Question about Curtis Televison & Video
Lcd tv flashing BLUE LIGHT
HELLO I HAVE REPLACED THE POWER BOARD,I WAS GETTING 56 VOLTS SUPPLYING THE INVERTER BOARD,TURNED IT BACK ON ,,NO CHANGE BUT I DO NOW HAVE 24 VOLTS WHERE IT WAS 56V..COULD THE HIGHER POWER SUPPLIED TO THE INVERTER CAUSE IT TO BURN OUT???. THANKS RICK
  • Curtis Master
  • 3,320 Answers
Yes
Posted on Mar 27, 2014
  • 2318 Answers
SOURCE: Insignia NS-32LCD Backlight or Inverter bad???
If you've done the flash light test, it could be the inverter board became defective but it could also be that the power supply does not provide the +24VDC to the back light inverter board.
If you could do the +24VDC test using a voltmeter then we can say for sure that the back light inverter board is defective.
Let me know if you need further assistance.
Posted on Aug 21, 2008
  • 191 Answers
SOURCE: VIZIO LCD 26 INCH model# VW26L HDTV10F NOT TURNING ON
unplug ur backlight inverter plug &power on to see ,if it doesnt on , change ur mainboard
Posted on Nov 10, 2008
ikebert
  • 47 Answers
SOURCE: After a momentary power outage Panasonic LCD TV has a flashing red light and will not turn on.
Try using a different outlet, the outlet or the tv may have been damaged in the surge. In the case of the tv contact the manufacturer and see if it's still under warranty. There may also be a way to 'reset' the tv by holding the power button down, try looking in the manual or calling customer support. In the future use a surge protector, many of today's electronics are still sensitive to power surges, older tv's were more resilliant than today's in this regard.
Posted on May 30, 2009
  • 29 Answers
SOURCE: Westinghouse Digital Electronics LCD TV Model w32701
I had the same problem..."No video but the Sound/audio was working fine." This is my solution.
Dissamble Procedures:
1. There are 4 different types of screws used. So, you can copy my technique. I used masking tape. Everytime I took out screw I taped it beside the hole.
2. You can pull the Video/Audio RCA box by plier, it is detachable.
3. You can pull also the antenna input box by plier.
4. When taking out the Inverter board, you have to flip the lcd upside-down. There are 4 screws at the four corners.
Soldering Solutions.
I soldered all 7 transformer's legs. 8 legs each transformer. I soldered also the 8 capacitors. Checked the 4 fuses.
Main Part of Solutions.
The problem was coming from the 2 surfaced mount inductors. That's why there was no supplied power (voltages) going to the inverter.
These 2 tiny inductors are labeled as L21 and L168 connecting the 12v supply and transfering the power to the inverter. IMAGINE THESE 2 TINY PIECES CAN DISABLE YOU VIDEO? That's why even if you are going to buy a new Inverter board it will not solve the problem. Because the 2 inductors are not connected fully (cold solder) although by naked eye they seems fine. Solution resolder them both.
I used 30w Radioshack soldering Iron. Don't use the 40w because the tip is thick and can damage the neighboring electronic parts. Use a tooth-pick for pressing the inductor while resoldering both ends. I used an over-head magnifying glass while soldering these 2 inductors because the size is HALF GRAIN OF RICE, I am talking a very very tiny piece.
Warning: Over heating can damage these inductors. Just in case you damage one of them. You can find a replacemen on a Dell desktop P4 motherboard. Can be found near the 4 pins cpu power (2 black and 2 yellow) for 12v.
It's been almost 3 days now my Westinghouse LCD TV still working fine.
Roan
Triangle Tech Whiz
Posted on Jul 07, 2009
BoiseLCD
  • 63 Answers
SOURCE: I have a NS-LCD37-09 tv. No picture or backlight
Your main board is faulty. I've done several of these but haven't been able to figure out which component is actually bad these yet. I've simply had to replace the board itself, and it fixes it every time. One thing you can do to get your backlights to come on (and so you know I'm not Jive'n you) Is unplug the three wire bundle that spans from power supply to main board. This will usually make the backlights fire up. I even had one that after I left it that way for a minute (with the backlight on) it suddenly started working again! But this was short lived. :-(
One time I even tried recapping the entire main to see it that would fix it. It did not. I think it might be something to do with the small chip labeled SL37HA37. It's a 16 legged bastard near the 3-wire plug I told you to pull. It's that or possibly the bigger IC near it that has a heat sink on it. The ball grid array solder joints may be faulty. Just guesses, if any smart guys out there figure this one out, be sure to tell the rest of us please!
Thanks, Chris Boise LCD www.boiselcd.com
Posted on Apr 23, 2010
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
My tv has a black screen when turned on, I can hear sound and when i put a flash light up to it i can see the picture, which part do i most likely need to replace?
http://electro-medical.blogspot.com/
Mar 01, 2016 | LG 32LN5300 32" LED TV 1920x1080, 60 Hz,...
Why does it turn from blue to black after 10 sec.?
Dec 15, 2015 | RCA Televison & Video
When I turn on the power the screen will light up briefly then go off, then the standby light goes on (red) and flashes in four times flash intervals
4 blinks notifies the back light failure . could be the back light inverter board or faulty capacitor on power supply board.have added the image of back light inverter. Also added the picture of the power board. On the picture the capacitors marked with red should be replaced first. If shows the same complaint even after that then you have to change the back light inverter board.
Power supply
Back light inverter board
25849195-rpi3jfilu1hke134nfog5c4e-2-9.jpg www.electro-medical.blogspot.com
Sep 04, 2015 | Sony KDL46V2500 46 in. HDTV LCD Television
LCD Tv, no picture, no sound, power light only
What have you got? The inverter, the mainboard?
It'll be one or the other...
Jan 31, 2015 | Televison & Video
Apex LD4088 LCD Power but no picture
If you have replaced the inverter board and the power board with known good parts the the panel itself is bad.
May 31, 2013 | Apex Digital LD4088 LCD TV
My sylvania LC427SSX 42inch lcd. i turned it off and when i turned it on in the morning the screen is black, i can hear sound and if i hold a light up to the screen i can see an image
It seems back light inverter is not working for some reason, either it is not getting volts from power supply board or got bad itself.
Please check with local tv repair shop for replacement back light inverter board.
Thanks.
Mar 16, 2011 | Televison & Video
Blue light on, no bckgd light, picture, sound, or remote HELP!!!
The indications that the power supply is going is when you start noticing flickering and sound like shorts when you watch TV...
I do not know how to answwr this without looking at it but first I will check again and follow how far you are getting electric to the board
Sep 06, 2009 | Insignia 37" LCD Flat-Panel HDTV
LT 30 HV Olevia Syntax No picture - blue flash
Ur video converter board is dead.
Need to be change.
Aug 15, 2009 | Insignia 37" LCD Flat-Panel HDTV
I have Akai 37" LCT TV. When I turn it on, no picture is getting displayed.
I NEED A INSTRUCTION MAUAL FOR THIS Akai LCT3701AD 37 inch Flat Panel LCD HDTV with Built-In DVD Player, ATSC Tuner and HDMI THANKS BLUE
Dec 17, 2008 | Akai LCT3701AD 37 in. LCD Television
Televison & Video Logo
23 people viewed this question
Top Curtis Televison & Video Experts
Martin Murray
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
