Question about Samsung Tools & Hardware - Others
Leveling I have a Samsung PL-10 lathe. I need to move it to a new location in my shop. Does it need to be leveled? Someone told me that it didn't need to be, but that doesn't make sense.
    New Friend:
  • 60 Answers
Hi there who ever told you that had better go back to trade skool any heavy industrial machine needs to be leveled after it has been relocated other wise in time the bed will twist and your accuracy on machining will be out
Posted on Apr 23, 2014
Do I need to change rear shocks after a lift kit
SilveradoSierra.com • Changing shocks after rear blocks : Suspension
www.silveradosierra.com/suspension/changing-shocks-after-rear-blocks-t56785.html
  1. Cached
  2. Similar
Mar 22, 2013 - 5 posts Will the factory shocks still have enough travel or will they max out? I also did the ReadyLift 2.5 leveling kit. Same question. Do I need to replace ...
5 Things You Should Know About Car Lift Kits ' eBay
www.ebay.com/gds/5-Things-You-Should-Know-About-Car-Lift-Kits-/.../g.html
  1. Cached
  2. Similar
When drivers install car lift kits, their goal is generally to take their vehicle from its ... lift kit or a suspension lift kit will come down to the type of tire they want to install on ... when installing a car lift kit is to purchase the wheels after buying the kit.
2" Leveling Kit, which one to buy? Do I need new shocks too ...
www.dieseltruckresource.com/.../2-leveling-kit-one-buy-do-i-need-new-shocks-too-1...
  1. Cached
  2. Similar
May 2, 2007 - After what I went through to install the leveling kit on my truck $250 ... I, personally, did kept the stock shocks on my truck and it seemed to do ...
Do I really need shocks with leveling kit? - Ford Truck ...
www.ford-trucks.com > ... > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
  1. Cached
  2. Similar
May 4, 2011 - 15 posts - ‎7 authors If you're still running factory shocks, it's worth changing them out even if you don't do the leveling kit. The truck will need to be aligned after a leveling kit. .... eye as the stock. install your lift and have the alignment checked. if it ... Do you need new shocks with rear lift blocks? 11 posts 6 Oct 2012 How much lift before longer shocks are required? 12 posts 15 Apr 2010 More results from www.ford-trucks.com
Your Lift Kit How to Guide on Lift Kits for Coilers & Independent ...
www.4wheelparts.com/buyers-guide-reviews/lift-kit-how-to-lift-kits-coilers.aspx
  1. Cached
  2. Similar
The following parts do not qualify for Free Shipping: ..... The downside to all coil spring suspension lift kits is that they alter the operating angles of ... That changes the axle location (axle moves to the rear in front, and forward in the rear), ... manners and efficient operation you will need to go with a long arm suspension lift. Do need to change rear shocks after lift kit Google Search
Jan 25, 2017 | Cars & Trucks
Samsung HE Top Load washer always going off balance. Only 4 months old and Ive had trouble since day 1.
Open this link and chat with Samsung technician .
('http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=N0000651&model_name=WA45H7000AW/A2&model_cd=WA45H7000AW/A2','',800,600)
Jan 04, 2015 | Samsung WA422PRHDWR Top Load Washer...
How to level a samsung dishwasher?
Usually the front legs can be adjusted by just turning them. The 1 back leg (Samsungs use a tripod foot support system), is adjusted through a remote screw-type leveler that is located in the center (left-to-right) of the base, just behind the toe-kick panel.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
May 30, 2014 | Samsung Dishwashers
Why is the Green light not blinking?
Do a peg test, if the unit is leveling and accurate, then it's just the green diode has malfunctioned, dont worry about it, it happens.
If the peg test fails, then either the keypad board has failed, or a motor may be jammed. Or possibly the laydown switch has is stuck, and the laser things it's perminatly in vertical mode, and wont level. Take it to a laser/survey shop as the front label will have to be replaced just to open it, to diagnose.
Apr 01, 2012 | Spectra Precision Laser LL400 10 Automatic...
How to level a Whirlpool Conquest refrigerator 2009 after moving it from a different house? The left front now wobbles.
To level your refrigerator:
Remove toe grill. Use flat-blade screwdriver or 3/8" socket wrench to adjust the front rollers. Or Turn the leveling leg clockwise to raise the side of the refrigerator or counterclockwise to lower it. Which ever applies to your unit.
Note: Having someone push backward against the top of the refrigerator takes some weight off the leveling legs. This makes it easier to adjust the legs.
Aug 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Volvo 960 gle estate self leveling suspenstion 1995 model. car lying low onto wheel arch when not loaded
IF self leveling (gas struts) are faulty,when you come to a stop after driving for about 10 mins,the rear will not have risen to level.(still low).then they will need replacements fitted,they are not that expensive,compared to some air suspension types.(just in case im not clear,the rear pumps itself up AFTER moving off/driving and will settle when stopped for awhile after.)
Oct 15, 2010 | 1996 Volvo 960
I have a 2009 Ford F150 2wd. I added a 2 1/2 leveling kit with 34 in tires and 20 wheels. When I turn it makes a sound like its rubbing. I eventually took it to a brake service center and was told that...
first check its not the tyres rubbing on the mudflaps/wheelarch.or even the inner wing(fender)YOU NEED TO GET SOMEONE TO TURN THE WHEEL HARD OVER WHEN YOUR UNDER THE CAR TO SEE WHATS TOUCHING.......the abs/electronics is just garage ********......
Sep 28, 2010 | 2004 Ford F150
Moving a canon ipf8100
normally you have to perform move printer level 2 to avoid damage to the printer. But, if you move the printer without taking any dangerous angle then you don;t have to choose level 2, level 1 or no move is OK
Mar 08, 2010 | Canon imagePROGRAF® iPF8100 InkJet Printer
Washer spins so hard, washer moves across floor
If the washer is old, the snubber pads will need replacing and greasing. This requires special tools for disassembly to the point where one can perform the required service.
If the washer is less than a few years old, the issue is simple leveling.
Look under the front edge of the washer and locate the leveling legs and locking nuts. Using a crescent wrench, free the locking nuts and re-level the washer, re-tightening the locking nuts.
Sep 05, 2009 | Maytag Washing Machines
Need to know what kind of power steering fluid to use?
Your car, being a 735 iL (the iL being the key here) requires what is called Pentosin 7.1. This is a mineral based hydraulic fluid used in BMW's with self leveling suspension. Since your car is an iL you have self leveling suspension. Not a lot of parts stores carry this fluid. NAPA has it, if it's not on the shelf they can order it. BMW dealers also stock it. The same pump that runs your self leveling also runs your power stearing and they are filled in the same location as they share a common resivoir. This resivoir is located in the engine compartment on the driver's side and looks like a black bottle with a screw type cap.
Mar 04, 2009 | 1991 BMW 7 Series
Tools & Hardware - Others Logo
69 people viewed this question
Top Samsung Tools & Hardware - Others Experts
john h
Are you a Samsung Tool and Hardware - Other Expert? Answer questions, earn points and help others
