Machine when you turn on only goes to spinning?
When i switch it it goes to spinning
Washer completes cycle 100% but then it restarts and starts filling all over again/ rewashes in essence
Dear William, I guess first you have to check if the start switch is shorted. When you turn on the machine, does it automatically go into cycle? If yes, then your start switch is faulty. Otherwise, you may have to replace your timer/sequencer.
Jan 16, 2014 | Washing Machines
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
My kenmore won't pump out the water. what could
couple of possible reasons and this will vary by brand of machine...lid switch could be bad...some machines will wash or agitate with lid up but will not spin unless lid is closed..others will not do nothing with lid up....some brands will not spin if the water level switch can detect water in the tub...this means your machine didnt pump the water out of the machine so it could spin couple of reasons for this 1 bad pump or bad pump motor(some machines have a pump that is driven by a drifferent motor than the one that drives the transmission)usually these machines use the water level switch to activate(turn on/off) the pump when the machine goes into spin cycle... some machines the pump wil come on and stay on for the entire spin cycle...some machines the belt will be bad and you just need a new belt....first thing to do is see if raising the lid will turn the machine off when it is in wash cycle if it does not..then it will in spin cycle..if the machine will not work in spin cycle the lid switch will be the reason why..
Sep 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Will not spin
You have either a bad lid switch, a bad drive coupling or a bad timer. If you can move the timer dial to spin manually and turn it on and it spins the lid switch is good and the timer is bad. If you manually move it to spin and the motor runs with no spin, the drive coupling is bad. If you manually move it to spin and nothing happens, the lid switch is bad.
Jun 11, 2009 | Kenmore Washing Machines
Agitates but no spinning or draining
Check the lid switch for continuity.
Open the control panel, disconnect the lid switch from the top of the cabinet.
Use a volt/ohm meter set for continuity. Insert the probes into the connector attached to the cabinet. With the lid closed it should get a reading. If no reading replace the switch.
While it is open you can make a jumper wire and jump out the lid switch wire going to the timer. Then turn the dial to spin and turn it on. If it spins it verifies a bad lid switch. If not, you have a bad timer.
Apr 29, 2009 | Kenmore 23822 Top Load Washer
Machine washes but doesn't spin when draining water
You have a bad lid switch if you close the lid right before it touches the cabinet you should here a click if not you will need a lid switch. Good luck
Apr 03, 2009 | Kenmore Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washer will not Spin during SPIN CYCLES
check the lid switch on the washer its below where the tab on the washer lid that goes down in the body of the washer there two screws at the base of the control panel back these out and raise the panel you will see a connector coming from the washer disconnect it and put a jumper wire where it goes to the control panel turn it to spin pull out the knob if it spins replace the switch if it doesn't reply to me and we will go from there
Jan 30, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
