Question about Westinghouse TX-42F430S Television
My tx-42f430s will not power on
While watching tv the screen froze. I attempted to power it off with the remote control but this did not work. I unpluged the power cord and it turned off. when I tried to turn it back on with the remote control it would not work. I left it unplug over night and it still will not work. I changed the battteries in the remote control... this did not resolve the issue. when I press the menu button on the side of the tv or replug the tv the westinghouse sign displays. The amber light is on. Can someone please assist.
SOURCE: My HDMI ports won't work on my Westinghouse tx-42f430s TV
Unplug the power from the LCD HDTV. Wait about 30 seconds. Then plug in like normal. Press and hold the power button (on the lower left hand side on the TV) for about 10 seconds. The westinghouse logo should show up. Go to "Menu" then "Settings" scroll down to "Factory Reset" then click "Yes". The HDMI PORTS are ready. It should work cause it worked for me.
Posted on Dec 27, 2007
SOURCE: Won't power up past the W logo.
Try hitting the input button and selecting the correct source. Mine is YBPBR1. That should get you a picture!
Posted on Nov 18, 2008
  • 96 Answers
SOURCE: westinghouse tx-42f430s won't power on
More likely it's because of power circuit of your TV set. If you are not trained enough in repairing TV sets, appeal to your local repair center
Posted on Jan 25, 2009
dave1645
  • 834 Answers
SOURCE: got an westinghouse LCD model tx-42f430S. got
have you run setup yet ? if not do so if you still get nothing then you r need a mainboard replacement
Posted on Nov 30, 2009
Testimonial: "Hey Dave, posted a reply please check if you do not mind, Thanks"
  • 58 Answers
SOURCE: what is the weight of
I found 2 different sources online that list the weight as either 61.1 lbs or 68.1 lbs. I think the 61.1 is more accurate for the bare TV without the stand or anything attached. But keep in mind that when mounting a flat panel TV to a wall, you should secure it with hardware rated for much higher weight tolerances. Many mounting brackets for TVs of this size are rated for 150 - 200 lbs, and for good reason. Consider a situation where someone trips and catches his balance on the wall-mounted TV. The TV is already putting 61 lbs of pressure on the bracket, so any force from any other contact is added to that. It doesn't take much to add up to 100 lbs or more. If the mount breaks free from the wall, you'll have damage to the TV, the wall, the mount, and any furniture or flooring beneath the TV, so the best advice is to mount it as if it weighed about 150 lbs. The 7 lbs +/- difference in reported weights won't matter at all.
Posted on Jan 25, 2011
Testimonial: "very helpful"
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Westinghouse tv turns on power light blue works for 3 minutes then turns orange
This is going to be associated with your inverter or your display board. Some cases they are the same board. You will have to take this apart, find the board and then find a replacement.
Apr 13, 2014 | Westinghouse TX-42F430S Television
MWe have one of these tvs and this morning it wont turn on although the light in front is red and it still wont turn on
I had the exact problem and couldn't do the factory reset or another reset that a Westinghouse tech told me to do over the phone - BUT I FIXED IT! This is what I did. With the TV facing me and power on and connected to my cable antenna (like normal - ready to watch TV) I took my right hand and started pressing all different buttons on the side of the TV in different order at random. All of a sudden the big W came on the screen so I called back Westinghouse technical assistance and she told me go to menu - then TV - then scroll down to channel search. Since all my cable channels are on channel 3 on the TV - the search found that channel and the picture and sound came on and works fine!
Sep 05, 2011 | Westinghouse TX-42F430S Television
Got an westinghouse LCD model tx-42f430S. got power to it, but only a blue screen. Can't access inputs, menu, or any function on tv...any ideas??
Nov 30, 2009 | Televison & Video
Westinghouse tx-42f430s won't power on
Jan 25, 2009 | Westinghouse TX-42F430S Television
Nov 17, 2008 | Westinghouse TX-42F430S Television
Channel number display will not turn off
are you using the TV tuner of the TX-42F30s or are you connecting via setup box
what happen if you change channel
the unit can be reset to factory mode.
Nov 15, 2008 | Westinghouse TX-42F430S Television
Horizontal Blue Line
WHEN YOU HAVE A SOLID BLUE LINE THAT DOES NOT MOVE...YOU HAVE A DEFECTIVE PANEL...LIVE WITH IT OR REPLACE PANEL..NOT COST EFFECTIVE TO REPLACE PANE....JOE ACE
Jun 13, 2008 | Westinghouse TX-42F430S Television
Remote code
DirecTV offers a remote code lookup tool, which I just used to find possible codes for my Westinghouse TX-42F430S; its first suggestion (the "most popular" code) didn't work. Clicking the "It's not here" button showed seven more codes, and one of them (11577) worked perfectly. Here is the full list of Westinghouse codes for DirecTV from that tool (as of 11/27/08):
Most Popular Code: 10885
Other Possible Codes: 10889 10890 11577 11282 10451 10000 11092
Nov 10, 2007 | Westinghouse 16093 Remote Control
TX-42F430S Lock up on power up
I have a similar problem with my TX-42F430S; Mine freezes when changing from Comp 1 to Comp 2. unpluging and waiting was the only fix. Just recently my TV just started turning off(after about 30min of watching) and the led will flash blue. I need to unplug for about 10min before it works again. Getting frustrated and I have contacted Westinghouse to send for repair. only had the TV for 3 months; connect to Roger Explorer HD box.
Nov 02, 2007 | Westinghouse TX-42F430S Television
Televison & Video Logo
120 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
