Question about Canon Normal EF 50mm f/1.4 USM Autofocus Lens
New camera lens fits very tight on camera body
New lens fit
    Sergeant:
  • Canon Expert
  • 488 Answers
Could be due to the weather seals on this lens.
Posted on Aug 03, 2014
Hi have a panasonic gx7been given 2 sigma lenses can i fit to my camera 1 x sigma 1:4.5 F=100 - 200mlti coated zoom lens 1 x sigma mini wide 1:2.8 f=28mm multi coated lens thank you
It depends totally on whether your camera takes interchangeable lenses, and if so, do these lenses have the same fitting ? Your camera manual should tell you if you can fit other lenses to the body - if so, follow the steps to remove the lens which is currently attached, and compare the fitments with this lens and the two others you have been given. If you are still not sure, then take it all to your local friendly camera dealer, who will be able to advise you. Do NOT try to force the new lenses onto the body - this is a sure way to render them inoperable.
Dec 22, 2016 | Sigma Cameras
Getting a message that reads...communication between the camera and lens is faulty... What do I need to do
You didn't mention what camera brand you have but if it's an interchangeable lens this usually indicates either the contacts are dirty (you can gently clean with with a clean cloth or *lightly* rub them with a clean pencil eraser making sure the lens and camera body point down so nothing falls into them) or that a pen is broken. Another option is the contact on the lens has been damaged or a pin on the camera body is.
I've also had issues with aftermarket lenses (Tamron) on a Canon 7D because the tolerance of the 7D mount was very precise and the lens didn't fit as tightly as needed.
Jul 19, 2014 | Cameras
Have many lens for XG-A what other minolta bodies will they fit
The XG-A, like the other X-series cameras, uses the older Minolta SR lens mount. You're pretty much limited to the SR- and X-series cameras. They will NOT fit the newer Maxxum bodies, for example, which use the newer Minolta AF lens mount.
Dec 19, 2012 | Photography
How to mount Quantaray 70-300mm F/4.0-5.6 Zoom Lens in Sony Alpha DSLR?
This 3rd party lens (like all of them) makes lenses specifically to fit Nikon, Canon, Pentax, Minolta, etc. camera body mounts. Each has a style mount that is unique. You can not simply mount a lens made for use on a Nikon body on a Sony body.
In order to use this lens, it MUST be the model designed for use on a Sony camera. Functionally, the lens will be nearly identical on any camera it is designed to fit, only the mount (the portion that actually mates to the camera body) differs from one lens to the other.
If you bought this lens without specifying it needs to be used with a Sony camera body (and it is for a different camera) it will NOT mount. Determine if the lens is indeed designed for a Sony camera body. You may find additional letters & numbers on the lens that can help you determine which camera body brand it fits by plugging the number into Google for a search. Additionally, the Quantaray brand is / was a Ritz Camera "house" brand. You could probably bring it to one of their stores and learn all you need to know about the lens there.
Jan 31, 2012 | Quantaray Cameras
Sigma lens APO170-500mm to fit on SLR camera body
Sigma makes lenses with a variety of mounts to fit a variety of cameras. A lens with a Canon mount won't fit onto a Nikon camera, for example. Assuming the lens has the proper mount for your camera, it should fit fine.
Apr 06, 2011 | Nikon F80 35mm Film Camera
Will the lenses for a film camera (Canon EOS Rebel) fit a new digital body? Thanks.
Yes the Canon EOS lenses from film bodies will fit and work well on Canon digital bodies.
Depending on the Canon digital body you select the lens may have a 1.6 x factor. Meaning the focal length of the film lens will become a longer focal length. For an example Canon's 50mm f1.8 lens on the APS size digital sensor will translate to an 80mm equivalent. This is great for most people but, getting a good wide angle lens is a bit of a challenge, there has to be a tread off somewhere. There are Canon full frame cameras that this factor doesn't apply, for example a Canon 5D.
Dec 08, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Try and fit Canon EFS Lens to EOS 5D Body
As far as I know, you should use L series Lens to fit Full Frame Canon Camera (5D & 1D).
That would be no adapter, but please correct me if I'm wrong.
Jan 13, 2010 | Canon EOS-5D Digital Camera
What cameras does this lens fit?
Vivitar made this lens with several different mounts, including mounts for Canon and Minolta cameras. Your best bet is to take the lens with you to a large camera store. The staff at the store may be able to simply identify which mount your lens has, or they can try the lens on different camera bodies to see which it fits.
Dec 18, 2008 | Cameras
Used on a Minolta Maxxum 800 si
Hello
The Minolta AF lens will fit and work on most of the Minolta AF bodies (it will depend on exactly what lens it is as to the compatibility), you will also find that it will fit and work with the new range of Sony
digital SLR camera bodies.
The Quantaray lenses are a little bit more difficult as Quantaray make lenses for several different types of camera body, it should mention on the lens what make the lens mount is for. If you post further information about the lenses it might help.
Sep 19, 2008 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Lens
Quantaray is a private label lens made for Ritz Camera. They make this lens to fit several different camera brands including Nikon and Canon. The only ones that will fit a Canon camera body are the ones with the Canon EOS mount. If your Quantaray lens doesn't have an EOS mount, then it won't work on your Canon camera. You can take the lens to any Ritz Camera location and they can help determine which mount it has, and which cameras it will fit.
Jul 08, 2008 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon Normal EF 50mm f/1.4 USM Autofocus Lens Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
