Question about Vacuums
Beaterbar won't turn
Model nunber v43286x
Just go to your local grocery store and purchase the type of belt that it says under or on the back of the cleaner
Posted on Mar 28, 2014
Hayden supervac
There are end caps and you can replace them. You will need to expose the brush bar/ beater; and remove it. Dig out the end caps and replace with exactly the same type. If you inspect the so called bearings, you may find matted up material that caused the stoppage. Clean and retry the system before getting a set of end caps.
Apr 03, 2014 | Vacuums
Beater bar won't turn
The belt may look ok but they lose elasticity and should be replaced at least every 6 months to deep clean properly. The beater bar may have debris stuck in the endcaps which keeps them from spinning freely. Depending in what vacuum you have, some have a separate motor which turns the beaterbar. If yours has a separate motor it could be the motor, the switch, the wiring or a variety of other possibilities.
Mar 26, 2014 | Vacuums
Brush won't rotate
Undo the screws for the housing pull out the beaterbar and remove any string or hair. Put a new belt on the beaterbar then put the bearings back into their slots and gently put the other end of the belt over the motor shaft.
Nov 30, 2013 | Vacuums
Beaterbar wont turn and motor just hums like its locked up
it might need a new belt, thats what drives the beater bar from the motor
Nov 19, 2013 | Vacuums
Henry hoover
That means you had too much hair in your beaterbar or that you had the vacuum set too low to the floor. The beaterbar stopped turning and the rubber belt was slipping creating friction and heating to the point of melting. When you vacuum check often that the powerhead (beaterbar) is moving. If the belt ever slips it stretches or melts in half and must be replaced.
If you were referring to the motor then there isn't much you can do but replace the motor.
Oct 17, 2013 | Vacuums
This is usually a sign that your vacuum belt has split or broken. Remove any screws to the part that houses your belt and check to see if it's still on the beater bar or not. If it isn't...look further to locate where it is. It may have only slipped off, or it may be broken.
Take the manufacturer's model number of your vacuum, bring it to the store and locate a new belt. You can usually find a generic replacement in most hardware stores if you can't get the brand name. Or you can go to the manufacturer's website and order the brand name one there. They usually only cost about $5. each.
Good Luck...and happy cleaning !!
Mar 14, 2011 | Vacuums
Rainbow d3c beaterbar has low suction Vacuum itself has great suction
did you check the hose or the power nozzle it might have holes in it.
Jan 13, 2009 | 3M SV-497AJM Vacuum
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
