush not working
Resolution for Quick Connect Power Nozzle: If you're vacuum is 2001 prior, chances are one of the two contacts in the power nozzle elbow have let go.
The elbow can be disassembled by removing the two screw covers. You will need a flat head and small star. Also, you need to release the retaining clip on the back of the elbow. You will have to remove the elbow completely if it needs replacement. You will then have to remove the top cover of your power nozzle. That is easily done by removing all screws in the bottom base of your nozzle. Once you remove your cover you should see 2-4 screws holding in the elbow
When you remove the cover, you will see metal contact rings and two contacts. If one of them isn't contacting the ring your power nozzle will not turn on. You can try shaping it back into place but from experience the new revised elbow that does away with that kind of connectivity is a lot more effective. The new elbow runs about $40-$60. Between eBay and Aerus Electrolux Dealer.
http://www.ezvacuum.com/electrolux-power-nozzle-elbow-assembly-graywhite-p-3542.html
Jul 12, 2010 | Electrolux Centralux Vacuum
Power Head keeps cutting in and out while vacuuming???Canister motor keeps running but the power head starts and stops like there is a short or some loss of connection somewhere. Any ideas?
The electrical terminal at the top of the extension wand may be loose or corroded. Unplug the vacuum and remove the wand from the hose assembly. Look at the 2 prongs and clean off any corrosion using a a Q-tip or scrape with a screwdiver if it's more persistent. After cleaning reconnect the wand to the hose and try it again. If the prongs are not corroded, they might be loose instead or they might not be aligned properly. If this is the case then bending the prongs very slightly may help realign them. The part that may be giving you the trouble is called the terminal cover (PN 8191782). It costs about $10 but the problem is knowing the procedure to actually replace the part. CAN ANYONE EXPLAIN HOW TO OPEN UP THE EXTENSION WAND TO REPLACE THE TERMINAL COVER ??
Jan 14, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
Loose electrical contact in extension wand
You have a loose connection at one of several possible locations.Inspect the contacts at the top and bottom of the wand .IF they are black or coppery or look melted, both pairs of contacts, male and female will need to be replaced.
Try to wiggle and twist the wand at top, then at bottom. If this does not reveal the short, work your way back down the hose towards the a vac itself, starting behind the hose handle.
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Cannot reinstall valve pipe assembly on Dyson dc17 vacuum
Take off the cyclone canister and flip open the filter cover. (The U-shaped tube at the bottom of the vacuum is probably already off-if not, release the lock with a screwdriver and remove it.) Release the vacuum from the upright positon, so that the head is extended. Align the value pipe assembly so that the clear tabs line up while the small extension off the value pipe faces the front of the vacuum (ie, is near the filter area). Now you have to carefully twist the value pipe clockwise while lining us the small extension with the black groove inside the head piece by moving the head back into the upright positon at the same time. Replace the U-shaped tube.
Mar 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hoover Flair S2220 cleaner w/power nozzle disassembly instructions
With the head flipped upside down, take a flat tipped screw driver and carefully pry up the rollers on the front the head. Underneath, you'll find a screw. Remove the screw under each roller, and the front cover will come off with ease. The rollers are just friction fit.
Aug 16, 2008 | Hoover U8185-900 Upright Vacuum
On button won't stay on
easy fix, unplug the machine sit in front of it. put your thumb on the on/off button and push down and slip your thumb off of it as fast as you can so it pops real loud. Do this ten times and then plug back in and see if it works. ( this came from talking with Dyson people) Hope it works for you. They said this will reset the machine. also acts as a warning that your filters most likely need cleaned.
May 21, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vax 4100, how to disassemble for repair
To disassemble a canister vax you first remove 2 screws holding the handle cover. One is just above where the power flex enters the handle, the other is at the mid-point of the top, hidden under the label. Both are small crosshead screws. Before doing attempting this, you need to be competent with working on mains electric wiring, as some of this has to be removed to do all this.
Once the handle covers are removed, the next bit is to gently lever off the speed control knob - it's a tight friction fit, then undo the nut holding it to the handle cover panel. After this undo the mains power connections from the multi-block joiner they go into then remove the 2 screws securing the mains wire. Then undo 2 bolts at each end of the handle going downwards into the main body. At this point the handle can be removed as well as the top body plate. You have to fiddle the electrics and switches through the hole in the top body plate to remove it. Now 3 bolts and a small crosshead screw is all that holds the upper motor section to the lower. Remove these and you can separate the 2 halves which gives you acess to the water pump. This is held in by screws founf underneath the plastic ring at the base of the motor body (around where the small reound blue sponge filter goes). This ring is held in by plastic springy clips. Gently lever round it to get it come off.
That's it. Re-assemble is reverse of all this. Don't disconnect the electrics without drawing pictures or photographing to work out which wire goes to where.
Mar 12, 2008 | Vacuums
Powermate connection flickers
I had the same problem. Sears has replacement parts for mine (Model 11625813506) here: http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=11625813506&pop=flush
Rather than pay $10 for a new cover terminal (which I probably couldn't install myself anyway), $99 for a whole new wand, and possibly $108 for a whole new hose (ridiculous prices, btw), I took a small flat head screwdriver and scraped off the dirt/corrosion on the terminal pins. This didn't resolve my problem, but I noticed the connection between the extension wand and the "Power mate" hose handle was loose. The handle could wiggle/slide about 1/8" when connected to the wand, creating the loose connection. I used the screwdriver to bend the pins down slightly (in the direction away from the wand tube), to compensate for the loose connection. This worked like a charm, fixed the intermittent circuit contact completely, and was very easy to do. I'd highly recommend trying this, before doing anything more complicated.
Feb 09, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum Logo
64 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
