Question about Dell Inspiron 13z i13z-8864sLV Intel Core i3-3217U 1.8GHz 13.3"
Internet connection intermittently drops out, requires reboot
Even when lan and wifi adapters are disabled/re-enabled. even though all other (10+) computers on network are functioning perfectly.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 174 Answers
You can try reboot
Posted on Mar 26, 2014
  • 50 Answers
SOURCE: Unidentified network
Your office network is probably hidden you will need to change the settings on the router. Talk to your Net Admin about it.
Posted on May 21, 2008
SOURCE: LAN and Wireless connections problem
PC laptop D610's standby and hibernation functions are deactivated and non-functional; how do I get them activated again?
Posted on Nov 26, 2008
Geekman
  • 32281 Answers
SOURCE: wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
Posted on Feb 03, 2009
peeface
  • 180 Answers
SOURCE: adapter problem
you can go here
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRON1300/B130&os=WW1&osl=en&catid=&impid=
you might be able to put in your service tag and it will tell you the one you have or you can click the plus sign next to where it says network on the page and and download a couple and try them.
Posted on Feb 16, 2009
shakeelm
  • 224 Answers
SOURCE: Dell inspiron E1505 cannot connect to internet
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
Posted on Mar 04, 2009
LevelOne WBR-6005 Router WIFI Problems
Open "Network Connections" on your wireless laptop, and check that the wireless adapter is "enabled". Look for a slider-switch on your computer that may "enable/disable" your wireless adapter.
Aug 27, 2014 | Levelone Computers & Internet
I can't connect to WiFi. Any advice?
Is the wifi enabled, can you see any wifi networks? If not, make sure wifi is enabled, if there is button on laptop to disable/enable wifi connections, swich wifi on.
Check from control panel -> network (network and sharing center in Vista/Win7) -> change adapter settings. If wireless lan adapter disabled (grayed out).
Jun 04, 2014 | Computers & Internet
Wireless radio switch
Usually WIFI is Disabled/OFF if you typically use a wired LAN connection, and a lot of systems only allow you to have One Or The Other on at one time, otherwise it would not know which method to send your internet and network traffic.
So, you may have to Temporarily Disable the LAN connection before you can Enable the WIFI connection.
If your dell has an antenna sticking out of the back, then you have wifi, otherwise I believe this model needs a wireless card. If you do have wifi, here's how to turn it on.
- click Start,
- choose Control Panel on the right
- If the top right says 'View by: Category'
click the down arrow on the right and choose either Large Icons
or Small Icons.
- choose Network and Sharing Center
- you will now see your wireless network if the adapter is on,
if it is not on, chick on Change Adapter Settings on top left
- two connections typically show up:
1. Local Area Connection and
2. Wireless Connection
- right click the Wireless Connection,
- choose Status
> the next window lets you Enable your wireless device, check its
Properties, or Diagnose connection issues.
Let me repeat from above:
Just reverse this later if you want to go back to a wired connection on the desktop machine. I use all WIFI at home, then I connect my laptop by a cable to my router if I have an issue to solve, which is maybe once every two years.
It's easier when you are doing it than it may seem just reading this.
Hope this helps
All the best to you,
KerryHos
Jan 27, 2014 | Dell Vostro 200 Mini Tower Desktop...
Limited acess with wifi bluetooth error with Asus K55VD-SX405
If windows7 open network and sharing center then manage wireless networks then remove all networks there then click on change adapter settings right click your wireless LAN \proprieties\TCP/IP V4 use automatic IP and dns \ok\ok then disable enable it then try to connect.......Good Luck
Feb 03, 2013 | Computers & Internet
Where is the switch to conect to wireless broadband
hi, not all desktops have built-in wifi, though some do, depending on your os: click "start" (bottom left) - right click "my computer" (xp) "computer" (vista) - click "manage" - click "device manager" all the devices will show up near the middle you should find "network adapters" - click the "+" sign to expand it - the local area wired network should say: lan or 10/100 if you have a wifi installed and configured, it should say wireless etc. - if that's there, go to "start" "control panel" "network connections" here you should see the wifi connection - right click on the wifi - click "enable" if it is disabled. then click "view available wireless networks" choose the connection - enter the password if secured - connect. peace, abz
Mar 01, 2011 | Computers & Internet
Compaq presario drops internet connection
Try this....
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 13, 2009 | Compaq Presario Notebook
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
Wireless does not show up in Network Connections
Did you try - after switching on the "antenna switch" or WiFi hardware - to "Enable" the WiFi adapter, under (XP) Start - Settings - Network Connections - LAN or High-Speed Internet - Wireless Network Connection? (select, right click and select Enable)?
p.s. Once your WiFi hardware is recognized (by Win XP) there is (should be) always a "Wireless Network Connection" in your Network Connections, enabled or disabled, active or not.
May 21, 2008 | Toshiba Satellite M45-S331 Notebook
Wifi connection
hello
1. what is the model number of your adapter?
2. what is the operating system of your computer?
3. did you install the wireless adapter on your pc or is it a built in wireless adapter?
-- if you install another wireless adapter on your pc, possible that its the one causing the conflict between the two utility. I suggest to disable the other adapter before installing the other wireless adapter
-- if the wireless adapter is a built in wireless adapter and you are using a windows xp computer, chances are that the built in utility and the xp wzc are the one causing the problem. you have to disable one of this utility to make your connection working
-- the utility is sometimes located at your system. if you wish to use the utility you have to disable the wzx or the other way around.
Apr 30, 2008 | WiFlyer - Portable, shareable WiFi base...
Can't connect to internet
The issue could be with the wifi connection that your wifi adapter is connected to. If your running a windows based system, go to the system tray and right click on your wifi connection symbol (SSID) and see which network your connected to. Every LAN has its own unique name of their Local area network (LAN), if its not displaying your LAN SSID name but a different SSID name then thats the problem. If thats the case, then once again right click on the wifi connection symbol in the system tray and change the wifi connection to your SSID for "view available connection". Your wifi adapter could be picking up a wifi connection in your area and you do not have access to their LAN.
Sep 05, 2007 | Edimax (ew-7128g) 802.11g/b Wireless...
Dell Inspiron 13z i13z-8864sLV Intel Core i3-3217U 1.8GHz 13.3" Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
