Question about Plumbing
The lift rod for my tuscany brooksville faucet is too short
Is it possible to get a lift rod 2 inches longer than normal
    Master:
  • 340 Answers
If you are talking about the lift rod that opens and closes the sink drain stopper, then this is adjustable by moving a clamp on the rod. If the drain does open far enough then move the clamp.
Posted on Mar 26, 2014
How do I fix my Tuscany Faucet my handle broke off while I was turning it off.
Go to any ACE hardware and see if they sell the parts for the faucet, bring the faucet with you. ACE carries a lot of this kind of parts.
Nov 30, 2016 | Plumbing
Can a tuscany sherwood double handle lavatory faucet be used for a bathtub?
there is a manifold available from a good plumbers supplies shop where the taps are separate on the branch ( "T" bit where the spout is mounted) this allows the taps to be positioned on the branch to fit the holes in the tub, basin or wall
they are fitted using a ferrule (plastic or copper seals) and nuts and are tightened up when in position
If you do not have taps suitable for this branch then you will need to buy the taps as well
the branch will be around $20.00 and the taps around $30.00 each for normal screw inserts
ceramic inserts will cost around $60.00 each but will last a life time.
talk with the plumber supply shop for good advice.
Jun 25, 2015 | Plumbing
How do I replace/repair the sprayer diverter valve in a Tuscany kitchen faucet?
Do you have a model # ? Normally the diverter will be exposed by removing the spout.
Dec 23, 2014 | Plumbing
I have bathroom faucet. Brooksville model 6736025. I need a longer lift rod. Is it possible to order one. The granite backsplash is 1 and 1/2 inches and the lift rod is about 2 inches short
I don't know much about Brooksville 6736025 but if it is like most other brands, the lift rod is a pretty thing that shows connected to a not so pretty rod or piece of metal that does not show. I would look to see if there is a not so pretty piece that can replaced with a longer not so pretty piece.
Mar 26, 2014 | Plumbing
The hose is always filled with water when not in use. The longer that water remains stagnant in that line, the more it will absorb that smell. Try running the water for 10-15 seconds before filling your glass. If that doesn't solve the problem, purchase a new hose.
Oct 20, 2013 | Plumbing
Where I can find replacement handles for a Tuscany bath faucet?
Bathroom fittings and accessories is the ultimate destination where you can get best quality replacement handles for a Tuscany bath fauce.
Apr 14, 2013 | Home
I have purchased a Tuscany Brass kitchen faucet with pull-out spout in the past 3 years. The problem is that the faucet leaks out through the loop handle and the spray head mounting collar what can be done...
if i remember correct this connection is plastic to plastic,if this connection is broken you must replace the hose and the head.i hope this helps.good luck with you project.
Jul 27, 2009 | Plumbing
I cant not get the pop up drain to move smoothly
Take it apart, clean it, lub the ball on the linkage, then reinstall it. If that is not the problem try ajusting the lift rod linkage where it connects together.
May 08, 2009 | Moen Bathroom Sink Faucet - 4-inch...
Plumbing Logo
97 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
