Sansui sled2453 bad reception
All the channels are fuzzy like there's a bad cable connection, yet the connection is good. When you pull up the menu, the menu is crystal clear
  • 3,904 Answers
If all the channels are fuzzy it is still a connection problem or a signal problem. replace the cable that runs from the box to the TV. What type of cable is being used? If you verify that the cables are good then you need to call your provider as to why the signal is so weak. The fact that the menu comes up means nothing in this case.
Posted on Mar 26, 2014
SOURCE: Poor reception when connected to cable (no cable box); DVD player will NOT accept discs
I called Polaroid Customer Service.
Thanks
rosemary38
Posted on Aug 20, 2008
  • 13 Answers
SOURCE: I have had my 40 inch Samsung LCD for
I have come across that problem about 8 times in the past, only solution to your problem is to have the main board replaced.
Posted on Jun 21, 2009
tvtek
  • 1284 Answers
SOURCE: pixilization on non hd channels with hdmi cable
Your TV is not at fault, it is showing you the difference between HD and non HD channels. HD TV's work great with HD scorces but don't usually look that great with standard definition, Also the non-HD channels are more likely to be heavily compressed which makes them look bad too.
Posted on Nov 03, 2009
Testimonial: "You know, I think you're right. The cable company would never actually say that their service is flawed. They blamed the TV. Thanks anyway!"
  • 8457 Answers
SOURCE: Cable picture is fuzzy
Ur standard DTV signal picture ok?Not than ur Main Tuner signal board is dead.Must replaced the Tuner signal board.
Posted on Apr 05, 2010
BElectric
  • 1140 Answers
SOURCE: I just purchased a Dynex
I think you will find that all of your channels are still there. If you are using digital or digital and analog channels, some of the digital channels may be on "sub-channels". This is explained on page 14 of your Dynex user manual. For some channels you will need to enter the main channel number - e.g. 8 - followed by a decimal point, then the sub-channel number - e.g. 8.3
The decimal point is below the 7 key. The easiest way to check whether you have sub-channels or not is to press the GUIDE key in the top-right corner of the remote for a complete list of the digital channels.
It's difficult to determine what is causing the 'fuzzy' picture. I would advise you to disconnect the coax connection at the back of the TV, inspect it for any damage, then re-connect it. It could also be caused by interference from another electrical device. Some TVs have better interference suppression than others and it's possible that your old Toshiba was better at eliminating interference.
There is also the possibility that you bought a lemon. I suggest you concentrate on making sure you have all the channels first then we can look at possible reasons and cures for the fuzzy picture. You don't want to spend too much time (or money!) getting it right if you can't get all the channels and you end up returning it to the shop.
Please check for the digital sub-channels first then reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Mar 26, 2011
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
Fuzzy channels all of a sudden, cannot figure out how to get reception again?
Sounds like your cable has become disconnected at some point between the television and the outside connection. Start by unplugging the cable at the rear of the TV and then reconnect. Check the picture. If no success, then trace the wire back to the next connection point and disconnect and reconnect. Continue to trace your line until you get to the point where the outside cable connects to the house. If you do not get a clear picture, then you will need to purchase a new cable.
Jan 23, 2012 | Televison & Video
Magnavox tv has cable channels 2-13 only. Lost original remote. Using a universal remote. Tried to auto program. It started scanning but when channel 14 came around, just fuzzy snowy picture all through...
The set needs to be switched from antenna to cable in the setup menu. It is capable of either antenna reception or cable reception. Ch 2-14 are the same frequency for antenna and cable but above 14 they are different. That is why the picture is stoping at 14. After you switch it to cable auto program again. Thanks for using fixya.
Nov 12, 2009 | Televison & Video
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
My sansui tv is hooked up to my cable; it gets channels 4 - 13 beautifully...but nothing else. how do i program it to receive the rest of my cable channels? It's a 2004 tv.
you need to go into the menu section of your tv and find the channel auto program and let it start and finish completely {the menu should go off it self when its done} then you should be good.
Jul 17, 2009 | Sansui DTV2760 27" TV
Setup 32 inch sansui for digital reception
1) Connect your signal source - either CABLE or ANTENNA.
2) Go into your menu and select your signal source to match.
3) SCAN in the channels. This will give you all channels available.
Your User Manual will give you all information.
If you are on cable, you may have to check with your supplier to see if they carry local stations.
Feb 23, 2009 | Sansui HDLCD3210 32 in. LCD TV
Poor cable tv reception.
Problem is direct "ingress" of the terrestrial signal from the TV station (off-air) on to the cable along with the signal from the cable company. Typically caused by faulty/bad/cheap connectors and cables. If you are certain that the signal is clean from the cable company, then the best solution is to replace the cable in your home with good quad shielded cable, with good tight connections made. You could start by checking all "F" connectors top see that they are snug. An amp may increase the signal enough to overcome the ingress and help a bit, but it usually just amplifys the same signal.
Apr 05, 2008 | Sansui DTV2760 27" TV
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
Channel Reception
1) Auto-program
2) Exchange under warranty
..........T.
Dec 19, 2007 | Sansui DTV2760 27" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
