Question about Scag STWC48V-25CV Wildcat Zero-Turn Rider
Won't start I was mowing and started to get off to pick up debris. Even with the blades off and the brake set the mower died. I let it sit for a while and it cranked up. Got off again and it did the same thing. Now it won't crank at all, just clicks when I turn the key. I checked all of the wiring, but everything seems to be in tact. I don't imagine it's the battery since the mower did initially crank and ran for over an hour. Please help.
    Problem Solver:
  • 11 Answers
The click means the starter solenoid is acting. Most starters are like GM autos where this solenoid is on the starter. Often heat adversely effects these parts. Try tapping the solenoid and try to start it. If that works then a rebuild is indicated.
Posted on Mar 26, 2014
Tip
Safety for All Mowers
<span> <ul> <li>Be sure to completely read the safety information contained in the operator's manual.</li> <li>Never tamper with safety devices. Check their proper operation regularly.</li> <li>Tragic accidents can occur with children.</li> <li>Do not allow children anywhere near the area of operation.</li> <li>Children are often attracted to the unit and mowing activity.</li> <li>Never assume that children will remain where you last saw them.</li> <li>If there is a risk that children may enter the area where you are mowing, have another responsible adult watch them.</li> <li>The blades on mowers spin very fast and can pick up and throw debris that could seriously injure a bystander.</li> <li>Be sure to clean up the area to be mowed before you start mowing.</li> <li>Do not operate a lawnmower with the discharge guard (reflector) or engine grass catcher installed.</li> <li>The Mower Deck has spinning mowers blades that can amputate hands and feet.</li> <li>Do not allow anyone near the mower while it is running.</li> <li>Always allow the mower blade(s) to stop completely before leaving the mower's operator position.</li> <li>Always turn off mower when crossing a sidewalk or a driveway.</li></ul></span>
on Apr 02, 2011 | Garden
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
My 155c John Deere will not start! Brand new charged battery....I turn the key...nothing(no clicking either). When bypassing it to cellinoid, it starts right up. When I shut off the mower, I have to...
Usually when the key is turned to start position the starter soleniod engages thus applying power to the starter. There are three possible causes to your problem . (1) Check for 12vdc at the terminal on the soleniod when the key is turned to start position, if there is 12vdc at the terminal then the key switch is good. (2) loose or bad cable connection at the soleniod, check connections. (3) bad soleniod -- replace it. generally you will hear a click from the soleniod when the key is turned to start position. Also be sure to check that ALL safety switches are engaged. You may need someone to sit in the drivers seat so that switch will be "made" / engaged. Park Brake is set, mowing blades are "NOT " being engaged, on some mowers if the transmission is in reverse ,even tho the brake is set the mower will not start.
Nov 10, 2013 | Garden
My 50" troy bilt zero
All riding mowers have a seat safety, blade engage safety and a brake clutch safety, some mowers have a reverse mowing safety. Seat under the seat, blade and brake you will have to check the linkages underneath, and if there is a reverse mowing one I have seen them near the shifter handle right under the fender.
Aug 23, 2011 | Garden
WILL NOT START craftman LT1000 YR.2000
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Mower stalls out after about an hour of run time
A few possibilities
1. If engine runs hotter than normal it can eventually heat up the carburetor to the point that there is a vapor lock. Blockage caused by gas bubble: a bubble of vaporized gasoline that blocks the normal flow of fuel. Problem goes away when things cool down. If that is the problem, you need to solve overheating problem. Since you have changed the oil, might be something blocking airflow to the flywheel which has the cooling blades on it. Or cooling blades are filled with debris. Make sure vent hole in gas cap is not blocked
2. Could be bad coil, or condenser causing the windings to act up when they are hot and have expanded they short out (kill engine) on their own casing. After they coil and shrink, they un-short themselves.
May 14, 2009 | Garden
Mower starts, but when I let off clutch, it dies.
Grass and debris clogg the switch mechinisms, safety interlocks are sometimes a pain to diagnose but I would first look at the seat interlock, the petal switch and ffinally then the mowing deck.
Dec 24, 2008 | Craftsman 20 hp 42 in. Deck Yard Tractor
Scag STWC48V-25CV Wildcat Zero-Turn Rider Logo
106 people viewed this question
Top Scag Garden Experts
Rick Johnson
Rick Johnson
Ted Maxwell
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Scag Garden Expert? Answer questions, earn points and help others
