Question about Mtd Garden
Need repair manual for HydroGear 718-0255a hydrostatic transmission. Does anyone know where I can get one?
4 Suggested Answers
  • 85 Answers
SOURCE: checking fluid level
most units of this size & quality have a factory sealed transmission. to check or change oil, the transmission would have to be removed.
Posted on Sep 12, 2009
SOURCE: Need a workshop/repair manual for a Kubota T1760
So do I Did you find a solution?
Posted on Oct 22, 2010
SOURCE: I have an Ariens riding
Click here to download the Parts Manual .
Click here to download the Repair/Service Manual.
Posted on Sep 15, 2011
Diagram for hydrostatic drive
Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one.A short description of the events preceding the beginning of the problem is also helpful.
The NOT SERVICEABLE UN-TRUTH.
The Huskvarna YTH150 uses Hydrogear transmission 319-0650, drive model 150071. One place to find parts and diagrams for most Huskvarnas is here: http://www.m-and-d.com/Hydro-Gear_parts.html
MTDs use Hydrogear trannys also. Go to the site and enter 618-0319 in the search box. It will bring up a selection of MTD transmissions.
Sears Craftsmen mowers also have trannys from Hydro-Gear.
The best lawn tractor Hydrostatic Transmission Fluid isactually 10W-50 synthetic motor oil (like Mobil 1). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Most of them are made by one or two manufacturers. Tuff Torq makes a lot of them, but not the Huskvarnas. They do make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, an untruth. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. They have a lot of good general info for anyone rebuilding their tranny.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like Mobil 1™). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black drain plug on the top, if they do not have the add on reservoir. You have to remove the tranny from the mower (not a difficult things to do, it takes about 30 min). Pull that black plug (I used a 1" putty knife to pry mine out) and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out; clean it and replace it. It may fall out while the tranny is upside down.If anything else falls out, you have a broken tranny and will have to take it apart.
When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
Tuff Torq Lawn Garden
Apr 07, 2015 | Garden
What oil in the hydrostatic and how much oil is needed
For an answer specific to your machine we need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one. A short description of the events preceding the beginning of the problem is also helpful.
Here are some general thoughts on Hydro Transmissions
Virtually all of these trannys have a black drain plug on the top, if they do not have the add on reservoir. You have to remove the tranny from the mower (not a difficult things to do, it takes about 30 min). Pull that black plug (I used a 1" putty knife to pry mine out) and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out; clean it and replace it. It may fall out while the tranny is upside down. If anything else falls out, you have a broken tranny and will have to take it apart.
Mar 29, 2015 | Garden
What type of oil goes in a craftsman dlt 3000 hydrostat tranny
Mar 25, 2015 | Craftsman Garden
MTD 918-0319 Hydrostatic Transmission is it a sealed unit or do you add grease
you add hydrostatic fluid through the filler hole
Oct 03, 2014 | Garden
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
Westwood 1012h ride mower
If I recall, hydrostatic transmission should only be carried out at a properly equipped workshop. Check yellow pages for your nearest mower repair shop. They should be able to collect it if you are unable to get it there yourself.
Apr 16, 2014 | Troy Garden
Husqvarna hydrostatic transmission
my transmission on the right side do not have the power the lifr side have what do i need to do to fix it
May 14, 2013 | Husqvarna Rz5424 Zero Turn Lawn Mower...
My MTD 12.5 hp briggs and stratton ride on mower is losing forward speed as though a clutch is slipping especially going up hills or slopes. MIKE
You didn't indicate what model so I don't know if it is hydrostatic drive or not. If it is not hydrostatic drive, it is most likely a worn belt or clutch adjustment. If you don't have your manual you can download one here:http://www.mtdlawnmowerparts.com/manuals.php
If it is hydrostatic drive it stil could be the drive belt or low water in hydrostatic transmission, or even water in the oil in the hydrostatic transmission. Always list model number when asking questions.
Oct 03, 2010 | Mtd Garden
John deere transmission what other mowers interchange
You will have to first know what kind of transmission you have. You will have to consider if it is manual or hydrostatic drive. The transmission model number should be stamped usually on the top of the transmission. Yes transmissions are interchangeable, for example some John Deere, Craftsmans and Husqvarna all use the same transmission. Peerless is a manufacturer of these, the only one I know of. So don't let anyone tell you that you can ONLY use a John Deere product. To determine what transmission you can cross over with, get the model and serial number off of your John Deere's transmission. Call a small engine repair shop and ask them what all transmissions it will cross over with. Let them know you are aware that Peerless manufactures the same transmissions for most all riding mowers and that they will interchange. If they are uncoperative, contact me with the model and serial numbers off of your transmission and I will cross reference it for you. But try to get model and serial numbers for other brands from them, then check these against used ones. You will need to tell them if it is a hydrostatic transmission or manual and if so what speed manual.
Jul 11, 2009 | Athearn N Rtr John Deere Tractor Model B ...
Garden Logo
263 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
