Question about NA Gateway NE56R11u Intel Celeron B820 15.6 Screen Display Notebook Wi
Blank hdd how to fix to run ne56r11u
Cant set up laptop need to know how to fix
  • NA Master
  • 3,320 Answers
The hard drive needs to be formatted by an operating system before data can be loaded onto it.
Get an OS install disk. Boot from it.
Follow the directions on screen
Posted on Mar 27, 2014
Cant get into my laptop forgot password nothin will work what to do
restart you laptop and before you see the windows logo press F8 and then select safe mode. This will enable the administrator account and the default password is blank. If the administrator password is set and you dont know it you must use third party tools to reset the password. Check this out http://pcsupport.about.com/od/toolsofthetrade/ss/ophcracksbs.htm
Nov 10, 2013 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp dv9208nr with vist sp2, system keeps rebooting, screen stays blank, cant even get to bios
hi,
When the files in your system are corrupted, your HP laptop would reboot automatically. When the files which are required to run the Operating System like fonts under Windows FONTS directory are been smashed then your system's Operating System will force your HP Laptops to restart continuously. Thus in such a situation you would have to change the name FONTS in the Windows directory.
Get more help to fix HP Laptop Keeps Rebooting error . Hope this helps you.
Apr 24, 2011 | HP Pavilion dv9000z Notebook
I have an hp pavilion zd8000 when i turn on my laptop the bootmenu will come on then the screen will go blank right befor windows start loading. what do i need to do to fix this problem?
Your ROM BIOS is asking you where to find bootable media, and when you tell it the HDD (hard disk dive), the ROM BIOS can't find a bootable partition on it and just quits, leaving the screen blank.
So, either your HDD is no longer connected to the system bus (was the laptop dropped recently?), or
someone (or something - aka virus/worm/trojan/malware/rootkit, etc.) has erased your bootable
OS (operating system) from the hard drive.
Fix: boot from a "Recovery CD" and use the utilities thereon to repair your OS (or at least find what's left of it), and try to reboot.
Failing that, run any/all diagnostics that your ROM BIOS has - especially memory tests and HDD diagnostics. Why?
(a) bad/jarred loose memory (RAM cards) will prevent booting
(b) an HDD that fails low-level diagnostics may never be salvageable and may have to be replaced -
it actually may have had a head crash - which tends to happen when a ZD8000 notebook is
dropped while the system is running - or a head can crash for no apparent reason.
If you can get the system to boot to SAFE mode - run sfc (system file check) as your first attempt
to repair the operating system - its already in Widows, here's how to run it:
START > run > sfc
As soon as you can get beyond safe mode, update your favorite anti-virus package database and
run one (or more ) deep scans, until the last scan that ran to completion found nothing.
Jan 02, 2011 | HP Pavilion zd8000 Notebook
How can i fix my acer notebook?i cant open bcos thy have unlock password? when i try to open my laptop it is show up the harddisk security,,, primary master WDC WD1600BEVT-22ZCTLOCK. WHEN i press...
You need to log into the bios and edit the hdd password...
You can press DEL or F2 key when you power ON the laptop... It will take you to the bios setup...
You can navigate in the bios to reach the hard drive password section and you can set the password as blank...
Once you are done press F10 to save the changes and exit out of it...
If it doesnt works, then you can give a try by restoring the BIOS to its factory defaults(using the restore defaults option in bios) which should turn OFF the Bios HDD security feature...
Dec 11, 2010 | Acer Aspire One D250 Netbook
I recently disassembeled my laptop to fix the power adaptor inside it. After reassembely i cant boot my laptop. Disk read error. What can i do?
Perhaps you simply need to ensure you have the, correct HDD set and the boot device set properly in BIOS?
Make sure the HDD is working and OK, if you can use a HDD to USB "Dongle" and test the HDD on another PC, to see if it is indeed OK.
Jul 05, 2010 | Compaq Evo N610C Notebook
MY HARD DISK HAS EXPERIENCED A PROBLEM I CANT INSTALL THE OPERATING SYSTEM. I GET AN ERROR SAYING DISK FAILURE AND ITS DOWN NOW I CANT DO ANYTHING
Disk failure = the hard disk has a hardware failure = it's dead. It can't be fixed, replace it and reinstall.
Apr 15, 2010 | Toshiba Tecra A3 Notebook
I want break my hdd password and laptop bios password
Bios password can usually reset by removing laptop battery and clock battery from motherboard, but HDD password as i know cant remove. You should change your HDD.
Apr 09, 2009 | Acer Aspire 4720 Notebook
Won't complete the boot up
As far as the rebooting is concerned id check the bios boot order make sure it can see the HDD. You normally recieve that blinking cursor when it cant find the HDD or boot device.
Also have you tried using hte restore cd's It's a bit of a last resort effort but my guess is your HDD is dead if you attempt to run the Restore CD's and they fail it pretty much means its the HDD.
The cracking noises will be from the speaker wires either loose or touching something else causing a static type effect. Fix is to adjust wires possibly replace them. Not easy to do by yourself. Unlikely that the speakers are affecting the reboot though.
Other possibility is a faulty mainboard capacitors that will definatley rebooting to occur.
Let me know how you go with the bios and restore discs or if you need further help.
Mar 23, 2009 | Acer Aspire 5100 Notebook
Blank lcd on presario v3164au
r u able to log in safe mode.if yes uninstall the display adapter,if you cant then better send it for servicing
Apr 11, 2008 | Computers & Internet
Can't start up the laptop as Media test failure
You may have to go back into the bios and see if there is an option to automatically find HDD, or you may have to manually enter them in the Standard Bios Settings. It may be that the old HDD are still in the bios's recognised setup.
Dec 13, 2006 | BenQ Joybook 5100U Notebook
NA Gateway NE56R11u Intel Celeron B820 15.6 Screen Display Notebook Wi Logo
42 people viewed this question
Top NA Computers & Internet Experts
ray gallant
 steve
steve
Tom Chichester
Are you a NA Computer and Internet Expert? Answer questions, earn points and help others
