Question about Logitech Cordless Headset for PC & Mobile Phones Wireless Headset
Hi, I purchased two units of logitech cordless
Hi, I bought two logitech cordless bluetooth headset for pc and phone.one for and for my friend as a gift. I was able to install and use mine on my Sony Vaio notebook, and we have broadband internet at home. However I just learned that my friend uses wireless internet connection. My question is, will the headset work with wireless internet connection?
Thank you.
Elana
  • 30 Answers
Your friend should be able to use the headset if your friend's computer has Bluetooth feature. THe computer will send and receive the Bluetooth signals with one transmitter/receiver like your computer does and then connect to the wireless lan with a different transmitter/receiver system on a different frequency. Just make sure your friend's computer has Bluetooth feature turned on and then setup the headset by the "pairing" process.
Posted on Jun 15, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Logitech Master
  • 1,001 Answers
Bluetooth Receiver Wireless Hands Free Calling for Home 3.5mm Audio Out Music Amazon com Charm sonic Wireless CSR4 0 Portable Bluetooth Receiver...
Posted on Jan 07, 2017
Power
Well most probably there is a battery problem, you need to replace the battery in your bluetooth headset, most of these models are powered by Small Lithium Ion or NiMh rechargeable batteries and these like cordless phone batteries are designed to be replaced at some point in its lifecycle. Find the even **** on the bottom side of the unit, where the microphone boom is attached. Place the edge of the flathead screwdriver along these slits, and twist gently back and forth until the unit opens up. Do not completely open the unit up. then you see the battery.
Good Luck!!
Jun 08, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Can I use Bluetooth headset on Bluetooth enabled land-line phone?
Sorry sir those over the head are the only ones to date that i know of
Dec 12, 2009 | AT&T Blackberry Curve 8300 Smartphone
See:http://www.testfreaks.com/blog/review/vtech-ls6245-cordless-phone-with-bluetooth/. Looks like you could at least with this one. I am also looking to do the same.
Dec 12, 2009 | Vtech Lands Phones
Bluetooth Capabilities
A cordless plantronics headset will work. A plain bluetooth headset that you use on you cell phone will not work. Mitel sells a new phone with a cordless headset and handset it doesn't use bluetooth it uses dect (europeon version) much but,
Nov 20, 2008 | Mitel 5220 IP Phone
Cant connect logitech bluetooth to phone,
the logitech head piece buttons must not be working, seems to charge ok but can't get to flash blue?
Aug 07, 2008 | Logitech Mobile Freedom Wireless Headset
Can't hear headset
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Jun 28, 2008 | Motorola Mobility H700 Wireless Headset
    I have a motorola H350
    Sounds like you need to do another method of connecting your phone to your unit, heres the trick..
    Most phones have multiple methods of installing your headset, you can either connect it, or activate an existing connection, and last SEARCH.
    If you have installed this unit already, all you need to do is ADD another device, when you find your settings for blue tooth, its as simple as TURN ON CONNECTIVITY, and your phone will find the device, if you stored it already on your phone.
    Another step is to do a reboot of your headset, hold down the call button until your headset light turns on and turns colors, keep holding the button down 5-10 seconds and you will see it, then try to connect your mobile phone to your unit by SEARCHING for DEVICES in your phone settings.
    Last but not least, you can search the internet for the headset, download the PDF and pray that this simple solution can assist you. Motorola's website is very user friendly and has a search engine similar to google or yahoo, register your headset while you are there, because you can get it replaced, exchanged, and have warranties with ALL new units purchased, or if you purchased a used unit from a local store, you still have a limited warranty you can use to get a new or repaired unit.
    I hope this helps..
    PLEASE RATE ME!
    ManOwar
    Apr 19, 2008 | Plantronics Explorer 220 Bluetooth Headset...
    I Also Got Bluetooth headset from a friend.
    Changing the headset is not going to change the battery drain on the phone.
    Aug 12, 2007 | Motorola Mobility H350 Wireless Headset
    Logitech Cordless Headset for PC & Mobile Phones Wireless Headset Logo
    511 people viewed this question
    Top Logitech Radio Communications Experts
    Bharat Das
    Bharat Das
    Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
