Question about Plumbing
I have bathroom faucet. Brooksville model 6736025. I need a longer lift rod. Is it possible to order one. The granite backsplash is 1 and 1/2 inches and the lift rod is about 2 inches short
Lift rod is too short
  • 352 Answers
I don't know much about Brooksville 6736025 but if it is like most other brands, the lift rod is a pretty thing that shows connected to a not so pretty rod or piece of metal that does not show. I would look to see if there is a not so pretty piece that can replaced with a longer not so pretty piece.
Posted on Jun 08, 2014
  • 374 Answers
SOURCE: Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Posted on Mar 13, 2009
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
  • 94 Answers
SOURCE: I have a Moen Chateau bathroom faucet (chrome,
yes it sound's like you need a cartridge.i think the # is 1225,you might also want to invest in a cartridge puller also,moen make's one, and brass craft make's one as well.
Posted on Apr 29, 2010
  • 349 Answers
SOURCE: water leaking at handle when turned on
1- Hanldle may have a cap that will come off to access screw to loosen or allen screw on the handle to remove it.
First thing you can check remove handle and make sure the nut that holds stem down is not loose. You can tighten it and try this first just replace handle turn on and check for leaks.
If not please go to step 2 in removal of stem
2- Cut water off and remove handle to gain access to stem. Next remove stem by untighting nut at the base. Remove stem and replace o rings on stem about middle of it. That will stop water from leaking at the base.
Posted on May 21, 2010
packrat1948
  • 528 Answers
SOURCE: the shank of the faucet
A lot of the faucet manufactures have not kept up with the new counter top innovations out there so I would say you need to pick out a new faucet that has an extended shank. Short of counter sinking the hole from the bottom of the sink top the above is your only out.
Posted on Feb 08, 2011
The lift rod for my tuscany brooksville faucet is too short
If you are talking about the lift rod that opens and closes the sink drain stopper, then this is adjustable by moving a clamp on the rod. If the drain does open far enough then move the clamp.
Mar 26, 2014 | Plumbing
Delta faucet will not hold water
The linkage to the drain stopper has to be adjusted so that the stopper seats when the rod is raised. If the stopper lifts out of the drain, it may be necessary to remove the lifter rod and insert it through the holes in the bottom of the stopper then reinstall. After this, pulling up on the faucet rod will force the stopper to seat rather than drop by gravity. The tradeoff is that you will not be able to remove the stopper without disassembly of the connection
Feb 18, 2013 | Plumbing
The shank of the faucet is an 1 1/4 inches long and the granite counter top is 1 1/4 inches thick. cannot tighten nut to hold faucet in place
Feb 08, 2011 | Fontaine Plumbing
I have a glacier bay 7032e-b6104 two handle bath room faucet. i just finished installing and water is leaking underneath from the middle of the three holes where the lift rod is. what's wrong??? tony
Sounds like you have a defective faucet. I'm guessing this is a new faucet and there shouldn't be any water leaking from between the faucet and the counter top. All the fitting above the counter top are factory fittings.
The only possibility I can think of is that if you didn't use a back up wrench when you installed it and you twisted the factory installed lines too far while tightening the water supply line to the faucet, you could have broken a weld on the faucets supply line where it is connected inside the faucet.
Sep 28, 2010 | Home
I just want to be sure I place the sink properly into the new countertop. Are there certain distanced from the back or front I should be aware of? I have an Eljer tile-in bathroom sink, model 052-0317. 21...
The most critical dimension is the clearance between the backsplash (wall side) and the sink as you want to ensure that there is room for whatever faucet set you've selected. Typically you want to leave 4 1/2 to 5" between the rear of the sink and the backsplash for the faucet but that's not critical as long as you leave sufficient space for it. A typical bathroom countertop is 22" deep so your large sink will be close fit. Now, if the faucet mounts through holes in the sink itself you can just center it.
Apr 22, 2010 | Home
I cant not get the pop up drain to move smoothly
Take it apart, clean it, lub the ball on the linkage, then reinstall it. If that is not the problem try ajusting the lift rod linkage where it connects together.
May 08, 2009 | Moen Bathroom Sink Faucet - 4-inch...
Mar 11, 2009 | Moen Bathroom Sink Faucet - 4-inch...
Seperate a granite tile backsplash from an existing countertop
the back splash should be held on by silicone or glue very seldom are they screwed on i would bet it is stuck with adhesive silicone so score around the outside of the splash with a utility knife the remove it scoring around the outside will prevent sheet rock damage
Jan 08, 2009 | Jenn-Air JED8430 Electric Cooktop
Plumbing Logo
48 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
