Question about Nortel Lands Phones
Is there a way to setup caller id on a Nortel system that show when the phone rings
Is ther a way of showing the caller id on a nortel system MICS r7.1 without using the Feature 811. Or so it comes up on it's own while the phone is ringing.
  • 104 Answers
In system programming, you can select whether the display is the name, number, or line.
F**CONFIG
Terminals&Sets
enter extension #
skip Line Access, Capabilities, Name, User Preferences
Telco Features
skip Feature Assign
at 1StDisplay use CHANGE softkey to toggle to NAME.
Posted on Feb 02, 2015
cnavarro
  • 2460 Answers
SOURCE: Caller ID
Since it appears by default, I'm guessing that the phone is not ringing. It has to ring to display CID. You need to make sure that it is part of an ICD group with Immediate ring.
Carl
Posted on Sep 03, 2008
SOURCE: nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Posted on Jun 27, 2009
ynotphone
  • 192 Answers
SOURCE: Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Posted on Jul 16, 2009
consultel1
  • 860 Answers
SOURCE: we have nortel t7316 phones in our office. one
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only
press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Apr 16, 2010
PhoneSystems
  • 213 Answers
SOURCE: I have a network of samsungiDCS 28D phones. The
Hi you need to add your extension to the group that your phone rings in to. usually this is gruop 500. you can check this in MMC 714 in customer programming. I have attached a video showing how to add members to groups, there are 60+ relating to the Samsung iDCS range at www.abbeytelecom.com
Posted on Jan 28, 2011
How do you set caller id to show before you pickup on the nortel t7316e
Feature **CONFIG,
Teeminals&Sets,
enter set #,
Telco Features,
1stDisplay,
use Change softkey to cycle between Number, Line, Name
Rls to exit programming.
You need a CI line card in the KSU.
Aug 15, 2014 | Nortel Lands Phones
Caller ID does not display name on Nortel phone
Cell phones do not send caller name, so create a Speed Dial entry for that number with the name you want to see. When a call arrives from that number, the system will show the name you have programmed.
Jul 11, 2017 | Nortel T7316E 2-Line Corded Phone
M7208 call display not working hot sure how to program it. when calls come in it does not show who is calling
So is the display not working or are you trying to set up caller ID?
M7208 phones were delivered with the very first Nortel systems and if you have one of those, you're not getting CID. The CICS cabinet or higher requries a CID trunk card and IIRC 5.0 or higher software. If all of those are in place, as a minimum you can press FEATURE 811 to display CID info.
Carl
Feb 05, 2011 | Nortel Meridian M7208 Corded Phone
M7310 + Caller ID
You need CID service from teoco, Caller ID capable circuit packs in your Norstar system and 2 parameters turned on in programming under "terminals a & sets" for each extension. Also the CID will only auto display on sets that have the ringing turned on for that line. (you can also program a display button..feature-811). I doubt it is the software version but to display it go into programming and step down through the menu from 'Terminals&Sets' 10 items to 'Maintenance' and press 'show' then show again at 'System Version' this will give you a display like "SP: 30DHC04 NAT". Hope this helps. Bill C. www.dyns-tech.us We also do remote programming on Nortel CICS and MICS so equipped
Mar 15, 2010 | NorStar M7310 Corded Phone
Our caller ID has stopped working and this has nothing to do with our monthly ATnT service
The caller ID facility is an optional facility provided by your Operator and this needs to be activated from operator side in order to show in customer's Called ID device.
Please check it with any other line that has the same facility activated.
Jan 21, 2010 | Nortel Business Series Terminal T7208 -...
Jul 16, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel t316e phone only rings 2 times
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
Programing my nortel t7316e charcoal to access whole phone lines
If you are fmailiar with the programming of the system, you must set the lines (3-8) to appear and ring on the extensions.
Assuming you have a later release MICS or CICS:
Press Feature ** 266344, then the installer password.
Press Show at Terminals and Sets, enter ext #.
Press Show until you are asked for the line number, then scan through the line appearances, and change to "Appear Only" on the lines you don't want to ring at that set.
Repeat for each extension you want to change.
DO NOT DO THIS UNLESS YOU ARE FAMILIAR WITH PROGRAMMING.....
Nov 11, 2008 | NorStar T7316E Corded Phone
Nortel M7310
Your M7310 phone does not have caller ID. The phone system can have caller ID and there are a few different options you could have for phone system and caller ID packages. You should try to find out which Nortel phone system you have and possibly what type of Caller ID unit.
I suspect you cannot do what you are looking for because as I mentioned, the phone itself does not have caller ID and only displays what the phone system tells it to. It is more complicated for a caller ID system to store a list of previous calls when you have multiple lines and multiple phones. Would you want to see a list of every call that has come in, just the calls that rang at your station or just the calls that rang and you answered at your station.... BUT... this may be ansered in a user guide specific to your phone system or your caller ID interface.
Oct 25, 2007 | Lands Phones
Lands Phones Logo
362 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
