Question about Frigidaire PLMB209DC Microwave Oven
Frigidaire microwave professional series model #PLMB209DCC door won't open.
Door will not open when push the door open button. Ordered part (push button door part) but did not solve problem. Door still won't open unless you pry it open. What can I do to fix this?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 119 Answers
Check tension spring on door
Posted on Mar 31, 2014
SOURCE: How can I unlock my Frigidaire Microwave Model FMT118E1W
It has been resolved!!!!!
The oldest and most basic "trick in the book"!
I am embarrassed to say...I unplugged it!
The issue has gone away.
Now my wife can have her "HOT TEA".
Posted on May 15, 2009
SOURCE: Frigidaire FMV155DC - defective door interlock switch
I had the problem where the timer continues to count down but turntable doesn't turn, fan doesn't come on and food doesn't heat. Holding the door up worked for awhile but even that temporary method stopped working.
I bought a door interlock switch the cost $23 from an appliance repair place and replaced it myself. It worked like a charm. To replace the switch, you need to remove 3 screws that hold the plastic grille above the door, which exposes the 1 screw that is holding the control panel. Remove that screw and slide the control panel up to remove it. There are three switches left of the panel. Note the middle swich has a different part number so I'm not sure what that one is called. The bad one on mine happen to be the bottom one. The switch is held on by a "pin" and tab that holds it in place. Push the tab and spin the switch on its "pin" past the tab to remove. Reverse your step to put the new one on. I hope this helps.
Posted on May 09, 2009
  • 52 Answers
SOURCE: Frigidaire door/power problem
Sounds like either the latch assembly or hinges too loose to activate the micro switch. TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
Posted on Apr 28, 2009
SOURCE: Frigidaire microwave door fallen off
I had the same problem. I removed the door and used a rivet tool. I checked to make sure the door cleared the rivet head, which was nearly flat, so there would not be any microwave leakage.
Posted on Nov 20, 2011
SOURCE: frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Posted on Apr 16, 2012
When I open the Panasonic microwave oven door by pushing in the door opening button, the oven starts immediately
There is evidently a fault with the door interlock switches. Don't use it as the oven may avtually be emitting microwaves with the door open.
Get a service tech to quote you for repair as it may be more economical to buy a new one, when you will have a warranty.
Do not try to repair it yourself unless you have detailed knowledge as there are components inside which can deliver a lethal shock even when the oven is not plugged in.
Sep 30, 2016 | Panasonic Microwave Ovens
Door will not open
Hello friend, thank you for your post!
I see that the door on your Frigidaire microwave will not open. Sounds like your door latch could be faulty. I would recommend performing a reset on your microwave and you can do that by disconnecting the power cord for roughly ten minutes. If your door does not open after the power has been restored you may want to contact a professional for proper repairs. Hopefully this is helpful. -Matt
Feb 28, 2015 | Frigidaire 5304440289 Microwave Door Latch...
Open door if latch is broken
And you can't just pull the door open? I know it's easier to push the open door button but both ways should work unless the safety switch bracket moved from it's intended position. I hesitate to offer this solution, but who wants decayed food smelling up the home? Let's assume it's a counter top oven, remove all cover screws and the cover. STAY AWAY FROM ALL WIRING and I should have said first unplug the power from the appliance. Locate the door latch area and lift up on the plastic/metal bar that has a spring attached to it and the door should be released. Pushing the door release button should lead you to the latch. Once you see how it works you may find the reason the latch is malfunctioning. If it's a over the range type you will have to remove a grill at the top of the oven to access the mounting screws that release the oven from the bracket but the latch reference above will apply to this type as well.
Dec 06, 2014 | Microwave Ovens
Microwave runs when door is open
Hey friend, thanks for your post!
From my understanding your Frigidaire microwave is running when the door is opened. I have identified a few possibilities could be the control panel or your door. Since it could be any one of these underlying issues I would recommend having a professional come and properly diagnose your appliance. -Matt
Sep 22, 2014 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
What are the Reasons why One touchy door open button is sticking on FGM0205KBB microwaves
Good afternoon friend, thank you for the post!
I understand that you are stating the door open button is continuing to get stuck on your Frigidaire microwave. I would like to ask some additional questions to make sure I can provide additional assistance. First, which button are you referring to that is sticking? When I pulled up your model FGM0205KBB, I do not see a door open button. Could we verify the model number is correct? Once I have that information I look forward to assisting you. -Matt
Aug 08, 2014 | Frigidaire FGM0205KB Gallery 2.0 cu. ft....
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Frigidaire microwave won't start when door is closed. It looks like the door does not latch properly. It worked 20 minutes ago and last night. How do you troubleshoot and/or fix the switches.
Hello Scott Noble - If I was in your position, I personally will recommend consulting a certified technician first for an accurate diagnosis. Depending on what part(s) is damaged from the door, the microwave could possibly have faulty switches, door switches, or latch which only a professional can repair.
Feb 23, 2013 | Frigidaire FMV157GM Microwave Oven
Frigidaire PLMB209DC Microwave Oven Logo
252 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
