Question about Acer TravelMate Computers & Internet
P253-E Touchpad Touchpad has stopped working tried to recalibrate it and it doesn't make a difference.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 174 Answers
Reset to factory default
Posted on Mar 26, 2014
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: Touchpad doesn't work
Step 1:
The touchpad of any laptop is always subject to heavy use.
Most touchpads are designed for their durability to sustain the daily wear and tear for the lifespan of the laptop.
However, there may be instances or accidents that cause the touchpads to malfunction or stop working entirely.
There are ways to troubleshoot such problems and there are also remedies to salvage the touchpad's functionality without heavy repair or replacement cost.
Determine What's Wrong
A laptop's touchpad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touchpad may be damaged by excessive use or foreign substances such as water, dirt or food items. Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return." Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced. b> Repairing/Replacing Touchpad b> A touchpad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touchpad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touchpad is deemed a necessity, such repairs are rarely worth the cost. Attempting to replace the touchpad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop. Long-Term and Better Solution b> The simplest, and best, solution to a malfunctioning touchpad is to replace its functionalities with an external mouse. Most PCs sold after 2000 come with USB ports and getting a USB mouse either a corded or a cordless one--will remedy the problem. A cordless USB mouse may be bought for as little as $10 and some of the better-designed ones allow the user to tuck the USB stick inside the mouse's belly when not in use. Even when a touchpad is working properly, a laptop user should be advised to plug in a mouse anyway whenever possible as touchpads are notoriously difficult to use and also leaves the user in an ergonomically incorrect position.
http://www.microsoft.com/ b> http://www.streetdirectory.com/travel_guide/116002/hardware/touchpad_keyboard_for_personal_computers__pc.html
Posted on Feb 19, 2013
What to do if a hp touchpad stop working
if restarting the PC doesn't make it work again see if HP have some drivers for it. If it's completely dead despite driver install and restart you may need a new touchpad. They rarely brake but it's not unknown. Installing a second hand or new touchpad (try ebay) requires a careful hand so get someone good with electronics to do it if you don't fancy it yourself.
Apr 06, 2012 | HP Tablets & eReaders
My 2004 silverado crewcab battery went dead and was replaced. The Air conditioning system now only blows through the defrost vents and the dial to change the airflow does not work. Can this be reset?
Turn the key on and make sure the blower motor is working. It doesn't matter what speed. Turn the key off. Pull the hvac1 fuse out of the under hood fuse box. Wait five minutes. Reinstall the fuse. Turn the key on, do not start the engine or touch the heater controls. You should hear the heat swiping through the different modes. After a couple of minutes it should stop. Turn the key off then start the vehicle. It may take several tries but eventually it should recalibrate.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 17, 2011 | 2004 Chevrolet Silverado 1500 Crew Cab
My touchpad doesn't work on my aspire one D255 netbook. The wireless mouse works but the touchpad doesn't respond to any touch. How can I make the touch pad work? Is there a function?
Hi!
If the touchpad worked well before and suddenly doesn't work any more, it is most likely it was stopped by pressing the key combination FN F7. To be sure please press the same combination again and check if it works.
If it still not work, please check if the touchpad drivers are installed on you netbook.
To do so, please open device manager. (opening the device manager could be done in more different ways, e.g. click START button and, depending on your operating system enter devmgmt.msc in the Run box for windows XP or in the Search programs and files box in windows 7).
Now, under mice and other pointing devices you should find your touchpad.
If the touchpad is not listed in device manager, drivers for it have to be installed.
Drivers for your netbook's hardware are on the acer support page.
Hope it helped,
Bogdan
Aug 28, 2011 | Computers & Internet
Touchpad stopped working cannot move pointer arrow around screen
Just check for the key combination on your key board (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
Hope this helps.
Jun 26, 2011 | Computers & Internet
Built in mouse has not worked properly from day 1. Now my external mouse won't work either. I tried a different external moue, but it doesn't work either.
Unplug everything except the power cord, including the following:
Speakers
Printers
Scanners
USB devices
Personal Digital Assistants (PDAs)
USB flash drive or other external storage devices
External Monitor
External Keyboard
External Mouse
If your computer is attached to a docking station, undock it.
Make sure the touchpad or your finger has no dirt, grease, liquids or food on it (the touchpad has to make a good contact with your finger to work correctly).
Turn the computer back on and retest the touchpad.
When the touchpad still does not work correctly proceed to step 5.
When the touchpad does work correctly, attach one external device at a time and test the touchpad to see which one may have caused the issue.
Make sure the latest driver for the touchpad is installed (you may need to use a external USB or Bluetooth mouse), for more information refer to:
"How to Use the Drivers and Downloads Website"
May 26, 2011 | Dell Inspiron 1525 Laptop
Touch screen stopped working
Have you tried to recalibrate the touch screen in the Set Menu? If so, and it still doesn't respond, then the touch screen might have gone bad. This is something you should have a dealer repair. About a $200.00 repair.
Apr 28, 2011 | Husqvarna Viking 1
GE XL 1800 touchpad motor sound
that sound comes from fan motor, please replace or service fan motor ..
Sep 25, 2007 | GE XL1800 1100 Watts Microwave Oven
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
