Question about Pool & Spa
Actuator/Valves are not in Sync with the control panel
My system has standard pair of valves to control the circulation - Pool mode, Spa Mode, Spa Drain, Sap Fill.....after removing the actuators to replace some parts, the actuators are out of sync with the Pentair control unit. e.g. in Pool Mode the valves rotate to Spa Drain, and so on....my actuators are VOR-24 Compool, kinda older models, and they do not have a toggle switch on the bottom. I have tried swapping the low-voltage cables, and that changes the behavior, though it's still not in sync with the controller.
  • Jonathan van den Berg
    Jonathan van den Berg Mar 27, 2014
    It is very possible that i installed the actuators on a different valve than they were originally on, not thinking that it mattered, but perhaps it does. I think i could easily just swap the two actuators and see if this resolves itself, of course i'd love to know if anyone knows if this is the likely cause
  • 372 Answers
You may have to open the valves and reset the cams. Not too tricky, just a lot of trial and error to get it just right
FYI when you decide to replace the actuators, Intermatic now makes a direct replacement for both Compool (Pentair) and Jandy models. They are significantly cheaper.
Posted on Mar 30, 2014
2 Suggested Answers
  • 990 Answers
SOURCE: JVA 2440 rotates continuously in spa mode
If you remove the handel and open thr top of the actuator you will see a set nut on the center of the shaft that you use to set where the valve stops. If this is tight then you may have a bad micro switch in the unit and you should replace the actuator. Good luck.
Posted on Jan 20, 2010
I have a Jandy Aqualink pool system. When I turn on the spa and heater, the spa drains..I've never had this happen but don't use the spa much. What should I check?
His is not typically a control panel issue but more likely a valve issue.
Your valves are set as follows wih a few minor variations.....
Pool mode- sucks from pool skimmer and or pool vac line and returns water to both the pool and spa.
Spa mode - self contains the spa , meaning water is sucked from the spa and returned only to the spa.
If your spa is draining then most likely one of your electronic valves is failing...most likely it's the return valve so what is happening is the water is sucked from the spa and returned to the pool instead of self containing the spa.
Easy check is to be next to the equip when spa mode is selected and two valves should move and align properly, the return side valve is most likely not moving or it is not moving into the correct position.
The fix is either adjusting the valve acuator or buying a new valve acuator.
Another thing to check is on the main panel circuit board to ensure the return and auction 3 pin plug ins are still connected.
Apr 05, 2015 | Jandy Aqualink Rs4 One Touch Control...
My controller says it is in spa mode - trying to heat only spa- but water is spilling into pool. I have 2 jandy valves, only 1 moves when I change from spa/pool mode. Any suggestions?
The valve actuator on the suction side is either bad or the toggle switch on the back is in the wrong position. There are 3 positions for the switch on/off/on. It should be in either be all the way up or all the way down. In spa mode move the toggle switch. If it still doesn't move then you have a bad actuator. If it moves someone has moved the switch.
Oct 21, 2013 | Jandy LAARS VALVE, PRESSURE RELIEF 75PSI...
I have an Aqualink RS that will not turn the pool's filter pump on either by remote or in service mode
check your jandy valves make sure they are fully open or closed they can lock your system if they are not in full closed or open mode second option is to try to turn jandy valves manually to if they are in spa mode manaully change then to pool mode or if they are in pool mode change them to spa manually on the jandy valve there is a 3 way switch this is where you can turn them manually wt we want is to send the signal back to the main control outside that the valves are in ready mode look in the main control open the door and see if there is a red light that indicates another problem if you can send me where the red light is what the red light label says it will help if you send me the aqualink model #
Oct 06, 2013 | Standard Power Center for Aqualink Rs
Spa won't heat unless in spa mode, and if it is in
On the automated valves there are tiny switches on one end or under the valve actuator. When you switch to the spa mode the suction valve should should move to fully block pool drains. The return valve should fully block the pipes to the pool returns and spa fountain. If one or both of these valves is not fully blocking the pipes to the pool then the tiny switch on that valve is in the wrong position or an operator is defective. The middle position of either of these switches turns the operator completely off so it cannot move. That is the position to avoid unless you want to operate it manually. One of the other switch positions caused the valve to move in one direction and the other switch positions causes the valve to move in the other direction. If you set the switches so when in the spa mode water is circulating only in the spa then you have the valves in the right position. Next, place the system into the pool mode. Both valves should move to the other position. If not then the valve operator that doesn't move has a problem. It could be the operator, the wiring, the control panel or a stuck valve in that order. All of this sounds complicated but once you know how the operators should act when you flip those tiny switches and how the valves should act when in the spa and the pool mode then getting the switches set right is simple. I hope this helps.
Aug 07, 2011 | Jandy Pool & Spa
Jan 07, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy aqualink rs4: pool has been winterized with the spa left on. when switched from service mode into auto mode system switches back from spa into pool mode (motorized valve switches back to pool mode)....
the only thing you can do since the jandy does not have a "winter" mode is switch the valves off. Once you have the valves in spa mode, there should be a toggle switch on the valve actuators. You can set the switches to the middle position and that will lock them in that position. You will probably have to re-winterize the pool lines.
Nov 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Why does the spa empty when the pump shuts off? just got a pool with an aqualink RS4 and no manual to look at. thanks
This problem can be caused by a couple things. the two most likely culprtits are either the absence of check valves and or incorrect actuator settings when the pump shuts down.
Your spa is most likely higher than the pool. You most likely have a spill over (waterfall) feature from the spa into the pool. This is so the spa water can be recirculated in pool mode. One of your actuator valves may be slightly off closed position in order to allow spill over in the spa, or you may have a dedicated overfill pipe in the circuit to feed water to spa in pool mode.
Whichever spill over piping you have set up, when the pump shuts down, water from the spa ( higher level than the pool) will backfeed through the overflow spa circuit, back through the pump and into the pool through either drain or return. Effectively rendering your spa level the same level as your pool.
To fix this problem, simply install check valves into the spa runs and as a secondary measure put one into the pool return run ( the run that feeds water to pool).
This will insure that when the pump shuts down, no matter which position the valve actuators may be set, water can not back feed through the pump circuit from spa to pool.
Jul 15, 2009 | Water Pik Aqualink Rs4 Package - Pool and...
SPA Filter on while Spa is Heating
If it has motorized valves the stop positions have to be adjusted so that the water coming back is equal to what it drains to stop the spill over process unless you want to add more valves but the pool pump does the job of heating and filtering the spa
Jul 04, 2009 | Jandy Aqualink Rs4 One Touch Control...
When I push filter button it say's locked out. When I push the pool ligh button it says locked out. The filter will only go on if I push spa button then they both go on. When I push solar it reads...
one of your automatic jandy valves is not working and if is not all the way around for pool the system on pool mode won't start you have two automatic jandy valve actuators one on the suction side and one on the return side go there and see wich vave still on spa mode this actuator needs to be replaced also check your control inside your house make sure you don't have it in spa mode
Jun 13, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
183 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
