Hello, 1. Our AEG Lavamat Carat stopped working from one moment to the other. 2. When I do program the machine, the digital display will show the usual info (but NO error code). 3. Once having pressed the starting button, the cover locks up properly and the pump is starting its routine three seconds or so, water-expulsion. 4. After that has happened, the clock will count down normally, but nothing is happening within the machinery itself. 5. The machine is not turning/spinning and no water is being poured in. 6. I tried the recommended error code procedure, but - although many codes will appear during the systematic turning of the program-button, no particular code is showing up, when the button is in its final position (as has been promised by some technical advice-paper). 7. I also removed the side panels of the machine and opened up the above part of the print-box and I opened the ENV box below-rear in the machine. 8. But I have not noticed anything unusual in the print channels nor is there a flavor of burned plastic or so. 9. As far as I can judge, all the connections in the AEG are being well placed too. 10. So what in your opinion should I do to solve the problem. kind regards
