Question about Whirlpool Washing Machines
No Hot Water
WTW5200SQ0 Cold water runs fine. When I turn the control knob to HOT nothing happens. No sound, nothing. Any suggestions?
  • Craig Schuermann
    Craig Schuermann Mar 27, 2014
    Do I need to replace the thermostat?
Jimster
  • 240 Answers
SOURCE: Hot/Cold water knob will not work on washing machine
Does the water flow when you have it on warm or cold settings?  If on warm setting and water flow is cold, its probably the mixing valve.  This part isnt that expensive, and not that hard to replace.  Remove the two front console caps, remove the two console hold down screws then flip the console out and then over the top.  You will see two gold cabinet hold down clamps, pop them out, the lift the whole cabinet off the unit.   You will see the mixing valve right where the inlet hoses connect to the machine.  Let me know if you need further help.
Posted on Oct 17, 2007
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
  • 1073 Answers
SOURCE: Cold water not running.
check the cold water selenoid on the water valve
Posted on May 05, 2008
abhishek33
  • 1239 Answers
SOURCE: GE WHRE5260E1CC NO HOT WATER
hi If the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Posted on Sep 13, 2008
docjohn174
  • 943 Answers
SOURCE: Hot water cycle flow problem
hi thanks for the question their is a screen in the water valve to catch any dirt you can try and remove the screen in the water valve and try again if it works ok . it usually works thanks the appliance doc
Posted on Sep 24, 2008
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Why does the hot water not come on?
Sounds like your hot water shut off is turned off try opening it up and see what happens While you were working on it did you shut the main hot water line off. A person I know called me over because her hot water would not run and then she remembered that she had turned the main line off. She opened it up and away it worked.
Oct 03, 2014 | Moen Plumbing
I have a single control, new glacier bay bathtub faucet control. i don't have the hot water heater hooked up. i'm only getting a slight trickle out of my faucet whenb i turn the knob to cold. is it...
it is likely required. many new faucets have what's called a pressure balance valve that helps prevent scalding by lowering the pressure of hot when the cold pressure drops (due to a toilet flush or other water being run). Because you have pressure to only one side, that can cause the valve not to provide the necessary volume.
Dec 12, 2010 | Plumbing
My kitchen sink will not let me turn the hot water off, it just keeps running. The cold water shuts off fine just not the hot side.. I turned the knob under the sink and the hot water turned off but now i...
Hi hi--
You'll need to rebuild or replace your hot water control stop--that's the valve on the faucet body. If it's a single handle control, you'll need to replace the control cartridge. If the faucet has two knobs, you'll need to locate whatever stem pieces are needed within the hot valve. Sometimes, on two knob faucets, you can get away with simply replacing the rubber pieces inside the control stem. If that is the case, your local hardware store should have manufacturer-specific rebuilding kits available. Be sure to locate the faucet's model name first! That should be written somewhere on the above-sink portion of the faucet body itself, and you should be able to see it without taking anything apart.
--Hope this helps.
Sep 27, 2010 | Plumbing
My shower ok for mins, then cold, then after 5 min too hot
replace your mixet stem it is located behind the knob where you adjust your hot and cold water you will have to turn your water main off then you will need a flat head screw driver a phillips screw driver a pair of needlenose pliars to pull it apart
Mar 11, 2010 | Delta & Single Handle Shower Faucet
Whirlpool washing machine (WTW5200SQ0) temp problem
I turn off the cold water during the fill up, and then turn it back on after it has filled. I hate this washer too because of that.
Jan 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water is not flowing in when turned on.
There are 2 solenoid valves that control the hot and cold water that fail occassionally. Try running just the hot or cold water (Its unlikely they both failed at the same time). If either the hot or cold works, then you have a bad solenoid valve. They cost about $25
May 20, 2009 | Kenmore Washing Machines
My washer wont run in the hot water cycle
Sounds to me like your water valves in the back are going bad, just had it happen on mine the other day, I bought one online for like 15.00 that was new solinoid valves for both hot and cold water. took about an hour to install with no instructions (take the old one out, new one hooks up the same way) or call the washer repair people.
Mar 18, 2009 | Whirlpool Washing Machines
May 05, 2008 | Washing Machines
No hot water
Make sure your hot water supply valve is on first. If so then try reversing the hot and cold water feed lines and see if you get hot water when asking for cold. The water valve for the hot water side could be bad. Are you familiar with a voltage meter or know someone that can see if you valve coil is getting 120V when the machine is trying to fill with hot water. If not the control unit is faulty. If you do have the 120Vac on the solinoid coil and no water the either the coil is open circuit(bad) or the inlet is plugged. Most generally the problem is in the control knob unit.
Feb 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
