Washing machine does not wash anymore
Hello, 1. Our AEG Lavamat Carat 47328 stopped working from one moment to the other. 2. When I program the machine, the digital display will show the usual info (but NO error code). 3. Once having pressed the starting button, the cover locks up properly and the pump is starting its routine three seconds or so expulsion. 4. After that the clock will count down, but nothing is happening. 5. The machine is not turning/spinning and no water is being poured in. 6. I tried the error code procedure, but - although many codes appear during the turning of the program-button, no particular code is showing up in its final position (as has been promised by some advice-paper). 7. I also removed the side panels of the machine and opened up the above part of the print and I opened the ENV box below-rear in the machine. 8. I have not noticed anything unusual nor is there a flavor of burned plastic. 9. As far as I can judge, all the connections in the AEG are being well placed. 10. So what in your opinion should I do to solve the problem. kind regards
Mix-it-up
  • 832 Answers
SOURCE: Print and copy comes out blank paper - MFC-420CN All in one
mac,
I guess your machine has a serious problem with the purge unit.
Its indicated thru error 39. (the other ones are quite normal: A! menas Cover open (when replacing carts) and the 8x are related to paper feeder (running without paper/paper jam))
Have a look on the encoder disc which is positioned on one of the big white gear wheels on left hand side. Is it stained or broken/scratched? Do you hear scratching noises when machine is powered up?
Anyway its worth a look. But it could be that the print head has dryed out/clogged though it wasnt cleaned for a while.
If you cant get the error clear the only way to fix the machine is to replace the whole print unit including ph and cart holder (incl. tubes). This is quite simple to do because you can simply unplug the connectors on the main circuit (left hand side red/black cable), loose one screw which is within the metal (position near power inlet, can be seen from above), unfasten the cart holder connector to main board. Unfasten the two white flat cable of the ph.
The whole spare part can be used from a dcp 110c/dcp 115c which you can buy as a 2.hand one at eBay. HAve a look for a dcp with broken scanner glass ;-)
Posted on Dec 08, 2007
antiochpc
  • 1314 Answers
SOURCE: Reverse printing
Open your printers/faxes folder, right click the printer you want to change, select properties. In that window, click on printing preferences. Click on the next to last icon (should be an A with a red arrow going to an upside down A). On that screen is an option to reverse print. Click on it.
Thanks and please take a moment to rate as fixya.
Posted on Nov 10, 2008
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
goodgold
  • 389 Answers
SOURCE: Paper Jam 8-112 when power on Xerox DocuColor DC 1250 Printer
You it is necessary to make sure visual(optic) to see the sensor(pick-off) of that node(knot;element), which(who) you is informed.Byvat that conk or клинят sensors(pick-offs) of the passing, electronics in this case her(its)(her) fault is practically excluded. Extremely(Most) seldom(rarely) such быват.I work(operate) 18 years I had 1 or 2 times, but only mechanical damages much(highly;very much) often were. The Sensor(Pick-off) conks or клинит, when remoove the stuck paper. I am simply(merely) run away that reason in sensor. Good luck you!
Posted on Sep 20, 2009
  • 903 Answers
SOURCE: Hi i have problem on my copier model Ricoh aficio
If you've done all of those steps and the problem keeps happening, it's most likely a dirty or defective thermistor, or a blown thermostat. The simplest solution is to replace the fusing unit as a whole, but if you want to save money, you can take the fusing unit out (the black unit on the upper right side, the one that heats up) and using a multimeter, determine if one of the thermostats is bad. Also, check the thermistors (the sensors that lay against the hot roller) for any built-up toner, and check the continuity of the fuser lamp while you have the unit opened up.
Posted on Jun 05, 2010
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Require a user manual for a LAVAMAT 1000 to download
Hello I need to number kushintës Lavalogic AEG 1600 washing machine
Feb 07, 2011 | AEG Lavamat Lavalogic 1600 Front Load...
User Guide for AEG Lavamat 502 washing machine
Hello Annete_fost,
Not a precise match...
but this will give you an idea to search the
internet in your local area...
(this being the an Francisco Bay Area)
https://www.manualslib.com/l/lavamat+502.html
Results 1 2 of 2
Hope this helps...
Carnac the Magnificent
Dec 14, 2010 | Washing Machines
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
No manual Lavamat 625 Senstronic
Still looking Lizziehmp?
1 - wash with pre-wash
2 - Quickwash
3 - soft rinse
4 - long spin (4 + woolmark -- short spin for wool)
5 - extre pre-wash / soak program
6 - pump-out
it is actually more complicated as each number above is further modified by pressing combinations of buttons. (see for example 4 above)
E - economy
1/2 - for small loads
funny V symbol - variomatic spin
Leave some contact, I could get you a copy of instruction card
Happy washing.
Voitek
(Warszawa, Poland)
Jan 11, 2009 | AEG Lavamat W1450 Front Load Washer
Lavamat 86800 stop the washing cycle after few seconds without any error code
Hi - did you ever find a solution to the problem? My 12 year machine now showing the same issue.
Oct 11, 2008 | AEG L86800 Front Load Washer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
k24674
jasbo
jasbo
