Question about Panasonic KX-FLB801 All-In-One Laser Printer
Printer will not print
After a print request, the message is not received by the printer. The print queue shows a 0, even after I have submitted a print request.
    Genius:
  • 1,114 Answers
If you are talking about a printer that is hooked up to a computer make sure the printer is selected by the computer to print. Go to the control panel and to printers and enable this printer. It may read "make this my default printer.
Posted on Mar 26, 2014
3 Suggested Answers
  • 224 Answers
SOURCE: Panasonic DP3030-Will not print from a computer
are you using post script? that error message appears when the firmware does not recognise the emulation. i would say you would need a firmware update on the device
Posted on Mar 31, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Dec 18, 2010
Hello, I'm having problem with my phaser 3140 printer. Every time I'm trying to print a file, the printer doesn't responds and it shows that there's always 0 in queue. Can any one help me please?
Please check your "print queue" on your computer. Check that you don't have, "use printer offline" set. You will likely see all your print jobs in the queue, and setting the printer "online" will cause them all to start coming out.
Feb 29, 2016 | Office Equipment & Supplies
Waiting for printer to become available error
Is this the error message you are getting? If so, it looks like that there is a long queue waiting to be printed and there is some error. So you have to check the printing queue and delete all and it should show '0' waiting at the printing queue.
Oct 28, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
Just put all new image drums and toner in my Okidata C5300n, checked the IP address, the computer sees it and shows the pending print job, but the printer in not receiving the print job. I have tried...
In most laser printers, when you replace the drum, you need to reset your drum in your printer's menu options. This is to reset the page count for your printer to tell you when it will need to be replace again.
May 09, 2012 | OKI C5300n Led Printer
When I press print I get the following message: "The Lexmark 2600 series is currently busy. Your print request will begin as soon as current processing is complete". Nothing prints. The...
There could be some print jobs stuck in the print queue. Try to clear the print queue first before sending a new print job. Follow these steps: - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- Browse to your windows\system32\spool\PRINTERS\ folder - You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files. - Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service) - Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Try to print again.
Apr 25, 2011 | Lexmark X2650 All-In-One InkJet Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
924 message "printer is busy"
Take out the cartridges
disconnect printer from computer
Turn off the printer
On the computer cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot.
Reconnect printer (swap cables if not detected)
Insert the cartriges
Try printing again
Have a great day!
Let me know how it is going
Pablo :-)
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Changing from XP to Vista
Does it print from any other program? (e.g. Notepad, MS Word etc) Are you receiving any error messages? are the documents being passed to the printer queue? (if the printer icon is showing, you can check this by double clicking it - most printers will show the queue upon double clicking the tray icon)
Jun 24, 2008 | HP Officejet 4215 All-in-One Color Photo...
Panasonic KX-FLB801 All-In-One Laser Printer Logo
23 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
