Question about Vehicle Parts & Accessories
I had a guy work on my car and he unplugged my speedometer but forgot to plug it back in, have not been able to get a hold of him and everyone I ask has no idea where to find the plug to hook it back up, my car is a 1992 vw golf cabriolet, if anyone can help me figure out where this speedometer plug is I would really appreciate it bc I am using an app on my phone atm to see how fast I drive, Thank you! :)
    Problem Solver:
  • 6 Answers
Plug itself usually runs up the steering column itself with very little play just enough to plug into the other end which is on the dash correspondence
Posted on Apr 03, 2014
2003 grand caravan sport speedometer doesn't work
I have 4 dodge caravans. Everyone one of them does this we take it on the freeway get up over 60 mph and it will kick back around. I'm serious it will work fine after. Everyone can do this. I run a small taxi business and we only use dodge caravans.
Apr 07, 2013 | 2003 Dodge Caravan
Speedometer on 92 honda prelude si
no there is no easier way if he didnt put the pin to the cable back on it must be reattached
Sep 03, 2009 | Honda Prelude Cars & Trucks
Speedometer not working on 2002 dodge ram 1500
Removed cluster from dashboard and unplugged & turned the whole cluster clockwise very slowly and needle started moving from 150 mph back down to 0 mph when rotation was completely done. Kept cluster upright while re-installing and plugged back in the plugs on back and everything was fine. Called local Dodge dealer and told me would take 30-45 minutes to reset and would cost approximately $70 to fix. Took about 8-10 minutes of my time and saved myself $70. This may not work for everyone but this was my amazing quick fix thanks to GOD for giving me this thought to try this.
Jul 17, 2009 | 1999 Dodge Ram
How can cracking the steering column make the odometer and speedometer fail?
I'm not sure if I understand you correctly. Are you saying you removed or lowered the steering column? If you did that, and the speedometer/odometer stopped working, it's most likely because the speedometer cable either somehow got broken or it came unplugged from the back of the instrument cluster. Go under the dash, and see if you can reach the speedometer cable. If you can, make sure it fully plugged into the cluster. If it is fully installed, push the metal tab holding the cable in place, and remove the cable. Try turning the cable, does it turn freely? It should. Then try pulling the cable itself out of the sheath, if it pulls out easily, it's probably broken somewhere in the middle.
Jul 06, 2009 | 1990 Chevrolet Astro Extended
Speedometer won't work on 1995 mustang
Modern cars no longer use a mechanical cable and speedometer. They have an electronic sensor called the vehicle speed sensor (VSS) which is mounted to the transmission where the old speedometer cable used to go. If the engine was replaced, perhaps the mechanic forgot to plug the wiring harness back into the VSS? Or perhaps he damaged the wiring or the sensor during the engine overhaul. (The transmission has to be removed to remove the engine from the car.)
Charlie
Jun 17, 2009 | 1995 Ford Mustang
99 jetta check engine light on, runs fine, speedometer not workin
o2 sensors will put your check-engine-light on. it is attached to the exhaust (closest to the motor)and rusts-out sometimes. you could try to fix it by buying the o2 sensor and use a socket-set to see if it loosens. i 'm not a mechanic but have had the issue, in the past, with the jetta II's and a 1997.the guys at vw dealers are great with info, if your a hands-on kinda guy/girl.
mike420
Jun 09, 2009 | 1996 Volkswagen Jetta
Help needed to install a speedometer on a 1969 volkswagen beetle
Open front Trunk to access speedometer, remove cardboard cover and unplug electrical connections to speedometer one at a time and mark them so you can hook them back up in the same places, then un-screw the speedometer cable and remove the two nuts that hold speedometer to dashboard.
Nov 23, 2008 | Volkswagen Beetle Cars & Trucks
No lights Speedometer &Tach
only those two or all instruments? if only two, then check circuit tracks in rear of cluster, check globes?? if all, check plug in connectors & all circuitry
Nov 16, 2008 | 1994 Mazda MX-6
Speedometer and odometer
It is the EBTCM. (eletronic brake traction control module ) You can still get them from Cadillac for the small fee of $1300.00. I know I fell out of my chair too... But the good news is, yes the company on ebay can fix it for about $200.00, but you need to pull it, and send it to them. Looking under the hood, it is on the driver side, under every-thing. it is at the point where the radiator hose enters the engine block. It has a lage plug of wires, and some brake lines hooked to it. only pull just the plastic part off and send.. Good luck and i hope this helps everyone...
Jun 30, 2008 | 1998 Cadillac Catera
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
