Question about Polaroid S7 7-in. Internet Tablet
Battery not charging tablet gets hot and wont turn on
When i plug the tablet to the charger it shows its charging with the green batt. when i attempt to turn it on it shows polaroid then shuts down the back of tablet gets realy warm when pluged in and when i turn it on w/out the charger it shows a batt. with a ! whats wrong with it?
  • Polaroid Master
  • 3,320 Answers
The battery is dead and cannot be recharged. Replace the battery.
Posted on Mar 27, 2014
4 Suggested Answers
  • 173 Answers
SOURCE: tablet wont charge
One possible cause of the problem was due to its charger loosing connection or the tablet's dc input jack had been broken. Thanks for using Fixya.
Posted on Jan 19, 2014
  • 4961 Answers
SOURCE: my polaroid tablet fell and it wont turn on
Bring it in to a repair shop...
Posted on Jun 28, 2012
farraher2751
  • 20 Answers
SOURCE: POLAROID TABLET PMID709 WILL NOT CHARGE
How old is tablet , maybe new battery is needed ???? Is there power at the wall plug your using ???? Sometimes it's as easy as the plug , !!M the charger your using May be bad , do you know how to use a voltage meter to test if there s power coming from it to your tablet ?? More info is needed on this ??
Posted on Dec 01, 2013
My tablet wont turn on or charge
Unplug the Battery, hold the Power button for 10 seconds to discharge any capacitors, Plug the battery back in, Charge the tablet until the battery reaches 100% (Factory Charger preferred), Turn it on. If this doesn't work it could be a bad battery, bad charger or bad USB connector.7 Jan 2014
SOLVED: Why won't my tablet charge or turn on? - Samsung Galaxy ...
https://www.ifixit.com/Answers/View/.../Why+won't+my+tablet+charge+or+turn+on https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=My+tablet+wont+turn+on+or+charge
not saying any off this is going to work for you but read it anyway.
the reason i say this is because i had some one else with the same problem but it ended up it was the tablet itself was faulty.
Nov 29, 2016 | Tablets & eReaders
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
May 11, 2015 | Tablets & eReaders
Trio Quad Core Tablet will not charge
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
Jan 01, 2015 | I-INC UniK Trio AXS 3G with Wifi 7.85"...
My tablet wont charge or turn on please help
Check its charger. If the charger is faulty, it won't charge the battery. If it is found OK, replace the battery. It is bad.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 17, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
Jan 13, 2014 | Tablets & eReaders
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
My Toshiba Portege M200 just stopped charging and wont even turn on? Is this the battery? Or what? The charger will be plugged in the wall and plugged in the laptop but nothing?
Try removing the battery and see if it will boot without it
Then check the caharger, charging light should be green and steady on the charger itself
If it is flickering, it meand power is not making a circuit, test charger jack with a DC volt multimeter with one probe to the outer side (earth) and one on the inner (positive). If this is ok, check the charging socket is not loose (if it is, will need replacing).
After that, suspect the power strip or charging / powerboard is dead on the motherboard
Mar 22, 2011 | Toshiba Portege M200 Tablet PC
Polaroid S7 7-in. Internet Tablet Logo
335 people viewed this question
Top Polaroid Tablets & eReaders Experts
John mullen
nexrad_chris
WTF Chuck.....
WTF Chuck.....
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
