Our AEG washing machine stopped functioning
Hello, 1. Our AEG Lavamat Carat stopped working from one moment to the other. 2. When I program the machine, the digital display will show the usual info (but NO error code). 3. Once having pressed the starting button, the cover locks up properly and the pump is starting its routine three seconds or so expulsion. 4. After that the clock will count down, but nothing is happening. 5. The machine is not turning/spinning and no water is being poured in. 6. I tried the error code procedure, but - although many codes appear during the turning of the program-button, no particular code is showing up in its final position (as has been promised by some advice-paper). 7. I also removed the side panels of the machine and opened up the above part of the print and I opened the ENV box below-rear in the machine. 8. I have not noticed anything unusual nor is there a flavor of burned plastic. 9. As far as I can judge, all the connections in the AEG are being well placed. 10. So what in your opinion should I do to solve the problem. kind regards
Mix-it-up
  • 832 Answers
SOURCE: Print and copy comes out blank paper - MFC-420CN All in one
mac,
I guess your machine has a serious problem with the purge unit.
Its indicated thru error 39. (the other ones are quite normal: A! menas Cover open (when replacing carts) and the 8x are related to paper feeder (running without paper/paper jam))
Have a look on the encoder disc which is positioned on one of the big white gear wheels on left hand side. Is it stained or broken/scratched? Do you hear scratching noises when machine is powered up?
Anyway its worth a look. But it could be that the print head has dryed out/clogged though it wasnt cleaned for a while.
If you cant get the error clear the only way to fix the machine is to replace the whole print unit including ph and cart holder (incl. tubes). This is quite simple to do because you can simply unplug the connectors on the main circuit (left hand side red/black cable), loose one screw which is within the metal (position near power inlet, can be seen from above), unfasten the cart holder connector to main board. Unfasten the two white flat cable of the ph.
The whole spare part can be used from a dcp 110c/dcp 115c which you can buy as a 2.hand one at eBay. HAve a look for a dcp with broken scanner glass ;-)
Posted on Dec 08, 2007
IB4G2008
  • 3587 Answers
SOURCE: here is page from manual showing belt unit
what page is this in the user guide?
Posted on Mar 13, 2008
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
pineworks
  • 4041 Answers
SOURCE: Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Posted on Jan 25, 2010
le_kash
  • 106 Answers
SOURCE: Nokia XpressRadio 5030 phone keypad
  • if phone has history of getting dropped to the floor or banged hard, this could cause the keypad contacts to misalign
  • try opening the case and cleaning the keypad contacts
  • best solution is have it checked by nokia service center tech support
Posted on Oct 02, 2010
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts to flash. Door indicator light then goes from...
You will need to change the carbon brushes in the motor. Tip machine 45 deg backwards you might need someone to hold for you and look at motor underneath you will see 2 black carbon brushes remove these and replace if worn then retry machine also make sure the wires to the motor are ok.
Jan 07, 2011 | AEG Lavamat 12710 Front Load Washer /...
User Guide for AEG Lavamat 502 washing machine
Hello Annete_fost,
Not a precise match...
but this will give you an idea to search the
internet in your local area...
(this being the an Francisco Bay Area)
https://www.manualslib.com/l/lavamat+502.html
Results 1 2 of 2
Hope this helps...
Carnac the Magnificent
Dec 14, 2010 | Washing Machines
I have an AEG Lavamat L 16850. It has stopped showing an EFO error code for the second time (on the 20 minute cycle both times). The first time I removed the fluff filter which seemed to solve the...
We have this problem for nearly 2 years now. It always occured in a special program ("Kochwäsche/Buntwäsche 60°" what means coloureds/boiled 60°).
The AEG technician didn't find the problem. Since we avoided that program, the problem never occured again.
But now, close before 2-years-warranty-by-law I demanded them again to repair it. I will report.
Oct 25, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Lavamat 86800 stop the washing cycle after few seconds without any error code
Hi - did you ever find a solution to the problem? My 12 year machine now showing the same issue.
Oct 11, 2008 | AEG L86800 Front Load Washer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
k24674
jasbo
jasbo
