Question about Kenmore Elite 45986 Front Load Washer
Washer is control locked and nothing works
I think the kids were in the laundry room and someone leaned on the control panel
2 Suggested Answers
SOURCE: Washer walks all over
you have a spring broke on the back side of tub, that holds it level.
Posted on Jun 12, 2012
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
I have a Frigidaire (ATF6000ES) Front Load Washer all lights come on and wont work.
Sounds like either the control board is faulty or the door latch sensor is not allowing the control board to communicate to the rest of the unit.
Aug 23, 2012 | Frigidaire ATF6000ES Front Load Washer
"control locked" light is on washer
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock stays on and no other buttons are working. I went into the laundry room to find the Control Lock light was lit. As I tried to hit the Pause/Cancel button nothing happened. No other buttons...
Thanks for using FixYa. To resolve this issue press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing loc code and it will not start at all.
the control lock is on. it is a child safty feature. on the control panel, find where it says "lock" or "control lock" and points to 2 of the buttons. hold both buttons down for 3-5 seconds or untill it beeps. your washer will oporate again
Mar 29, 2009 | Frigidaire Affinity ATF7000ES Front Load...
My husband and I are building a new home with a second floor laundry room. We are very interested in purchasing a LG washer (WM2688HWMA) and dryer (DLEX8377WM), but need strategies to keep the units...
hi As a safety device, a dryer usually has a door switch that activates the working .A dryer is simply a large drum into which wet laundry is loaded. A motor with pulleys -- connected by a series of belts -- turns the drum. Air heated by a gas heater or electric heating element is blown through the drum to dry the laundry. The temperature and speed of the drum are controlled by a series of thermostats operated from a timer device on the control panel of the dryer.
The control panels on the latest dishwashers can look intimidating. They're loaded with so many dials, push buttons, and other features that the machine looks too complex to repair. This is actually not the case. With the exception of the control panel, dishwashers haven't changed much in basic design over the last two decades.
Sep 12, 2008 | LG Washing Machines
KENMORE ELITE PROBLEM
Press and hold the control lock button down until the light goes off. This is a child proof feature that may have come on if you leaned against it to long. After lock light goes off you can use the machine.
Jul 21, 2008 | Kenmore Elite 45986 Front Load Washer
GE Washer WSSH300GWW front loader washer CONTROL LOCK!!
Solution: Hold down the power and delay start button at the same time. In about 3-4 seconds a beep will occur and the red key lock will turn off. I think it is a problem in the machines firmware. I just guessed at what combination of buttons the engineers used to do a firmware reset. In any case it worked for me.
May 23, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet
On the far right sode of the control panel there is a unlock control reset button. Hold it for 3 seconds and the fault will clear.
Mar 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I need help
un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
Aug 26, 2007 | LG WM2077CW Laundry XL Front Load...
Kenmore Elite 45986 Front Load Washer Logo
18 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
