Question about Microsoft Windows XP Home Edition
Need to remove 32bit HP components windows installer out of conmtrol panel
I have numerous files in cotrol panel and cant seem to remove any of them need fixing
  • 52 Answers
You need to write your problem in more detail, and to be specific of what you are trying to do in order to make us understand your issues so we can suggest how to fix them.
Posted on May 10, 2014
4 Suggested Answers
proton77
  • 1183 Answers
SOURCE: need to setup windows xp faxing
Since you donot have the windows xp cd , you would not be able to enable the fax feature in windows xp home edition.
Alternatively you can download a fax program from the interent and configure the same to send faxes.
One such porgram is called snappy fax, can be downloaded from the link below
http://www.snappysoftware.com/
Thanks
Proton
Posted on Jan 31, 2009
  • 25 Answers
SOURCE: I tried to download MS Paint from control
1. Open a cmd line
2. start
3. then click on run, type "cmd" in the box then ok.
4. When the cmd box pops up c:>
5. type: c:>\windows\inf\sysoc.inf
6. when the note pad window pops up scroll down till you see the line:
TabletPC=tabletoc.dll,TabletSetupProc,Tabletpc.inf,HIDE,7
It would be wise to save the "TabletPC=tabletoc.dll,TabletSetupProc,Tabletpc.inf,HIDE,7" string to replace if anything goes wrong.
Just cut and paste in word etc and you can just paste it back in the sysoc notepad if anything weird happens, OR
7. Simply highlight this then delete it. Now hit save in the file option tab. Close the window and now you should have access to the change or delete files in the control panel..
if this works for you let me know
Posted on Oct 21, 2009
crok41
  • 621 Answers
SOURCE: Autorun is Disable, how to fix it?
Just goto Control Panel then Autoplay, you can make all of your own custom settings for all types of CD,s and DVD,s and programs. Cheers from Scott
Posted on Mar 11, 2010
Incorrect side by side configuration when i try to open my yahoo messenger
remove it from control panel add or remove programs and install it again
Sep 14, 2011 | Yahoo Messenger
Plz tell me how to stall hp845c printer to pc windows 7 32bit
you need download your printer driver for win7 32bit
Jun 01, 2011 | Computers & Internet
No sound device driver in my window xp
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 22, 2010 | HP Sound Card
Can't use HP Solution Center anymore to scan documents (I could before upgrading from Vista to 7)
did you go from xp/vista 32 bit to windows 7 32bit or did you install windows 7 64bit.
Most likely you will need updated drivers from HP, which are available at there webite support area. www.hp.com - click support - insert your model number - select your operating system - download
If you do need software, you may also need to uninstall any previously installed printer software before you install the new downloaded software.
This can be done in the add/remove programs section of the controll panel.
Apr 05, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Does Emperor RotMK work with Windows 7?
I have Windows 7 32bit and was able to successfully install Emperor ROTMK. I used to get that error with an old disk I had. it was because my disk was damaged.
Feb 02, 2010 | Sierra Entertainment Emperor: Rise of the...
Scanner problems
This worked for me. You want to start fresh so delete your HP printer in "Printers and Faxes". Also delete any HP software that loaded in Control Panel "Add and Remove Programs". Next in Control Panel under "Add and Remove Programs", the "Add and Remove Windows Components" TAB, check mark the file to add called "Other Network File and Print Services". After clicking next, the extra print files will load. Reload your software/ HP drivers and it should be fine.
Jul 05, 2009 | HP Office Equipment & Supplies
Hi this is randy
If you do not have the disk you download software from Internet, follow instructions below,
Click here:Drivers and Software:HP Officejet 4215
A web page will open, follow instructions, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthefile,doubleclick on the file, if you get introubles ,thenfollowinstructionsbelowto reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note some printer does not work on Vista.
Sep 27, 2008 | HP Officejet 4215 All-in-One Color Photo...
Ethernet cotroller - Driver need for Hp Compaq nx6115
I have Compaq nx6115 too and faced the same problem. I tried all sorts of stuff following useless guides. This works on for me:
Download drivers from Broadcom (link below) and manually install it from your Windows XP Device Manager.
http://www.broadcom.com/support/ethernet_nic/4401.php
Select your Windows version correctly (e.g. Windows XP 32bit)
Jul 02, 2008 | Adapters.com BT-0333 Bluetooth USB Adapter...
Microsoft Windows XP Home Edition Logo
13 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
